Old 01-20-2014, 10:30 PM   #1
SV6GUY
Endlessly Wrenching
SV6GUY's Avatar
Drives: VE SV6 S2 manual
DIY manifold porting
Hey there,
Annoyingly we don't have an experienced porting service in Oz for the LLT, was wondering if anyone has gone with a DIY approach. Any sort of feedback or advice will be greatly appreciated.
SV6GUY is offline   Reply With Quote
Old 01-20-2014, 11:46 PM   #2
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
What? Like Australia? Isn't that MACE country?
Jason@JacFab is offline   Reply With Quote
Old 01-20-2014, 11:51 PM   #3
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Yes but the MACE porting gets done in the US
Old 01-21-2014, 08:14 AM   #4
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Porting the inlet plenum not very hard to do, just time consuming and finding the right filler to smooth out. I matched the six intake ports only with the isolator spacer and got great results.
Old 01-21-2014, 04:52 PM   #5
SV6GUY
Endlessly Wrenching
SV6GUY's Avatar
MACE in Australia doesn't provide a porting service...yet
Thanks Sikoriko, anyone else?
Old 05-09-2014, 12:50 AM   #6
SV6GUY
Endlessly Wrenching
SV6GUY's Avatar
excuse the bump, but can anyone suggest how to fill in the dip at the manifolds mouth?
Old 05-09-2014, 03:00 PM   #7
mhog
mhog's Avatar
Drives: 2010 V6 Camaro 2LT/RS
This is how I did it:
Buy this size box of JB weld (http://www.ebay.co.uk/itm/JB-WELD-IN...-/250858214345)
After you clean and dry your manifold you will have to prop the front up on something about 10 inches of so to keep the putty level when you put in into the sump or chin of the manifold.
Mix the JB weld putty.
Use a paint mixer to scoop the putty into the sump of your manifold. If you get the industrial size you will use all of it. You kind of want to use more than necessary. You are going to have to trim some off anyway and you want it to be one pour. One pour because you don't want any separations in the putty. In other words don't let the putty sit too long before you get all of it in. That will cause it to crack and break off after some time.
Let it sit to dry overnight then have fun cleaning up.
mhog is offline   Reply With Quote
Old 05-09-2014, 03:23 PM   #8
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Take it to a weld shop and have them fill it in with filler rod. Don't trust that jb material. Hey its your valves
Old 05-09-2014, 04:34 PM   #9
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Since it's aluminum, welding may be cost prohibitive.
If the IM is not brand new, it may have oil residue even after thorough cleaning.
Tracy (Rx Performance) claimed the aluminum was porous and he soaked the "dip" overnight with brake fluid as a solvent to eliminate all the oil.
I dunno, I'm just passing it on. But if someone starting skipping this step to save time, it might explain our recent number of failures on professionally ported IM's.
Old 05-09-2014, 04:40 PM   #10
Jason@JacFab
I'd be afraid of warping it if it was to be welded... That's a pretty big dip to fill up welding... I've got a metal forge on the way, so I can just pour molten aluminum into the areas that need to be filled.
Old 05-10-2014, 02:24 PM   #11
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Acid clean or cut the thing off and weld a plate. That is a good chunk of metal it you continuious weld (filler) yesit will wrap
Old 05-10-2014, 04:41 PM   #12
mhog
mhog's Avatar
I have had the JB weld material one my manifold for about 2 years now. I had my manifold off last week and the JB weld was still intact. I think as long as it is one solid piece it will be ok. If the whole thing breaks loose it would be too big to cause any major problems.
Old 05-11-2014, 08:36 AM   #13
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
Could you drill a few pilot holes in the dip and run a few screws into it before the pour, like RacnJsn95 has done on the LFX manifold? That would give the epoxy something more to wrap around and cling to.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 05-13-2014, 12:45 AM   #14
SV6GUY
Endlessly Wrenching
SV6GUY's Avatar
that brake fluid idea sounds great. I thought I might put a horizontal bolt through the 'reservoir' like 911medic suggested but i'm a bit worried what material i should use to fill the dip, need a reliable resin.
