07-29-2014, 02:50 PM | #1 | |
Drives: 2010 SS, (ARH/Farks 8sec car) Join Date: Jul 2013
ARH Shortie Headers Pick Up Huge Gains For Turbo Builds
Jeremy at Power Fab Automotive recently installed our ARH Shorty Headers on a customer’s twin turbo Gen 5 Camaro. Jeremy’s standard TT kit was designed using factory cast iron manifolds, but Jeremy decided to put ARH Shorties to the test for a back to back comparison. While it would seem logical that the headers would increase power by spooling the turbo more efficiently, Jeremy was shocked with the performance results. Without any other changes, the Gen 5 picked up +38RWHP / +74RWTQ at peak! Gains throughout the RPM range were even greater where HP increased by 70 between 4000-5000. There was absolutely no change to the tune in back to back testing. As a direct replacement for the manifolds, the swap was quick and easy. The results were no surprise to the ARH team. The best part is that ARH Shorties are made using the highest quality 304 S/S allowing them to withstand high boost applications. They are also 50 State Legal.
PowerFab’s Build Info: 2012 Camaro SS Stock LS3 w/ cam only Stock TR6060 w/ Monster Clutch LT1 triple disc clutch Squash Performance twin pump fuel basket w/ dual E85 pumps Brown & Miller Racing Solutions fuel plumbing/fittings PowerFab Automotive 6266 Twin Turbo Package American Racing 5th Gen Camaro Shorty Headers E85 fuel @ 10psi of boost ARH Shorty Headers VS Stock Manifolds: ARH Shorty Headers (Isolator plugs and hardware included with purchase) Stock Manifolds Dyno Results: RunFile_002(Blue): Stock Manifolds RunFile_008(Red): ARH Shorty Headers +38HP/+74TQ! NO RETUNING OR OTHER CHANGES! Quote from Jeremy- “With the gains we’ve seen using the ARH Shorties vs. cast factory manifolds, we'll easily take the 1000RWHP stock bottom end record. It’s just a matter of time!” - Jeremy Cozad PowerFab Automotive |
07-29-2014, 08:32 PM | #2 |
Drives: 2013 Camaro 2SS RS 1LE IMO Turbo Join Date: Jan 2011
How much for a set of those?
And will that set fit wit the Turbonetics kit for LS3 I currently have JBA catless mid pipes and stock manifold |
07-29-2014, 08:35 PM | #3 |
Drives: ‘13 1LE Join Date: Jul 2013
I love those torque increase figures
Thank you for bringing this to the table. Man I miss turbo'ing.. |
07-29-2014, 11:32 PM | #4 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
I've always thought that the exhaust before the turbo's doesn't matter that much. Interesting.
07-29-2014, 11:41 PM | #5 |
Drives: 2010 2SS/RS Join Date: Jan 2013
Size of primaries?
07-30-2014, 12:17 AM | #6 | |
08-01-2014, 05:37 PM | #7 | ||||
08-01-2014, 05:42 PM | #8 |
Will they fit the Turbonetics kit?
08-01-2014, 05:46 PM | #9 |
Drives: 2014 SS Join Date: Jan 2011
I can vouch for this, while we didn't do a side by side comparison they easily supported Bull's 1280 rwhp in his 5th Gen SNL Performance built. The car made over 1,000 rwhp on 20 psi and pump gas/meth.
These headers are a fantastic addition to those doing turbo kits, great job ARH! |
08-01-2014, 06:02 PM | #10 |
Too bad they were in stock for the baller twin charged zl1. Had to go with another brand.
Nick
Corvette Z06 -1200ish rwhp |
08-04-2014, 07:25 PM | #11 |
08-04-2014, 07:27 PM | #12 | |
Yes, the Turbonetics kit uses stock manifolds.
08-05-2014, 12:20 AM | #13 |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
These are direct replacements for stock manifolds, so as long as whatever turbo kit you're running is currently bolted to stock manifolds they will bolt right in place without any issue.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
08-05-2014, 12:32 AM | #14 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
That's awesome gains but I'm not buying the no retune needed. anything that is adding power is going to need to be accounted for
