10-03-2013, 03:51 PM | #1 |
Track > 1/4 Mile
Driver Seat Squeaks!
I have a 2013 Camaro ZL1 with 2,800 miles on it. I just noticed two days ago the chair started to squeak. I hear it mainly when I push my back against the the seat. It is driving me up a wall, anyone else have this issue or know what it might be?
I've tried moving the chair in different positions but it doesn't seem to help.
10-03-2013, 06:33 PM | #2 | |
Drives: GM Vehicles Join Date: Jun 2010
I do apologize for reading about your seat squeaking. I understand that you're seeking opinions of this matter, and wanted you to know that we're also here if you need additional assistance. Feel free to send me a message if needed. Regards, William R. Chevrolet Customer Care |
10-04-2013, 09:05 AM | #3 |
Track > 1/4 Mile
Thanks William.
I went to the dealership this morning and of course the squeaking stopped and I could not replicate it... I will continue to monitor it and see if it gets worse. There appears to be a TSB for this "PI097: Squeak/Creak type noise from driver and passenger seat track front mounting system." Time will tell.
10-04-2013, 04:18 PM | #4 | |
It's so displeasing when that happens. Please keep an eye on it and let me know if it arises again. We're here via PM if you need us. Kind regards, William R. Chevrolet Customer Care |
10-22-2013, 07:34 PM | #5 | |
Drives: 2012 Camaro 2SS/RS L99 A6 Black Join Date: Jun 2013
10-22-2013, 07:37 PM | #6 |
I have a 2010 and my passenger seat squeaks bad too. Especially over a bump
11-01-2013, 03:08 PM | #7 |
Drives: 2013 ZL1 Join Date: Jun 2013
My 2013 ZL1 had the same problem, passenger seat was creaking, and the service manager set me up for the repair under the TSB listed. When the part came in it was damaged in shipping and rather then try and make it work they ordered me an entire seat track and had it over nighted , mind you I'm still still in the loaner car. To make a long story short the car seat was fixed when promised and washed and waxed when I got it back, thumbs up for Dimmitt Chevy from Clearwater Florida .
11-05-2013, 01:37 AM | #8 |
Drives: 2013 camaro 2lt r/s Join Date: Nov 2013
well you aint alone , my 2013 with 400 miles on it has a squeaky drivers seat
seat has to all the way back and squeaks very loud if you hit bumps just right or wiggle in the seat no big deal , I will address this when I go in for my 1st oil change @ 5000k |
11-15-2013, 08:32 AM | #9 |
Drives: 2013 Camaro LT2 RS Join Date: May 2010
Same problem with both seats in my 2013 RS. This is a common problem and is related to the seat frame design....it is a flaw. I know this because of several trips to my dealer for the infamous clunking seat. This occurs when the seat is in the FULL back position and someone is sitting in it. The ONLY solution to this "clunk" is to move the seat forward a tiny bit, to keep it from resting on the rear bump-stop.
Both seat frames on my car were replaced and the brand new ones did the same thing. I suspect that all of the 2013s have this problem and the only people that notice are the ones that put their seats in the "full back" position. |
11-16-2013, 11:49 AM | #10 |
Drives: 2011 Camaro 2SS/RS Join Date: Jun 2011
The squeek may be the seatbelt buckle rubbing on the side of the seat. I have a noise from that area on the driver side, if you look at the buckle mechanism, there is a felt-like material about 2" long 1/8" wide on the seat side of buckle that acts as a rub protector. This material appears to wear smooth and then squeeks on the leather seat edge. Sitting there in the seat with the belt fastened, pulled snug, move your hips any direction and you will hear the noise. I wonder if anyone with cloth seats has squeeks, probably not. i imagine a few basic remedies would be easy to apply, new felt on buckle would work too.
12-07-2013, 08:54 PM | #11 |
Drives: '13 AGM/1SS/1LE/NPP/NAV Join Date: Mar 2013
My car does this on the driver's side. First time was around 1500. Brought it in, tech said he got it to go away by re-torquing the seat frame. It was perfect until ~5000. Now it's back and it irrationally irritating. It's literally a loud creak every time I go over any bump at speed. I'm a resident though and haven't had a weekday off to take it in. Until then... I hate driving the car.
12-07-2013, 09:24 PM | #12 |
mine has done the same thing since new. had it in once to fix it. a few blocks from the dealership and noise was far worse than before. sounds like a pos when driving on bumpy roads.
12-08-2013, 02:11 PM | #13 | |
Kindly, William R. Chevrolet Customer Care |
12-10-2013, 10:33 AM | #14 | ||
Drives: 2012 Camaro RS Silver Join Date: Jan 2013
Did it sound like this?? |
