07-25-2023, 12:15 PM | #1 |
Drives: chevrolet camaro Join Date: Aug 2019
Speed Engineering Heat Exchangers
good afternoon all,
has anyone with an 20 and up used the speed engineering heat exchangers, their website says for years 17 - 19 Zl1 and 16- 19 CTS-V. i have a 21 Zl1 and want to use these. will they fit the 2020 and up Thanks |
07-25-2023, 09:36 PM | #2 |
Drives: '21 ZLE A10 Join Date: May 2012
same...they will fit
07-26-2023, 04:49 AM | #3 |
Drives: 2022 Rapid Blue ZL1 Join Date: Feb 2022
Yes, 17-23 are all the same for heat exchangers.
Please report back on the fitment and quality if you do order them though. I have been curious about them since they are so cheap. I just recently ordered the Weapon-X triple exchanger set with the black ice coating. I think a lot of people want to know if SE is a quality option.
2022 M6 Rapid Blue ZL1
Performance: Kong X-Port OEM blower, 1 7/8" TSP headers (Polydyn coated), Corsa Intake/X-pipe/NPP Exhaust, LT5 95MM TB, DSX FlexFuel sensor, Dedicated Motorsports inline fuel filter, Katech Dual fuel pump, WeaponX Boost freeze chiller, WeaponX center and aux HX, PWR oil cooler, and Elite E-2X catch can. Tuned by Pat G 731 WHP on a Mustang Dyno. Suspension/Brakes: Eibach lowering springs, Vorshlag camber plates, Full SPL rear control arms, DSC Sport suspension controller, Blackwing F/R brake cooling ducts. |
07-26-2023, 06:39 AM | #4 | |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, AWE Touring, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
07-26-2023, 07:38 AM | #5 |
Thanks for the feedback! I considered the SE exchangers, but this is a brand new, nice car, I just didn't feel right about putting a cheaply made (unknown quality) parts on. Plus the black ice coating should help even more with heat soak, so I felt it was worth the extra money.
07-26-2023, 08:52 AM | #6 |
Drives: 2019 Camaro ZL1 1LE Join Date: Nov 2021
I think i'm going to try them out.
Remember sometimes a lot of companies buy parts and just re-brand them. I'm sure there are other companies using these with their name on it |
07-26-2023, 11:22 AM | #7 |
I've looked at all the different companies that make them, and they all look exactly the same, except for the company Logo on some of them.
Last edited by LORDOBERON; 07-26-2023 at 11:27 AM. Reason: added more information |
07-26-2023, 01:17 PM | #8 |
My only curiosity is if these are really needed. GM really did their homework with the ZL1 1LE on the cooling because of the problems they had with the Z06. I'm wondering if the thicker cooler will definitely take air away from the radiator and the AC condenser and curious if this will cause problems down the road. For us track rats having the supercharger cooler is great but making sure the radiator is keeping the engine cool is very important as well.
07-26-2023, 02:22 PM | #9 |
Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
I have them. They add capacity but be aware that the brackets for the small heat exchangers have to be modified a bit to fit due to the bigger tank size which also interferes with the rock guards in front of them. I had to shave about 1/4" off them where they butt up to tanks to get the rock guards to fit correctly. Not too bad to mod overall though.
At the time, I measured the exact amount of coolant I gained but of course I then lost track of the paper I wrote it down on. Between the 3, I think it was a bit over 1 gallon. 1 small cooler is for the engine FYI. I believe I picked up about .5MPH in the 1/4 mile by just doing this. The car consistently trapped 124something before and now traps 125 consistently. |
07-27-2023, 05:27 AM | #10 | |
07-27-2023, 05:40 AM | #11 |
From all the ones I've looked at, while having similar shape, I have noticed that some have taller and/or thicker cores. The main concern for me though is the weld quality. WeaponX, as well as others like LMP, are made in house, hand tig welded, and pressure tested before they are shipped. The Speed Engineering are definitely made in China and are machine welded. This isn't necessarily a horrible thing, but it could be a higher potential for leaks. Like I said before, I was considering these, but I just decided to go with WPX for peace of mind. Plus I really like that they offer the black ice coating for better heat dissipation.
07-27-2023, 07:48 AM | #12 |
Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
No matter what headers you get - make sure you get them jet hot / ceramic coated for up to 2500'. LT4's run very hot through the manifolds. Do everything needful to keep the underhood temps down.
#SAVETHEMANUALS
07-27-2023, 08:10 AM | #13 | |
Drives: 2021 Camaro ZL1 Join Date: Mar 2023
I got a little off the main topic there. @smokin19 did you have to make any modifications for the Weapon X heat exchangers to fit?
2021 Camaro ZL1 Satin Steel Metallic
Rotofab CAI, Banks Idash, AEM X series wideband, CSP 2" headers, Jet hot 2500 ceramic coating, DSX Flex Fuel Sensor, DMS Fender Tank, Velossatech Big Mouth, JMS Fuel Booster, MPI Billet Lid, Jokerz race port, 2.30" upper, 107mm Soler TB, 160°F Billet DMS, Big Gulp, LPE Big Bore HPFP, XDI +30, ECM & TCM tuned by Elite Tuned, Atturo 315 AZ850DR |
07-27-2023, 08:31 AM | #14 |
Drives: '20 ZLE Join Date: Jun 2020
Mine were upgraded but I don't know who's they are
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. |
