Old 01-30-2014, 07:56 AM   #1
'10CamaroSS
Drives: 2010 Camaro 2SS
Cylinder head removal and install
I'm looking for a good DIY on removing and reinstalling my heads. It's more the reinstalling that I'm kind of not so sure about. Any help would be much appreciated.
'10CamaroSS is offline   Reply With Quote
Old 01-30-2014, 10:16 AM   #2
SNSSTR
All About That Speed
SNSSTR's Avatar
Drives: 2010 Camaro 2SS/RS
Here's a little write-up that may help you out.
http://www.camaro5.com/forums/showthread.php?t=197733
2010 SS M6 | 416 CI | H/C/I | GPI TUNED | SNSSTR
SNSSTR is offline   Reply With Quote
Old 01-30-2014, 11:01 AM   #3
'10CamaroSS
Thank you. I've read this thread before and from what I understand as long as #1 cylinder is at TDC than their is no certain order that the rods, rockers need to be installed. Is this correct? I'm no mechanic but I'm definitely not a dummy I'm just trying to get as much info as possible before deciding if this is something I can attempt in my garage.
Old 01-30-2014, 11:12 AM   #4
SNSSTR
SNSSTR's Avatar
I'll be honest, I've never done it myself, however, from what little knowledge I have, I don't believe that there is any certain order that the rods and rockers need to be installed. That would be a good question to ask in the V8 Help Desk
Old 01-30-2014, 03:29 PM   #5
Broke Pilot
Drives: '14 1SS 1LE,'68 Chevelle,'70 Vette
If you're referring to the order of removal, then no, you can pull them off in any order. But when you do, have a large space to lay them out in order they came out if you're no replacing any of it. Each pushrod and rocker arm needs to go back in the same place it came off.
Overkill is underrated....
Broke Pilot is offline   Reply With Quote
Old 01-30-2014, 04:37 PM   #6
'10CamaroSS
Does each cylinder have to be at TDC when torquing that set if rockers down?
Old 01-30-2014, 04:50 PM   #7
flyinglow57
Drives: rumble bee,2SS 6sp
no the ls motors are unique and can be torqued down right to 23 lbs or what ever the tq spec is. alot better than the old motors.
blk 2ss 6spd with sunroof.
intake,tsp cam,full exhaust,pcmforless tune,trailing arms,toe rods. hopeing for 11.9 because my g/f said she will take the cam and the suspension back if not.
flyinglow57 is offline   Reply With Quote
Old 02-01-2014, 12:24 PM   #8
'10CamaroSS
I appreciate what little feedback I did get on this thread although I thought it was going to be a lot more helpful.
Old 02-01-2014, 07:55 PM   #9
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
Push rods are the same length, so they can go back where ever. You do have different intake and exhaust rockers, so they have to go back on an intake or exhaust valve, but that's it. It is a good idea, to bring each cylinder to TDC to ensure both valves are closed on that cylinder prior to installing the rockers and torqueing them. This is done to ensure you get an accurate torque and valve spring pressure is not affecting the rocker arm bolt torque.
Now, if you want to keep track of where each push rod and rocker arm came from and reinstall to the same position, that fine too. It's actually a pretty good habit to get into.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 02-14-2014, 04:09 PM   #10
'10CamaroSS
Thank you for the help
Old 08-15-2016, 12:54 PM   #11
ZL1 Lingenfelter
ZL1 Lingenfelter's Avatar
Drives: 2013 Camaro ZL1
Its not a good habit, its nearly a requirement. LS motors do not have adjustable rocker nuts like old SBCs. They run hydraulic lifters that require an exact amount of preload (between 0.003 and 0.006") if I am not mistaken. This is done by using a pushrod that has been tweaked to an exact length for each lifter to give the correct preload on the lifter and the corresponding rocker. Therefore, each pushrod and rocker MUST go back in the same spot for the same lifter as removed. It will work if you dont use the same order, but it is not recommended.
ZL1 Lingenfelter is offline   Reply With Quote
Old 08-15-2016, 08:01 PM   #12
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
2014 1SS/1LE
AGP 57/57s, E85 + meth injection, Monster triple, ZL1 diff swap, Z28 coilovers
AGM 1LE is offline   Reply With Quote
Old 08-15-2016, 10:32 PM   #13
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
WRONG
you have to be on the base circle or your tq will be off. The valve spring on the open valves will cause a incorrect reading.
all the push rods are the same length the pre load is .030 to .120. Some builder do .030 but GM is more around .100. pushrods and rockers should go in the same place because of wear. from the GM service manual
7. With the engine in the number one firing position, tighten the following valve rocker arm bolts:
 Tighten exhaust valve rocker arm bolts 1, 2, 7, and 8 to 30 N.m (22 lb ft).
 Tighten intake valve rocker arm bolts 1, 3, 4, and 5 to 30 N.m (22 lb ft).
8. Rotate the crankshaft 360 degrees.
9. Tighten the following valve rocker arm bolts:
 Tighten exhaust valve rocker arm bolts 3, 4, 5, and 6 to 30 N.m (22 lb ft).
 Tighten intake valve rocker arm bolts 2, 6, 7, and 8 to 30 N.m (22 lb ft).
if your not removing the oil pump just rotate so one of the valves on each cylinder is just starting to open and tq the other valve to 22ftlbs.
JCunningham is offline   Reply With Quote
Old 08-15-2016, 11:16 PM   #14
JCunningham
Drives: 2017 2SS M6
all the parts are the same length. they go back together in the same place because of wear. the preload can be .030-.120. GM is around .100 stock. Most engine builders do .030 - .060 because after market lifters require that much. The stock LS7 LS3 lifter requires around .080.
and this is from 2014
