10-30-2011, 07:41 PM | #1 |
Drives: RY 2011 2SS A6 Join Date: Jul 2010
Datalogging helps improve launch
I've been playing around with my SCT tuner and discovered that it is a very useful device for analyzing my launch skills - far more useful than a timeslip from a drag strip or iPhone app or even a video of a particular launch, because the data is coming from the car itself. For those of you who have ever datalogged your car (and it can be a pain to get set up), you'll notice that the log is actually a csv file (a spreadsheet) where each row is a timestamped snapshot of engine parameters. I logged speed as well when i did my data logging, which is recorded in kilometers. (96.5 km/h = 60 miles/hour). I did a bunch of test runs and put them into the chart below.
Pretty cool, huh? You get EXTREMELY precise timing on how long it took you to hit any particular speed. In the runs below, I twice tried just flooring it - that's the red and blue lines. You can see that right at the 0.5 second mark the wheels started to slip and I had zero acceleration progress just about 1/2 a second. TC kicked in around 1.0 sec, the tires grab, and then the car accelerates again. Both red and blue lines show a 0-60mph run at about 4.85 seconds. After that, I tried NOT mashing the gas but giving it gas in a more controlled fashion. That's the green line. No wheel spin but turns into about a 5.3 second 0-60 time. Yuck. Clearly the best launch is in between - hit the gas hard but not all the way to the floor in the first 1/2 second. I guess this is what people talk about with "rolling on" the gas. To me it is really useful to be able to see it for actual runs I did so I can diagnose what I'm doing wrong and improve my launch. Takes practice, I guess. Anyhow, just thought this was pretty cool. For any of you with tuners and laptops, you can self-diagnose your own launches better than other way. Sure beats scratching your head looking at a 60 foot time and and wondering why it sucks . No more guessing or futzing around with my iPhone app and wondering if it's accurate or not. |
10-30-2011, 07:48 PM | #2 |
I like teeth.
Drives: #198 Join Date: Oct 2009
looks really cool! Good job! Now you need to get that 0 to 60 time down
10-30-2011, 07:55 PM | #3 | |
Other than doing a better job launching, the chart seems to say to me there's not much else I could be doing as a driver... |
10-30-2011, 08:17 PM | #4 | |
I like teeth.
1) Some nice axis labels! 2) If there was a way to put rpms on the left side and show that concurrently on the graph, it could show where you shift and how long it took you to shift. Also, people much more knowledgeable than I could comment on where exactly to shift or help you out even more! Even if the above two are not possible I still really like your chart and wish I had the time to install a datalogger on mine. The concept is very intriguing to me so that I could learn my 0 to 60 times and maybe help me get better at launching! |
10-30-2011, 08:26 PM | #5 | |
I can do rpms alongside a single run - can't do multiple on the same chart of course. But nice suggestion. Let me cook something up...
Dry sump LS7, cage, JPSS suspension, Wilwood brakes, fire suppression, ARH 3" headers/exhaust, Z/28 DSSV coilovers, Kirkey seats, TeamTech 6-point harnesses, 19" Forgeline GA3R, 325/30R19 Re11 tires, oil cooler, monster JPSS splitter/wickerbill, CAI, brake ducts. |
10-30-2011, 08:31 PM | #6 |
I Wanna Go Faster!!
Drives: 2011 2SS Synergy Green M6 Join Date: Apr 2011
So "datalogging" has taught you that in order to have a better launch you need to spin less......
That's genius. |
10-30-2011, 08:43 PM | #7 |
I guess you must be a pro and know exactly what to do to get an amazing 0-60. Good stuff. For me, being able to SEE where the problem is, and see the impact it is having vs. what is possible, is pretty useful.
10-30-2011, 08:47 PM | #8 |
Here's another plot with RPM and speed, just off one WOT run.
Boy, TC really kills the engine.
10-30-2011, 10:21 PM | #9 |
Very good information...Is the T/C is killing your RPMs or the tires grabbing after spinning? Would be good to have a comparison of the RPM chart with and with out T/C.....
10-30-2011, 11:24 PM | #10 |
TRI COUNTY TAMPA
Drives: 2011 1SS/RS VR/BLK A6 Join Date: Jan 2011
I have not done anything like this but, it basically just confirms yet again what we have learned from the track over the years. Simply mashing the gas is never the best way to get your best 0-60 or overall time. For the best time on the track shut all the nannies off. Stall it at about 1200 or so. Varies by track condition and such. Let off brake, roll into throttle fluidly and continue to the floor as your moving. Mashing it equals tire spin and wheel hop.
10-30-2011, 11:58 PM | #11 | |
I like teeth.
I do research at my university so we have to plot graphs that tell 20 different stories if you take the time to read them all. Never can have too clustered graph lmao jk jk But your graph above does look very good! Just a quick question, why is there a lull in both lines from 0.75 to 1.2 seconds? Like the lines seem to be going straight across which would actually indicate no acceleration and thus no speed change... ?? |
10-31-2011, 05:59 AM | #12 | |
Having tried WOT with TC off a while back (did not log it) the back end breaks loose and you just roast the tires until you lift up. So at this point it does become a question of skill; using either TC or not, can you get the pedal in the right position to keep the tires turning but not spinning? Based on what I see, I am going to try a full split second mash of the pedal and then lift off a bit and then mash again once clear of the 2600 rpm dead zone.
10-31-2011, 06:01 AM | #13 |
You're right. Tire spin = no acceleration. That run was at WOT and TC seems to cut the engine pretty fast to restore traction.
10-31-2011, 12:49 PM | #14 |
I like teeth.
Similar Threads | ||||
Some Helpful Tips for Drag Racing | The Stig | Dragstrip and Launch Techniques Discussion | 9 | 07-31-2017 09:11 AM |
Best way to launch an SS M6? | SS>GT | Dragstrip and Launch Techniques Discussion | 4 | 10-06-2011 04:46 PM |
Launch Control Tech | Scarrzz | Camaro ZL1 Forum - ZL1 Specific Topics | 48 | 06-11-2011 08:06 PM |
Does suspension (trailing arms, and sway bar) make a difference in launch RPM? | Jason@JacFab | Dragstrip and Launch Techniques Discussion | 1 | 05-24-2011 04:04 PM |
PRESS RELEASE: Official Launch of BidMotors.com | BidMotors | 5th Gen Camaro SS LS LT General Discussions | 1 | 11-22-2010 12:00 PM |
