Old 01-17-2012, 07:00 PM   #1
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
"tuned" MAF
just curious if this is something that is legit or a rip off. there are no numbers to justify the $180 price tag so it makes me skeptical. is our OEM something that Vince already "tunes" to adjust our AFR? just thought i'd throw this out there since i don't recall there being any discussion about it yet.
http://www.granatellimotorsports.com...ng-2336-0.html
hapisok is offline   Reply With Quote
Old 01-17-2012, 07:43 PM   #2
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Don't believe this this is applicable to to the V6. On the V8's, GM had two contractor's to provide MAF's.
It was found one supplier's wasn't as sensitive and provide as strong a signal for throttle changes, etc..
Only effected the LS3, L99's. You wanted one with a code including a "letter" followed by a #, like 'K18'. If it was just a letter- 'V' or such, it was weak and could effect performance, even though it met GM specifications.
I replaced one on a friend's L99 after some mods. Haven't talked to him yet about results.
No cross-over to the LLT or LFX to my knowledge.
Bought mine from a Chevy dealer for $80 + tax. I see Mr. Granatelli's is a K13, but seems to be charging a bit more...
Old 01-17-2012, 08:24 PM   #3
hapisok
hapisok's Avatar
wow...
but if your running a 1LT...then why did you purchase one if it only effected the LS3 & L99?
Old 01-17-2012, 08:43 PM   #4
Ventmaster
Ventmaster's Avatar
You're speed reading Hapi- slow down..
Its been suggested that Granatelli's may be "re-badging" more that one GM product. With aftermarket car parts, its always buyer-beware (or aware, or is it wary?) Or "a fool and his money... "
Old 01-17-2012, 08:55 PM   #5
hapisok
hapisok's Avatar
haha...ROFLMAO (literally)
yeah, i see how that could be mistaken for buying Granatelli's...my bad. i was just referencing your purchase in general. so did you just upgrade your MAF according to the XYZ123 based on the "better" supplier according to the results from the V8 guys because yours was labeled with a V (or such)?
Old 01-17-2012, 10:45 PM   #6
Ventmaster
Ventmaster's Avatar
Exactly, apparently it was Vararam that intially discovered the difference between the MAF makers.
Seems either sensor is O.K., but when you start making mods- like a Vararam CAI, one is better than another.
I'd put a catback and CAI on for my friend and saw the MAF was weak. Figured I'd cover all the bases to get the most bang for the buck (want him to think I'm a great mechanic!).
But I believe its just a V8 thing...
Old 01-18-2012, 05:32 AM   #7
hapisok
hapisok's Avatar
...i kid i kid!
sounds good enough to me. thanks for the info, thats the first i've heard about the MAF's though..."its a Vararam thing, i wouldn't understand"...
Old 01-18-2012, 08:59 AM   #8
bmorecam
it's the same exact thing as a $2 dollars resistor mod. It's basically tricking your IAT to see temp preset such as 20F in the middle of summer. It actually used to do wonders I heard back in the days. Not so much for today's ecm.
Issue SOLVED strong MAF. daveagogo1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 131 07-17-2014 08:19 AM
Good MAF vs. Bad MAF..the Dyno Test @ MarylandSpeed MarylandSpeed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 22 06-15-2012 10:41 AM
Air "Release" Sound After CAI / MAF Change ArmoSS Tuning / Diagnostics -- engine and transmission 7 08-16-2011 07:06 AM
Cold Air Intake & Maf Scaling nyny69 Tuning / Diagnostics -- engine and transmission 3 09-09-2010 07:34 AM
Halltech Yellow Jacket – oil substance around MAF information caverman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 06-29-2010 01:51 PM
