Old 12-08-2016, 06:01 PM   #1
barnetter88
barnetter88's Avatar
Drives: 2013 2SS 1LE
Cool ECS pulley size
what size pulley and how much boost are you esc guys making? I have stock pulley that came with kit and the restrictor installed and making little over 6 lbs. I am looking to get around 10lbs. Does anyone have sugestions. Thanks
416 stroker fast 102 intake id 850 injectors, cnc factory heads, ltheaders, highflow cats, night fury cam and ecs supuercharger. 3.91 gears m6 car
barnetter88 is offline   Reply With Quote
Old 12-08-2016, 08:34 PM   #2
xXSicSicSicXx
Drives: 14 1LE
i thought that was the smallest pulley you could run
xXSicSicSicXx is offline   Reply With Quote
Old 12-08-2016, 09:39 PM   #3
pancherj
Drives: 2010 Camaro SS
With the 3.33 pulley and restrictor, I was making 12lbs on my stock cube motor. With a 416, you may need the 3.33 pulley and no restrictor.
pancherj is offline   Reply With Quote
Old 12-09-2016, 06:42 AM   #4
bct10985
Drives: 2010 2SS LS3, 2013 duramax
I think the new ecs kits come with a bigger supercharger pulley than the 3.33
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 12-09-2016, 07:21 AM   #5
tjsblackbonne
Drives: 2011 RS 2SS Camaro
3.47 is the size the kits are shipping with now
2011 Camaro RS/2SS M6
Best NA time 12.29@113.8 (CAI, headers)
Best FI time 11.20@132.72 1.99 60' stock tires (ECS 1500, headers, LS9 cam, Alky Meth, Livernois dual pump,Monster LT1S clutch) 817whp 691 tq
NEW SETUP Forged Thomspon Motorsports LS3, Aruns Jam cam. 852whp 689 TQ
tjsblackbonne is offline   Reply With Quote
Old 12-12-2016, 12:23 PM   #6
Doug @ ECS
Doug @ ECS's Avatar
Drives: very fast
It depends on who it is purchased from, some of our southern dealers prefer a larger pulley and a smaller restrictor due to higher outside temp averages.
Barnetter88, you can just open up the restrictor to your desired boost, wouldn't cost you a dime other then your time and checking the tune over. I hope that helps.
Doug @ ECS is offline   Reply With Quote
Old 12-12-2016, 07:08 PM   #7
barnetter88
Thumbs up
awesome thanks Doug i purchased the kit from you guys at ECS
Old 12-17-2016, 09:49 AM   #8
RaiderSS
RaiderSS's Avatar
Drives: 2010 Camaro SS2 DeadBLK
ECS YSi kit 2.75 Blower Pulley/no restrictor
416 Stroker, AI Heads, 2" LT, Open exhaust, 850ID injectors, ZL1 pump, Quad nozzle plenum direct meth injection.
RaiderSS is offline   Reply With Quote
