Old 09-22-2014, 10:32 AM   #1
EvilZL1
Snake Eater
EvilZL1's Avatar
Drives: 2012 AGM ZL1
Replacing trans fluid
Anyone know how to do this? If so what brand do you replace it with.
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends
https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ
Follow me on instagram:
http://www.instagram.com/snkeatr/
EvilZL1 is offline   Reply With Quote
Old 09-22-2014, 02:09 PM   #2
2014CamaroZL1
2014CamaroZL1's Avatar
Drives: 2014 CRT ZL1
Remove upper plug, remove lower plug, drain.
Replace lower plug, refill through upper plug, replace upper plug.
Used factory GM fluid.
2014CamaroZL1 is offline   Reply With Quote
Old 09-22-2014, 03:12 PM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
It isn't quite that easy as you must use some sort of flexible funnel or pump to get the new fluid in the upper hole where most cars have a dipstick tube. The GM fluid must be Dexron 6 approved for the ZL1 in the automatic. Look at the owners manual and put the exact amount that is recommended for the automatic. Mine was slightly low from the factory. Sorry, I can't remember the exact amount.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is online now   Reply With Quote
Old 09-22-2014, 05:14 PM   #4
RiCorvette
RiCorvette's Avatar
Drives: 2017 Corvette Grand Sport 3LT
I'm assuming manual tranny...
I'd take it to a sympathetic repair shop that has a (vacuum?) pump.
I did the first time without a pump and it was quite an ordeal (not to mention a stinky mess).
The 2nd time I took it to a Shop that only charged $20 for the 20 minutes necessary - well worth it.
Or if you are so inclined, there is a post about using an air compressor to
'push' the fluid from the bottle into the tranny. Search and ye shall find....
Or maybe someone will follow up with said post.
I've tried Mobil 1 Synthetic ATF and Royal Purple...
After reading a lot of posts, I think I should have stayed with the GM OEM Fluid.
Tremec C/S suggested using Mobil 1
RiCorvette is offline   Reply With Quote
Old 09-22-2014, 06:17 PM   #5
nxttruck2002
Drives: Camaro
if M6 use Redline D4
nxttruck2002 is offline   Reply With Quote
Old 09-22-2014, 07:25 PM   #6
EvilZL1
Snake Eater
EvilZL1's Avatar
Sad to say but it is an auto.
Sent from Wayne's Manor
Old 09-22-2014, 07:28 PM   #7
EvilZL1
Snake Eater
EvilZL1's Avatar
Couldn't you use a funnel with a flexible plastic or rubber hose?
Old 09-22-2014, 08:56 PM   #8
Stephen12ZL1
Drives: '21 ZLE A10
you can try but the fill hole is in a tight place and a simple $3 hand pump from autozone is fine to make this a slight PITA procedure.
Old 09-22-2014, 08:58 PM   #9
EvilZL1
Snake Eater
EvilZL1's Avatar
So in other words I should just pay the dealer $150 for pulled plugs and putting it back in to fill back up
Old 09-23-2014, 06:54 AM   #10
Stephen12ZL1
Drives: '21 ZLE A10
No, I would never pay the dealer $150 to do a tranny fluid swap. I was just trying to prepare you when you get under the car and get a little hand pump to make the procedure go easier. If you do it with a hose or flexible funnel, let me know how it goes. I have headers and the header pipe is fairly close to this area and clearance is tight.
Old 09-23-2014, 10:46 AM   #11
EvilZL1
Snake Eater
EvilZL1's Avatar
What side is it located on?
Old 09-23-2014, 11:49 AM   #12
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
You said you have an automatic, right? None of this is for you then. For an automatic you have to remove the pan on the bottom of the trans, drain it, replace the filter, replace the pan with a new gasket, then refill thru the dipstick tube under the hood. It's not hard but it's messy.
This still leaves a lot of old fluid in the torque converter and trans. To get it all out you have to disconnect one of the cooling lines from the radiator then fire up the engine and catch the old trans fluid as it spews out and have someone cut off the engine as soon as the fluid stream stops. Don't run the engine any longer than necessary.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 09-23-2014, 12:48 PM   #13
Stephen12ZL1
Drives: '21 ZLE A10
unfortunately, there is no dipstick on the Camaro. The fill plug is on the passenger side where the dipstick is traditionally located on every rear drive GM with an automatic transmission. You don't have to remove the pan either. Our cars are so new at this point I would just use the drain plug and replace fluid only. If the car has mega mileage, then definitely remove and replace the pan, gasket, filter, etc. Forget the tranny line disconnect trick above...it can be done on other vehicles, but I would advise against it on this car.
