09-29-2012, 12:49 PM | #1 |
Drives: 2011 Camaro RS 2LT Join Date: Jul 2012
Engine Cover with Ported and Spaced IM
I purchased a ported IM and had requested a plenum spacer and 1 inch spacer to be installed and come with my manifold. Does anyone know if the engine cover will work over top of it?
09-29-2012, 01:20 PM | #3 |
I am not even sure I know where to buy those.
09-29-2012, 01:31 PM | #4 |
COTW 9/16/13
Drives: 2011 2LT/RS Camaro IOM Join Date: Jan 2012
You can buy the oil extension from GM I'm not sure what the part number is and the other you have to fabricate yourself.
09-29-2012, 02:10 PM | #5 |
Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
No, it won't fit if you have the plenum spacer. That's what I had heard
09-29-2012, 02:18 PM | #6 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Yep, you can buy the oil-fill neck extension from GM for $8.00 or so and raise the "rod" mounting point a couple of ways, but it'll still fit if you don't add the plenum spacer too.
I've got the part# at home & I'll post it later . |
09-29-2012, 03:15 PM | #7 | |
having FUN now 13.66@101
Oil extension tube (92068813) I bought one for my set-up and extended my post too.
09-29-2012, 06:22 PM | #8 |
I ordered and requested the plenum spacer to be installed with my Ported intake looks like I wont be ever using my engine cover again.. :(
09-29-2012, 09:53 PM | #9 |
Jan
Drives: 2010 Camaro 1LT Red Jewel tintcoat Join Date: May 2010
Who needs that engine cover??????????? It looks better without it. I will not be putting mine back on after instaling my black iceolator. It has already been off a while & no plans of going back there. I am exploring ways to clean up my engine bay. Check out this thread:
http://www.camaro5.com/forums/showthread.php?t=246801
09-29-2012, 10:04 PM | #10 | |
Stop writing "vert", ffs!
Drives: 2011 2LT Convertible Join Date: Feb 2012
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator |
09-29-2012, 10:34 PM | #11 | ||
Funny, because I like my engine bay with my cover than without it. But am looking to do an engine bay clean up over the winter to see what I can come up with to change it further.
10-04-2012, 04:31 PM | #12 |
Banned
Anyone here with machining abilities? Just copy the old post but add the desired length by extending the threads or elongate the top. Shouldn't be to hard with a lathe and a micrometer.
10-05-2012, 08:50 AM | #13 |
Banned
maybe a threaded rod with a ball on it? LOL
10-05-2012, 09:12 AM | #14 |
Drives: 2010 Camaro 2LT RS Join Date: Nov 2008
Just get a connecting nut the length you need. I have the Mace 25mm spacer, so I needed to add an inch. They sell connecting nuts everywhere, including Home Depot.
