01-24-2014, 06:46 PM | #1 |
Drives: 2010 SS 426 V8 M/T Join Date: Aug 2012
Leather seat issues...again....FIXED!!!!!!!!!
About a 1.5 years ago I noticed that my leather seats covers were coming loose on the front section of the seat.
I took it to the local dealer-ship down the road who fixed it several times before getting it to stay on tight (put some type of screws to hold it down) Anyway now I just noticed that my seat covers are coming loose between the console inside on the drivers side. I can easily pull the leather right up and see the plastic clip. On the passenger side the thing is nice and snug with no issues (perhaps because most of the time I drive alone) Does any of you know how to fix this? Your help is appreciated. Last edited by yellowrs; 02-01-2014 at 06:12 PM. |
01-24-2014, 08:22 PM | #2 |
Drives: 2011 2SS/RS Victory Red Join Date: Aug 2011
pull the seat out, re-clip it on the frame then drill a hole through the clip and frame, and then either rivet it in or screw it in. You are stressing the seat when you sit and pulling on it basically, so learn not to plop, or learn how to reach down and re-clip it on without pulling the seat. My issue with screwing or riveting it is that stress is going to go somewhere else and you might start tearing stitches.
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB. |
01-24-2014, 09:07 PM | #3 | |
The car no longer is under warranty. Thanks again |
01-24-2014, 09:12 PM | #4 |
Easy, move the seat forward, remove the two screws in the back of the tracks, tilt it forward unplug the seat and pull it out.
01-24-2014, 09:14 PM | #5 |
T50 I think? I replaced the passenger seat with the power base and pulled the driver seat to run stereo cables, then pulled both this summer to dynomat, and give it a good vac. So its pretty easy! The plug under the seat has a purple slide release.
01-25-2014, 07:42 AM | #6 | |
Will post some pictures. Again thank you for your help. It is greatly appreciated. |
01-25-2014, 12:39 PM | #7 |
Well so much for taking the seat out, managed to strip the bolt on the driver side.
I used the wright tool which I just bought at autozone but that pos bolt is in to tight. |
01-25-2014, 06:54 PM | #8 |
Drives: '10 CGM 2SS/RS 6M Join Date: Oct 2009
It probably wasn't too tight, it might have been cross threaded, mine was
01-25-2014, 07:54 PM | #9 |
That sucks! They generally come out pretty easy, like Mike said suspect they cross threaded it.
02-01-2014, 05:35 PM | #10 |
OK, finally was able to fix my seat cover problem.
Took me a while to get the screw out. Used super-glue and self tapping metal screws to reattach the loose leather. Picture 1 is driver side with the seat removed. Pic 2 is the loose seat cover. Pic 3 is the seat cover installed back in the track. Pic 4 is the the plastic clips secure with self tapping metal screws. |
02-10-2014, 01:24 PM | #11 |
Drives: A Gift From My Wife Join Date: Apr 2009
I probably would have used a couple of washers under the bolt heads to ease the stress on the fabric but good job!
-Funk
2012 Convert 2SS/RS SW/IO LS3 - Build #1081
07/21/2011 - (3800) Order produced and vehicle is being prepared for shipping. 08/09/2011 - (4200) Shipped (vehicle is shipped to the dealer or interim point of delivery). 08/16/2011 - (5000) Vehicle has been delivered to dealer. 08/19/2011 - In my possession. |
02-10-2014, 02:09 PM | #12 |
36.58625, -121.7568
Or a special plate
