Old 01-18-2014, 07:21 PM   #1
jkof08
jkof08's Avatar
Drives: Black 2SS/RS
Bolt on L99 12.557 @ 112.40 doesn't feel quite right need help
today was a DA of -600 i ran a 12.5 and i should be low 12's high 11's. i launched in this particular instance at 1200 RPM. when i launch i stall up hold it and on the last yellow slam it to the floor i launch from Idle, 800-900, 1000, 1500, 1600, and 2000. all with consistent 12.6's with 1.9 and 1.8 60' the time slips all look similar to this one. take a look and let me know what you think. most of my buddies seem to think its the tune. i data logged and will be sending it to TED Jannetty monday, but in the mean time is there any advice out there. i warmed up my Drag radials until i saw smoke. traction was not an issue, at least id did not feel like i was spinning. and the guys standing there said i didnt spin. Tire pressure was at 18 psi after a run it would go up to 19 psi.
MODS
Hennessey CAI (I know it sucks but I like it)
JRE Scoop
MSD Wires
Stainless Works LT Headers
Stainless works Hi Flow Cats
Stock H Pipe & resonator
Flow Master Pro Series axel back exhaust
Lingenfelter 3.70 gears
Pro Torque 3500 Stall
8 pass Transmission cooler
SCT programmer
Jannetty Ported Throttle Body
Jannetty Tune
Driveshaft Loop
1LE Strut Tower Brace
Forgestar F14’s 18x10
Mickey Thompson 305/45/18 Street ET II’s
front 21x8.5 and street tires
C.A.I. CAI, FlowMaster Pro Series, 1LE Strut Brace, Ported Throttle Body, Vengeance Tune, JRE Scoop, MSD Wires, 3.70 Gears, Stainless Works LT Headers and Hi Flow Cats, Pro Torque 3500 stall, LS3 Conversion Stage 2 TSP Port & Polished Heads, Kaotik CAM. 18x10 Forgestar F14 wrapped in 305/45/18 MT Street ET II's
12.068 @ 119.9 1.9 60ft (on 20' DR's with a VVT CAM)
jkof08 is offline   Reply With Quote
Old 01-18-2014, 07:28 PM   #2
Supercharged SS
Drives: 2010 Camaro
MODS
JRE Scoop
MSD Wires
SCT programmer
Jannetty Tune
Driveshaft Loop
Your 60' sucks. No other way to put it. With those gears, stall, and drag radials you should be in the 1.6's. No worse than 1.7. You must bogging at the line. The log will tell the tale. Any video?
Could also be a tune issue or problem with the car. You should be able to check your log and see what the pids show.
The mph is about right for those mods but a 1.68 60' would get you around 12.1. With your mods you're all about the 60' bc you don't have much power.
At least you know where the issue is.
Old 01-18-2014, 07:34 PM   #3
jkof08
jkof08's Avatar
there is a video i would have to get it from my friend, and im not sure what i would be looking for in the PIDs. but how do u launch?
Old 01-18-2014, 07:40 PM   #4
Supercharged SS
Drives: 2010 Camaro
With your power level you should stall that bitch up to 3500 if the car will hold. If it pushes just keep lowering the rpm until it holds. You need to leave as hot as possible. If the track is decent and you're burnout is good it will hook.
Right now your achieving 60' of a bolt on car with stock tires. You need to utilize that stall and gear.
I'm not sure what pids you are logging but some that are useful are rpm and mph. Together you can see any wheel slippage, shift points, tranny issues, lots of things.
Old 01-18-2014, 07:49 PM   #5
jkof08
jkof08's Avatar
i tried pre loading it as high as it would go a few weeks ago and any more than 2500 would push me across the line. so launching at 2400 only got me 13 flat dead hooking. people on the forum told me to launch from idle or 1000. i also talked with ted and he suggested launching at 1500.
Old 01-18-2014, 07:55 PM   #6
Supercharged SS
Drives: 2010 Camaro
No one can really tell you how to launch. You'll need to poke around and see what works. Theoretically if you can hook the car the higher the rpm the better. You can flash it, which is just hanging at or just above idle and mashing it or stall the balls off it. 2400 seems low for a 3500 stall to push the car. I'm guessing pro torque converter.
Bottom line is something is happening at the launch. You'll only get some brainstorming here so interpret the logs, correct the issue, and try it again.
Old 01-18-2014, 08:00 PM   #7
jkof08
jkof08's Avatar
ya its a pro torque from JRE performance are those crappy? but when i launched at higher RPM it just seemed slower. ive talked with several guys with less than me mod wise and they r in the 11's launching from idle, 800, and 1200.
Old 01-18-2014, 08:07 PM   #8
Supercharged SS
Drives: 2010 Camaro
Nothing wrong with that converter. Prob not holding you back. Seems like that converter likes to be flashed not stalled up. I've always had success flashing from 1000-1100 with the pro torque. Other converters like different methods.
So time to look into what's happening when you leave the line. Logs and logs. Is the car falling on its face, etc.
Take some time and learn to read your logs. Then you'll know instantly what's going on and not have to rely on anyone else. They are very easy to read.
Old 01-18-2014, 08:08 PM   #9
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Lots of good info here. I had a 1.9 60 ft with just bolt ons, on a hot rainy day in Indy for c5 fest, on factory tires. That should tell you something.
Old 01-18-2014, 08:11 PM   #10
jkof08
jkof08's Avatar
im not sure what im looking for on there. i can read it bc it says rpm and vehicle speed but im not sure what to look for as far as if its bogging or what.
Old 01-18-2014, 08:17 PM   #11
Supercharged SS
Drives: 2010 Camaro
You'll need to follow the lines on the graph. Only open the mph and rpm pids to start. So you only check those two boxes on the left of the screen. On top you can expand the graph to make it easier to read. You want those lines to be as smooth as possible. Any bumps in those lines and something is going on. Depending on where the bump is you'll be able to narrow down the issue.
Ask Ted to go over them with you while your both in front of the graph. That's the best way to learn how to read it.
All I prob did is confuse the hell out of you.
Old 01-18-2014, 08:21 PM   #12
jkof08
jkof08's Avatar
lol no, but thanks for the help.
Old 01-18-2014, 08:29 PM   #13
Supercharged SS
Drives: 2010 Camaro
Ha! Don't sweat it. You'll get it figured out.
Old 01-18-2014, 10:17 PM   #14
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Gotta keep working at it. I almost went 11's last year but had traction issues...
I went 12.37@112 1.85 no converter, no gear.
I went 12.06@110 1.70 converter, stock gear. (best mph 113.5).
Best 60 1.66 but was spinning.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
