11-07-2013, 09:38 AM | #1 |
Who has a stall?
hey guys, i just put a cam and heads in my car, the block is out right now, i figured that it would be easy just to throw in a new torque converter.
my questions are what should i get for my set up? (whipple, cam, heads, headers) and who has some that has worked well?
Whipple, Heads/Cam, headers, 2800 stall, 3.73 Gears, Borlas
11-07-2013, 10:08 AM | #2 |
502 RWHP N/A
For forced induction applications a torque converter rated at a stall speed of 2800-3200 will work, for n/a car builds 3600 and up depending on size of cam. I have a 3600 with gt-11 cam, milled heads for better compression full exhaust, gears, lighter wheels and drag tires and other suspension mods times are in sig for this set up
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
11-07-2013, 10:13 AM | #3 | |
11-07-2013, 10:31 AM | #4 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Does your car even hook now? If you race a 3200 or more. If you are hitting it on the street might want to go 2800-3200. And you need a triple disk.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
11-07-2013, 10:37 AM | #5 | |
its a wok in progress, this isnt my daily. i planned to do suspension work after the cam and heads with some slicks. i just haven't gotten there yet. i will make it hook. and the short time that it takes for the suspension parts to get in i can do a roll from a 30 or whatever, it will help me out
11-07-2013, 10:38 AM | #6 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
I have the night fury cam (havent installed yet) and Lethal racing recommended a 3200 stall, so thats what im getting. They issues getting it from Yank for some reason so we went with Precision Industries vigilante.
Cant speak to the performance or drivability yet as I am waiting to install everything. (N/A btw) |
11-07-2013, 11:34 AM | #7 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
Geez, am I reading that right? You have a auto with 3.91 gears and a Whipple? First, no matter what stall you get it will need to be a triple disk and your going to need your tuner to command lockup at the end of 4th at WOT. Otherwise your going to be shifting into 5th a lot at WOT. Look at it this way. Even if you have a 6800RPM limiter with 28.7" tires your only going to be able to run 121mph in 4th with the stock converter or 128mph in 4th with a triple disk locked up. You seriously might want to think about a 3.45 or 3.70 gear change because with that much power I see a shift to 5th no matter what plus that torque has got to be hard to control.
I would recommend a FTI or Circle D in the 2800 range because of how much low end torque the Whipple is going to give you. Best thing to do is call Circle D and/or FTI and tell them your exact list of mods and what you want the car to do. Those converters are really more made to order depending on set up.
11-07-2013, 04:42 PM | #8 | |
11-07-2013, 04:48 PM | #9 |
Writer
Triple disc converters have 3 clutch discs, can hold the power and stall up to higher engine speeds.
I would call Chris: https://www.circledspecialties.com/ A stall will let your engine stall up higher before you leave the starting line, which helps your ET. A looser stall will also experience less RPM drop on the shifts, which helps keep an engine in its power band.
PROJECT HEAVY CHEVY
11-07-2013, 07:42 PM | #10 | ||
11-11-2013, 05:01 PM | #11 | |
im trying to decide if i should spend the thousand dollars and order it or not
11-11-2013, 05:11 PM | #12 |
Drives: 2010 Camaro Join Date: Feb 2010
11-11-2013, 05:31 PM | #13 |
11-11-2013, 11:27 PM | #14 |
Will totally depend on your tune. I would guess with a Whipple, cam, and heads you have to be close to 625RWHP through a auto trans and even with the greatest tune I don't see it lasting forever. Also be sure to use the biggest trans cooler that you can.
