10-22-2014, 08:55 PM | #1 |
Drives: '14 2SS/RS 1LE NPP, NAV, Recaros Join Date: Apr 2014
3rd Gear Lockout
When pushing my 1LE hard up through the gears (shifting above 5K), 3rd occasionally seems blocked out on 2nd to 3rd until the revs drop. Have made no mods to the car (not even Skip Shift override...yet).
Any ideas? Thanks!
If You're Not Having Fun, You're Not Doing It Right
10-22-2014, 09:55 PM | #2 | |
Drives: GM Vehicles Join Date: Jun 2010
Sorry to read of your transmission concerns. I understand the displeasure when dealing with a matter like this. Although you're seeking opinions from others, I'd be happy to communicate your concerns with the Customer Experience Managers (CEM) at your GM dealer of choice. Please know that you're welcome to message us privately if you would like to discuss this further, or if you simply want this matter documented. William R. Chevrolet Customer Care |
10-22-2014, 09:59 PM | #3 |
Thanks William. Wanted to see if anyone else had experienced this. Like I said, only happens when pushed very hard, and then only occasionally. I'll bring it up at my next service in a few weeks.
10-22-2014, 10:07 PM | #4 | |
And I certainly realize your desire to get feedback from the forum. Don't hesitate to keep us posted on this situation and know that we're here if additional assistance is needed in working with the dealer. , William R. Chevrolet Customer Care |
10-22-2014, 10:12 PM | #5 |
Drives: 1LE Join Date: Feb 2013
OP, I don't think I have experienced this. However, once, I "missed" third. By that, I mean I hit the spot between 1st and 3rd when trying to upshift quickly from 2nd at high RPMs. I knew exactly what I did, and I was able to catch it quick and not release the clutch peddle. I then did multiple hard runs being conscious of my earlier mistake and had no further problems.
Is there a chance that you are doing this too? Supposedly, the MGW shifter specifically addresses this common user error by increasing the spring rate so that it more strongly pulls the shifter to the 3rd gear gate when pulling out of 2nd. |
10-23-2014, 04:41 PM | #6 |
It happens a lot to me when I power shift my car on nitrous at the track. My problem is I was not shifting fast enough and it locks you out engine rpms die. That's the main reason I'm switching to automatic
Go Hard or Go Home
10-23-2014, 06:00 PM | #7 |
Drives: 14 ss 1le camaro Join Date: Mar 2014
these trans are tricky.. ive learned how to shift it just right and i have avoided all issues the 1le is known to have.. change your shifting patterns.. make sure you foot goes all the way down on clutch.. it takes some time.. and i have had mine in for a 1st 2nd gear sync replacement.. etc... now its like its supposed to be.. goodluck
2011 camaro L99 convert. totaled .
2014 camaro 2ss 1LE. blk on blk..stock |
10-23-2014, 08:21 PM | #8 | |
Drives: 2014 Camaro 2SS 1LE NPP Join Date: Nov 2013
What exactly is the "tricky" part of these transmissions? Your foot should go "all the way down" on all manuals. Last edited by Billy10mm; 10-25-2014 at 11:54 PM. |
10-25-2014, 08:41 AM | #9 |
LOL, OP, I did it again today.
If you go to pull a hard run, it is easy to miss third. As you pull up from second, if you don't allow the shifter to "spring" back to the center some (or you don't push it over manually), it is really easy to hit that spot between 1st and 3rd. Feels like a "lockout" or bind. Today, after being conscious of my error, I made no less than 20 full throttle runs up through 3rd. Smooth as butter. Just be conscious that you come over to the center as you try and push up to catch 3rd. Again, MGW specifically advertises a higher spring force pulling the shifter back to center to avoid the 2nd to 3rd miss. FYI |
10-25-2014, 09:05 AM | #10 |
Drives: 2015 Camaro SS Join Date: Sep 2011
Just read there is a recall on some 2014 Manual Transmissions- Linkage Recall 14368
I have a 14 SS with the factory 5.1 ratio short throw shifter and I can honesty say I have never missed a full throttle shift in any gear. IMO the tremec is one of the easier transmissions to shift coming from a 5.0 MT82 where I was locked out of 3rd on full throttle shifts frequently.....
2015 Camaro 2SS Cam/Heads/FBO 498/447 SAE |
10-25-2014, 01:54 PM | #11 |
There is a difference between "missing" a gear and being "locked out" of a gear. One is user error (or at least user interaction with the design) and one is a mechanical problem.
It's a good shifter, but I'm betting the OP had the former. And the recall is unrelated. Not being a dick, just saying. |
10-25-2014, 07:20 PM | #12 | |
10-26-2014, 12:05 AM | #13 | |
2nd gear lockout? Are we talking about skip-shift? You had 1st and 2nd gears replaced ... something very few, if any, other people have had done. So what you meant to say was, "My 1LE had some transmission issues, yours might be defective too." ... which is very different from, "these trans are tricky" and "it takes some time". The former indicates that there might be a mechanical problem with a select few vehicles. The latter indicates that there is something fundamentally wrong with the design of the transmission in the 1LE. Considering the transmission in my 1LE is better, by leaps and bounds, than the manual in my E46 3-series, the C7 Stingray (which is actually pretty terrible), the Mazda Miata (which defined what a sports-car shifter should be like), and the last 996 Carrera 2 I drove (which had a superb transmission) .... I'd say the 1LE's transmission design was impeccable. The only manual transmission I've driven that's as good as the unit in the 1LE is the unit in the Honda S2000. And I'm quite calm, thank you for your concern. |
10-26-2014, 12:21 AM | #14 |
Drives: '16 C7 Z51 Join Date: May 2012
When you rev hard, the engine compesses one of the engine mounts (and stretches the other), twisting a bit. Transmission will not twist as much due to tolerances and flex, so the shifting will be slightly misaligned. This happens with pretty much every car, which is why I usually stiffen the engine mounts of every car I go to track with.
Hopefully, it's not any other issue, and slowing the shifts and/or engaging the clutch better should help. As was also mentioned by Randy Pobst, this transmission does not like to be rushed.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
