01-23-2012, 03:41 PM | #1 |
Drives: black camaro orange stripe 2ls Join Date: Dec 2011
anybody have a hypertech tune?
i was at autozone and saw a hypertech performance tuner. i wanted to see if anybody had it or if its worth buying? and can you feel the difference in hp gains?
01-23-2012, 03:45 PM | #2 |
Drives: White M6 1LT RS Join Date: Mar 2010
Trifecta is what most have on here. More support and custom tunes.
I definitely felt a improvement with Trifecta.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done! |
01-23-2012, 03:46 PM | #3 |
idk i was thinkin bout trifecta and think the datalogging would be a pain in the ass
01-23-2012, 04:06 PM | #4 |
Drives: 2011 LS Join Date: Oct 2010
not telling you to not buy hypertech, but data logging for trifecta is a piece of cake if you have a laptop. It also gives you a tune more dialed into your car specifically. Most have Trifecta because it was all that was offered for quite some time, but I havn't heard anyone complain after getting it.
01-23-2012, 04:26 PM | #5 |
How easy is the datalogging? And how often do u have to keep doing it?
01-23-2012, 04:51 PM | #6 |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
Just plug the cable into your laptop, open the Trifect app, start the logging tool and make some short runs. You'll probably want to do one normal driving for about 2 minutes, one WOT pull up to the speed limit and maybe one cruising on the highway. Until you change mods that should be all you have to do. It is a really simple process.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
01-23-2012, 05:06 PM | #7 |
its nice if you have a automatic bc you can change your shift firmess and limiter settings. I would have gone trifecta but it wasnt $300 bucks at the time.
Performance: Huron Speed Single Turbo Kit- Turbonetics T76- Stainless Works Retro Chambered Catback - Ported Throttle Body - Dyno Tune - DSS One Piece Aluminum Driveshaft - BMR 1.4" Lowering Springs -TSP 235/239 Lumpy Stick- Aeromotive A1000 Return Fuel System
Cosmetics: Heritage Grill - LED Dome/License Plate/and Fog Lights -8000K HID Headlight - BMR 4 Point Strut Tower Brace - Forgestar Wheels Audio: Scosche Dash Kit - Kenwood DNX6990HD w/Nav - Prefabbed Ported Box with 1 12" Alpine Type R - Alpine PDX M12 Amp |
01-23-2012, 05:29 PM | #8 |
67 GTO has it....apparently loves it
Formerly owner of:
2012 2SS/RS Build Thread - Totaled by red light runner 2010 LT/RS Build Thread - Traded in for 2012 2SS 2007 Acura TSX 1992 Oldsmobile Achieva V6 1992 Mercury Sable |
01-23-2012, 05:44 PM | #9 |
Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
Trifecta is great. The datalogging is easy and Vince has great customer service as well.
Also, last time i checked, trifecta gives more power than hypertech. I understand why people would like a handheld tuner but to be honest, I got mine tuned and haven't asked for anything to be tweaked or adjusted in about 3 months. |
01-23-2012, 05:54 PM | #10 |
13.453 @ 101.90
Drives: 2010 Camaro 2LT Rally Yellow Join Date: May 2009
Yea, I'm ok with it. No complaints.
GMPP exhaust/JBA shorties/Vararam CAI/VMax TB/SLP Pulley/VMax IM isolator/MACE Ported IM +Plenum Spacer/IPF Tuned |
01-23-2012, 06:44 PM | #11 |
you just datalog one time and your done?
01-23-2012, 06:54 PM | #12 |
Correct, until you get another mod if you wish or if you feel anything is off with your car but Vince is pretty good at getting it right with all the basic mods. Another thing to consider is that I don't believe hypertech can remove the speed limiter. I saw you were an ls like me and ours come limited at 118 because of our tires. You can remove it when you get when you get tires that are better rated. Not that you'll be going that fast... Just a thought
01-23-2012, 06:54 PM | #13 |
Drives: 2018 Camaro SS 1LE, 2019 Camaro 2.0 Join Date: Sep 2011
You do not HAVE to data log if you don't want to. The hypertech tune is NOT a custom tune. The fuel trim corrections, if any, are static. The timing advance is static. Nothing really changes past what they did on their initial tunes, other than a few user-selectable parameters. With Trifecta, it's a fully custom tune done to your specific car. You may have better gas than someone living is California or something and be able to run more timing, etc. not all cars/situations are created equal, so why would the tune be?
Plus with trifecta, we adjust for your mods now AND later. If you get headers, just let us know, well adjust the tune at no cost. You data log as much as we need you to at first. Usually 1-3 times, to get the tune dialed in. After that, you just need to do it again if you change something on the car. We also adjust the transmission to your liking and will change it down the road if you want firmer or less firm shifts later on. Order here- www.badnewsracing.net/webstore |
01-23-2012, 07:28 PM | #14 |
^^^^ This.
Also, that reminds me. I believe the hypertech can't turn the cel off. Trifecta can and this is relevant because if you get long tube headers you won't want the cel on. Trifecta can remove the CEL as well as tune for free for any additional mods that aren't forced induction or e85. |
Similar Threads | ||||
MarylandSpeed DYNO TESTED: Diablosport Predator Canned Tune on 2010 SS A6 | MarylandSpeed | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 27 | 05-18-2013 10:01 PM |
Camaro SCT tune Vs HP TUNERS tune by Tampa Tuning | Tampa Tuning | Tuning / Diagnostics -- engine and transmission | 21 | 02-08-2012 07:06 AM |
Traficta tune or hypertech | BloodUSMC | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 15 | 10-09-2011 11:01 AM |
Test and Tune - Nov & Dec (Weather Permitting) | thesnoopster | USA - Mid-Atlantic | 17 | 11-21-2010 04:49 PM |
Standard vs Automatic Racing | HarrisraTx | Dragstrip and Launch Techniques Discussion | 74 | 10-29-2010 09:26 PM |
