Old 03-16-2010, 04:35 PM   #1
treedoc2000
Drives: 2010 camaro SS
Need longer wheel studs--need help!!!
I bought some aftermarket wheels for Camaro SS A6. The back rims don't clear the brakes, so I bought a 1/4 inch spacer and the wheels now clear the brakes barely. Now the problem is when installing the lug nuts they only turn about 2 turns then get tight. Is this enough thread to be safe or should I get longer bolts put on? I've called around looking for longer studs and can't locate any, does anyone know where I can find some? JEGS says they have longer studs but they need to know the knurrel diameter. No one knows what that is, Chevy house is clueless. Need help desperately, any ideas would be greatly appreciated.
treedoc2000 is offline   Reply With Quote
Old 03-16-2010, 04:37 PM   #2
Coop 2010
Delivered 05/20/2009
Coop 2010's Avatar
Drives: Black 2010 2SS RS
Two turns is not enough, just think of the lateral stress on that stud and its threads.
Coop 2010 is offline   Reply With Quote
Old 03-16-2010, 05:34 PM   #3
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '17 Corvette Z51 Coupe
I have done this many times in teh past, but not on one of our new camaros....as I will NEVER use a wheel spacer, but to put new studs in for ANY reasoe, its the same process given the information you have given us to work with.
1. NO, 2 threads are NOT ENOUGH, either a lug or worse yet a WHEEL will come off, and if your are lucky, you won't be moving when it does.
2. Take a wheel off. look at the stud. Take a measurement of the diameter of the stud, right that down. then count how many threads it would take to go that distance ( the diameter). thats how many threads you need as a MINIMUM to have full streangth.
3. The only way you can find out the TRUE knurrel diameter is to press out one of the studs on the hub, and measure it with a caliper or micrometer so you can buy the correct size so that when they are pressed in, they will be tight.
Old 03-16-2010, 06:20 PM   #4
rayhawk
rayhawk's Avatar
Drives: Trailblazer SS
Unfortunately, you will have to press a stud out to know for sure. Dorman has a pretty wide selection, search around their site for something appropriate. Oh, and the stud you press out will have been deformed during installation, so go a few thousandths larger on the replacement stud to ensure a tight fit. Check the hole size too and make sure it matches the manufacturer's recommendation.
http://www.dormanproducts.com/catalo...ec10_Part3.pdf
Hooters, hooters, yum yum yum, hooters, hooters on a girl thats dumb.
-Al Bundy
07 2WD Trailblazer SS, LS1 E-fans, 4" FWI, pcmforless tune
rayhawk is offline   Reply With Quote
Old 03-16-2010, 07:16 PM   #5
jputer
jputer's Avatar
Drives: 2016 1LT Garnet Red
The GM part number for the stock rear wheel stud is 11588811. Get one from your dealer and head to the closest NAPA store or speed shop for longer studs.
I found these specs in the BIW catalog
11588811 5.812 STUD, FRT WHL (PART OF 10) (M14X1.5X24, 58 TOTAL LENGTH)
2011 1LT/RS Summit White A6
jputer is offline   Reply With Quote
Old 03-16-2010, 07:52 PM   #6
oneinch
oneinch's Avatar
Drives: 2002 Ford F150 4WD
jputer has the best advise. In the long run it's easiest to buy a new stud for you to reference against. You can get what you need and not have any downtime.
oneinch is offline   Reply With Quote
Old 03-16-2010, 07:56 PM   #7
Taz_FL
Taz_FL's Avatar
Drives: 1LT/RS Yellow/Black
actually you want one and a half times the diameter in threads for maximum strength. In other words, if its a 1/2" stud you want to have 3/4" of thread, anything more is a waste as far as strength goes.
Taz_FL is offline   Reply With Quote
Old 03-16-2010, 07:58 PM   #8
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
really deep well lug nuts?
I piss excellence
and fart awesomeness
Old 03-16-2010, 08:02 PM   #9
iPODFAN11
iPODFAN11's Avatar
Drives: 2012 1SS
When you bought the rims, did you make sure they were properly measured for the car? i.e. proper backspacing, etc?
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
Old 03-16-2010, 08:57 PM   #10
Mark-HD
Mark-HD's Avatar
Drives: 2010 Inferno Orange SS
Why not just avoid the hassle and buy a set of wheels adapters that bolt to your hub using stock studs and they have their own studs for mounting your wheels. There are several pictures of them on the forum....
2010 Camaro SS, M6, MTI shifter and sway bars, GM quarter flares, Corsa catback, Roto-Fab CAI, 30% tinted windows, Lloyd's custom mats, Hawk ceramic pads, Pedders lower coils, Magnuson supercharger with 3.6 pulley, BMR trailing arms & toe rods, Kook's LT's1 7/8 w/cats, Lingenfelter/SLP billet pedals, KW V'3 Coilovers, RevExtreme catch can, ---Ordered--- IconZ LS7 9 & 11" polished wheels!. Dyno'd 563.05 HP, 543.86 Torq.
Mark-HD is offline   Reply With Quote
Old 03-16-2010, 09:00 PM   #11
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
Obviously not......
But anyhow the stock studs are 14mm 1.5mm pitch if that helps.
I wouldn't deviate from that size.
two_wheel_mayhem is offline   Reply With Quote
Old 03-17-2010, 02:03 AM   #12
treedoc2000
The company said they would "fit" the new camaro.... They told me that out of 14 sets sold, Only two said they needed a spacer to clear brakes. Uhh I guess Im the number three
Old 03-17-2010, 02:08 AM   #13
treedoc2000
Thanks for the good Ideas! Of course the chevrolet house does not have any in stock. I like the idea of the spacer that has the studs built in -----BUT is this gonna be strong enough??? anyone use one of these yet. Not that its a super high HP car but its puttin out somewhere in the range of 550 and I dont want to take a big risk. Any other thoughts welcome
Old 03-17-2010, 02:14 AM   #14
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Since this is KNOWN issue with these wheels, return them for a different set.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Tires loosing pressure joepitt Wheels and Tires Talk Sponsored by The Tire Rack 22 12-11-2010 06:00 PM
POWDER COATED WHEEL EXCHANGE PROGRAM !! L@@k !! ProdigyCoatings Wheels / Tires 8 01-31-2010 10:17 AM
Possible wheel defect Chacho Wheels and Tires Talk Sponsored by The Tire Rack 9 01-11-2010 03:55 PM
Steering wheel leather cracking!! meliss7567 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 09-17-2009 03:13 PM
