07-02-2023, 12:50 PM | #1 |
Drives: 2017 Nightfall Grey 2SS 6 Speed Join Date: Jan 2022
BTR 220 Cam?
Hello everyone, I recently found a tuner near me that seems to know what they are doing with these cars. I got my 6 speed manual bolt on car tuned. Car put down 462whp and 495 lb-ft of torque on e85, on a dynojet. Was quoted $4800 for a cam install I believe that includes parts too. May want to go cammed in the future I was talking to the tuner and he recommends the BTR 220 cam for my goals. I am looking for a stout n/a cam setup that drives like factory, that will chop, and make some nice power with reliability and longevity in mind. I live in a small city so i do drive the car in traffic. I would like something that would work with a supercharger if i decided to boost it. He says this cam works good with a pro-charger, (leaning more towards procharger, but possibly a positive displacement supercharger) I am wondering if anyone has experience with this cam, and what kind of supporting mods I would need with it? I am looking for a second opinion so i know what to expect before I talk more with the tuner on it. Also what kind of gains can i expect? Hoping not to lose any torque. Thank you for any help.
Current mods are: Roto-Fab, LT Headers, Hi-Flow Cats, Borla Atak Catback (NPP), Flex Fuel, Mishimoto Catch Can Last edited by Banshee.2SS; 07-02-2023 at 01:30 PM. |
07-02-2023, 06:20 PM | #2 |
The Mechanic
Drives: 1SS M Join Date: Dec 2017
I just did a btr 225. Tuning isn't finished yet but it definitely chops. The btr cams have more lift then most mild cams for this engine but they have next to no bounce so the valve train should last.
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
07-04-2023, 06:07 PM | #3 |
OK good to know, I don't see a lot of videos on the BTR 220 cam. I see a lot of videos on their "stage 2" cam is this the 220? what kind of supporting mods should I look for with a cam swap like this?
07-05-2023, 06:53 AM | #4 |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, AWE Touring, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
07-07-2023, 09:42 AM | #5 |
The Mechanic
I think the staged cams where before the spintron series with the 220 225. They're older. They sell the cam packages with the stuff you will need springs, lifters etc
07-07-2023, 10:47 AM | #6 | ||
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
I have the JRE Terminator cam (similar specs) to the BTR 220. Video clip below with idle audio... Supporting mods I would consider, while to motor is out... (none required) 1. Katech or TSP VVT delete front cover 2. Katech or TSP DoD delete valley cover 3. Katech C5R chain 4. LME Dogbone chain guide 5. ATI balancer 6. Porting your stock heads 7. BMR motor mounts
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
07-07-2023, 06:19 PM | #7 |
Drives: like an old lady Join Date: Jun 2012
if you go with a btr 220 cam, id simply ask them what upgrades they recommend
from a power standpoint, at minimum id do msd / LT2 intake manifold 103 / 95 mm throttle body ati damper ported heads LT4 low side, high side & injectors i think only the cam youd see 50-60 whp with the stuff i mentioned 90-100 whp the stock LT1 intake manifold is terrible. at least do something in that respect
2016+ camaro: everyone’s first car
07-08-2023, 10:09 AM | #8 |
Drives: 2022 camaro SS 1LE Join Date: Jan 2023
So i went with btr 220 cus i have a 2022 1LE with an A10 and stock stall and i daily it. But i think im goin to go with a circle D 2600-2800 stall and get the trans tuned. Car idles great still gets round 20 mpg round town higher on freeway, an made over 530 whp with cam only fbo and 93 octane. They are adding E85 to a station near me so gettin tuned for that soon. Im debating on adding ported heads have a set done an ready were months out when i got the cam so couldnt wait. Just sucks cus its running sooooooo good i dont know if itll be worth it haha. But for me here is what im running
Kooks headers, high flow cats MSD manifold unported Katech 103mm tb Katech C5R timing chain Katech oil pump LME timing chain guide Morel lifters Btr platnium springa with titanium retainers Btr push rods Rotofab intake Tuned on dyno Tryin to justify 1800 more to get the heada an put them in i just dont know if itll make a noticable difference. |
07-08-2023, 05:12 PM | #9 | |
Drives: 2020 SS 1LE Join Date: Jan 2023
07-08-2023, 05:39 PM | #10 |
Well picked up the heads today so goin to do it tonight an tomorrow. E85 will be in a few weeks.
07-08-2023, 05:44 PM | #11 |
Drives: 6th gen Join Date: Aug 2013
Can you post a video of the Btr 220 idle?
‘22 2SS 1LE M6 Summit White - RF, Flexfuel, LT2 intake, 95mm tb, ATI udp, VT ramair, full 28” dragpack - 11.68@122
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) |
07-08-2023, 07:30 PM | #12 |
Heres a before an after of the heads goin in today an tomorrow had to hunt down a 1/2" allen head for that one dumb bolt in the drivers head
07-09-2023, 04:26 PM | #13 |
Well almost done taking a break before puttin on the drivers side head. The passanger is on an everything is all reassembled on that side. Just have to remove and install drivers side. Wasnt to bad pretty easy.
07-09-2023, 06:02 PM | #14 |
Were these OEM heads that were already done with a core exchange? That turn around is crazy otherwise lol
Tags |
btr 220 cam, cam, cam install |
