09-03-2013, 10:45 AM | #1 |
Drives: 2013 Camaro ZL1 Join Date: Aug 2010
Vredestein Ultrac Sessanta
Alright - based on the comments on my previous post - I'm going to buy a different set of tires. It seems like most people really like the Michelin PSS but I wanted to see if anyone has any comments about the Ultrac Sessanta tire. It seems like a good option to replace the F1's. What do you guys and gals think??
2013 Camaro ZL1
“If everything seems under control, you're not going fast enough.” |
09-03-2013, 10:48 AM | #2 |
ZLT!!! COTW (8/5/13)
Drives: 2011 IOM 1LT RS M6 Join Date: Mar 2012
Handle is very good! Dry or wet, snow don't know yet... noise very low... Look! AWESOME!!!
09-03-2013, 12:34 PM | #3 |
Drives: 2013 ZL1 Join Date: Jun 2013
How much a set?
09-03-2013, 01:10 PM | #4 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
Ultrac Sessanta
Looks the biggest they come is 295/25/20 ... Those should go up in smoke rather easy, but you could stretch the rears for a more of a square setup like the 1LE. They run around $315 each for the 295/25/20. Myself I need to replace also, and think I'm going to give Invo's a try a see how long they last. I plan on 295/35/20 front and 315/35/20 rear ...
09-03-2013, 01:40 PM | #5 | |
I think you can get them in a 315 too.
http://ohio-speed.com/p-1420-vredest...-31535r20.aspx Quote:
2013 Camaro ZL1
09-03-2013, 01:42 PM | #6 |
2013 Camaro ZL1
09-03-2013, 06:54 PM | #7 |
700RWHP-650TQ
Drives: 2011 Forged LS3 Supercharged/Cammed Join Date: Aug 2010
Get ahold of Jim at Ohio Speed. He has special pricing for C5 members. I got my tires for quite a bit cheaper then the price listed above for each tire.
I run the 315/35/20s and they are awesome. Always grips, no spinning, quiet, looks nasty, and great tread wear. Im currently 502RWHP with zero issues. Love these tires.
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL |
09-04-2013, 09:43 AM | #8 | |
What size do you use on the front with this tire?
2013 Camaro ZL1
09-04-2013, 11:11 AM | #9 |
Ragtop Rocket!!!
Drives: Black on Black Convertible Join Date: Mar 2013
Are these all season tires? I'm starting to look for a set for the fall and winter because I am not planning on storing the car for the winter.
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package. 744rwhp 727rwtq |
09-04-2013, 12:00 PM | #10 |
700RWHP-650TQ
