05-25-2018, 09:51 AM | #1 |
Drives: 2011 LS Camaro Join Date: Mar 2011
Is this fixable?
What do you guys think? Body shop said that putting bondo in that place would be weak and non sufficient... Recommended a new bumper.
Exhaust: Magnaflow catback/x-pipe, Injen SRI, BBK Headers w/ no cats
Suspension: BC BR Coilovers Cosmetics: ZL1 front conversion, AAC plasma afterburners 2.0, GFX rear, Interior: AAC red footwells, ZL1 shifter boot/knob, suede center console |
05-25-2018, 10:04 AM | #2 |
Drives: 2010 Camaro 2SS/RS Black & Silver Join Date: Aug 2010
A new bumper is not that expensive. Check on the site in the for sale section or ebay.
STAINLESS WORKS HEADERS-TUNED BY JANNETTY RACING-C.A.I. INTAKE-TAYLOR 409 WIRES-SOLO AXLE BACK EXHAUST-ELITE CATCH CAN |
05-25-2018, 10:09 AM | #3 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Yeah if they are going to have to reshape, and bondo, and blend the paint anyway... you might as well just start with a new bumper.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
05-29-2018, 02:28 PM | #4 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
Bumper Facias/covers are repairable. Bondo has nothing to do with it. Do you homework.
But a new cover might be your best way to go.
05-29-2018, 02:54 PM | #5 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
New bumper...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
05-29-2018, 03:00 PM | #6 |
Instagram: Sangstah
I would suggest a new bumper or find a used one off craigslist. Bondo will crack eventually.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
05-29-2018, 08:16 PM | #7 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
There are plastic "bondos" now. They "weld" the pieces back together. If done right, it's just as strong as original was. But you need to find the right guy who knows what he's doing.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
05-30-2018, 06:19 PM | #8 |
Drives: LT W/2LT,blue metallic Join Date: Jul 2016
and by the time you pay for his labor a new bumper might not be such a bad deal.
06-02-2018, 09:51 PM | #9 |
Drives: 2014 Camaro 2SS RS & Ground effects Join Date: Apr 2014
is there a piece that goes over the area with the white dots? If so and if you have it why not try crazy gluing it back on and then minimal body work?
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260 |
06-02-2018, 09:56 PM | #10 |
06-05-2018, 07:58 PM | #11 |
Drives: 2012 2SS RS Join Date: May 2018
Depends on how picky you are. If you don't mind them heating the plastic up to bend it back into shape, glue and screw the bumper back in place (altering the body permanently) and build up the missing piece then paint and blend, then I am sure you can find somebody willing to do it. If you want them to fix the bumper to where it attaches properly back in place without undue tension then it probably has to come off, then someone has to build up the missing section and fix the attachment point that is damaged. If the bumper is off and the paint is out then painting a new bumper cover might be cheaper than the labor in the first place, and the likelihood of getting an acceptable high quality repair goes way up.
When I bought my car one of the other cars I looked at (drove over 500 miles round trip and otherwise really liked it) had similar damage from a car wash on the rear bumper with the offending bit still attached and also curb damage to the front bumper. While the owner suggested just forcing the piece back in place and super gluing it to the body to keep it in place, but that wouldn't be acceptable to me, with the other minor body damage it had the only way I would drive the car is with 2 new bumpers and a total re-spray but it was a 10 to them. So if you can live with it keep shopping around there will be a body shop that will take your money, but the outcome is probably better with a new bumper cover. |
