Old 06-30-2014, 12:31 PM   #1
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
Ridetech coilovers settings?
Anyone have any good settings to start off with. I just upgraded my lca and sways to 1le stuff and added ridetech coilovers. I know they say to start at 20 out from full stiff.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 06-30-2014, 01:13 PM   #2
954camaro
954camaro's Avatar
Drives: Camaro SS/RS inferno red interior
Wanna start out way stiffer or you will hear so weird noises like I did I made it 24 in the back and 23 up front I believe.
SoFlo Muscle Car Group
Miami/Broward
954camaro is offline   Reply With Quote
Old 06-30-2014, 02:30 PM   #3
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
You say stiffer? Your settings are softer.
Build Thread
Old 07-01-2014, 07:52 AM   #4
954camaro
954camaro's Avatar
My bad then it is opposite then. I have 16 in the back and then 17 up front.
Miami/Broward
Old 07-01-2014, 08:17 AM   #5
marolf101x
Drives: 2010 Test Mule
shock settings are a personal preference so I cannot tell you where to set them where you will love it. I like to start about 20-22 out and go for a drive. If I need to adjust I make a big change, 10 clicks maybe. Then drive again.
By making big adjustments you can really feel the change.
Skunk Werks
Ridetech
www.ridetech.com
marolf101x is offline   Reply With Quote
Old 07-01-2014, 10:44 AM   #6
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
I understand. I am actually waiting for alignment to get done so as I pick it up I will start out with ridetechs starting point of 20 out than adjust from there.
Build Thread
Old 05-12-2016, 12:54 AM   #7
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
im bumping this old thread. would like to know everyone's settings and how have these improved you ride quality?
JCunningham is offline   Reply With Quote
Old 05-12-2016, 01:40 AM   #8
Merc
In The Circle
Merc's Avatar
I'm starting at 20, But I have custom spring rates as suggested by JDP 350/550 for the strip. Ride Tech comes with 300/500 unless you specify the spring rates.
Old 05-13-2016, 12:15 PM   #9
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
I had the RideTechs on till winter, waiting (way too long)on their updated front end links.
I see you have the 1LE bars, so that is more similar to my combo too. Here is what I liked:
From soft> Front: 16
Rear: 25
I have the 275 front springs. That is what JDP spec'd in early 2015. They also spec'd the 550 rears, but RideTech drop shipped them with the 500 pounders. RideTech's customer support has been praised in the past, but frankley, their communication could get better.
Car did very well on the road course.
Ride quality is good, better than with the Z/28 springs/struts.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
cdb95z28 is offline   Reply With Quote
Old 05-13-2016, 09:59 PM   #10
FunkedOut
FunkedOut's Avatar
Drives: Black 2010 SS
Got mine from JDP, drop shipped from RideTech. Came with 275/500 springs and bearing top mounts for the struts. I have heavy bars from JPSS (27/32).
On the street, I've been riding 20/20 and it really eases the bumpy roads and feels about the same or a bit slower/stiffer than factory (I have a 2010). I'm gonna soften up the rear a bit more, although i know 24 is too soft for me.
On the track (road course), I found 4/10 to be the sweet spot. I think I want a 300 spring in the front.
FunkedOut is offline   Reply With Quote
Old 07-06-2016, 03:08 PM   #11
MarioSS
MarioSS's Avatar
Drives: 2010 Camaro SS (RS LS3)
Did the updated ridetech coilovers fix the clunking noises?
Sent from my SM-G935F using Tapatalk
MarioSS is offline   Reply With Quote
Old 07-15-2016, 04:07 AM   #12
FunkedOut
FunkedOut's Avatar
thanks for reminding me.
mine are totally quiet, except for the endlinks that makes a little noise. I read that they redesigned them and fixed that.
I need to call them for a swap.
their customer service is second to none; top notch.
Old 07-15-2016, 07:51 AM   #13
MarioSS
MarioSS's Avatar
Thanks for your reply man!
