Old 05-06-2016, 10:10 PM   #1
bigrobkc
Drives: 2011 Camaro SS
Reinstalling center console after mylink
I did the retrofit mylink and also have the frameless mirror install from gen5diy... I'm finding it impossible to get the 4 pack gauge trim to lay flush and go back in successfully does anyone else have this issue??
bigrobkc is offline   Reply With Quote
Old 05-06-2016, 10:16 PM   #2
flyer08
Drives: 2010 2SS/RS
It's been a long while since I did it in both cars but it should go in easily.
Just throwing some things out, are any wires in the way? One thing I had an issue with when I did the first car was being afraid to break stuff and not putting a trim piece in hard enough. Went back and tried again after letting it sit for a while and popped right in.
flyer08 is offline   Reply With Quote
Old 05-07-2016, 10:28 AM   #3
bigrobkc
Well I definitely wasn't scared to break anything! Freaking frameless mirror harness broke so not sure if I can hard wire that without the harness or not?? Seems like there are too many harness cables for the trim to lay flat..
Old 05-07-2016, 11:18 AM   #4
Tmick5jr
Todd
Tmick5jr's Avatar
Drives: 2012 Camaro
push hard..
Tmick5jr is offline   Reply With Quote
Old 05-07-2016, 12:18 PM   #5
Addoni
Addoni's Avatar
Drives: 2017 50th Anniversary 2SS Camaro
Take the sides off first. They will pop off easily but run the length of the console past the seats.
Try gently pushing the shifter end in first (has the thinnest plastic so you don't want to break that end) and then the cluster. Check the 2 sets of wires on each side of the top of the tunnel. Check the cig/power/traction connections and the gauges connection to make sure there is clearance. It takes patience but should pop in if everything is lined up properly.
Sent from my SM-G935T using Tapatalk
Addoni is offline   Reply With Quote
Old 05-07-2016, 05:34 PM   #6
DaFisch
Master Amateur Mechanic
DaFisch's Avatar
Drives: Victory Red 2011 2SS/RS
The 4 pack guages were changed for my link. You're going to have to shave off the backor buy a 2013 4 pack
2011 Victory Red 22/RS
Forged 418 Ls3 from Texas Speed, LSX heads from Texas Speed, Tick Turbo cam, Jakes/PCM/Billet 4l80e, 3200 Stall converter from Circle D, DSS 750 hp axles, DSS aluminum driveshaft, stock 3.23 gears, TSW Wheels Front 20x10 Rear 20x11.5, Fabberage Twin Turbo Supercharger Killer kit with Upgraded Turbos, Squash Dual fuel pump, Full BMR Suspension/bushings, Holly High Rise intake manifold, ID1300 Injectors, Megan Coilovers, PCM of NC plug and play trans kit. HP/TQ TBA
DaFisch is offline   Reply With Quote
Old 05-07-2016, 08:03 PM   #7
WeflyhereSS
WeflyhereSS's Avatar
Drives: 2012 Black on Black Camaro 2ss
you have to cut using a dremel tool the from two edges diagonally to get it to work
"How do u keep it under the speed limit? YOU CANT HAHAHAHA"
WeflyhereSS is offline   Reply With Quote
Old 05-08-2016, 01:51 AM   #8
C_Amaro92
C_Amaro92's Avatar
Drives: 2015 1LS
Don't have the know how to help you on this one but out of curiosity, how much the retrofit mylink cost you? Did you install it yourself?
Sent from my SM-G900P using Tapatalk
C_Amaro92 is offline   Reply With Quote
Old 05-08-2016, 02:08 AM   #9
Homeless Man
Homeless Life Chose Me
Homeless Man's Avatar
Drives: LS3 (sold 4/21)
I'm looking to do this. Where did u put the lock button?
Pity a man in familiar places, who yet feels like a stranger.
Homeless Man is offline   Reply With Quote
Old 05-08-2016, 05:07 PM   #10
WeflyhereSS
installed myself unit and harness and programming i was right around 900
Old 05-09-2016, 02:23 AM   #11
C_Amaro92
C_Amaro92's Avatar
Drives: 2015 1LS
Oh wow that seems like a pretty great price. Where did you get everything?
Old 05-09-2016, 04:50 AM   #12
Rainbow1616
Rainbow1616's Avatar
Drives: 2011 Inferno Orange Camaro 2SS/RS
I never bothered, I don't miss it at all.
I even bought the door pulls but never bothered putting them in.
As far as the gauge pack you have to trim the corners like the others said. It should tell you on the instructions that came with it.
Rainbow1616 is offline   Reply With Quote
Old 05-18-2016, 10:38 AM   #13
WeflyhereSS
found the unit on here for cheap took a couple months for a good one to pop up , and got the harness and reprogramming for gen 5 diy
Old 05-18-2016, 02:31 PM   #14
el-guapin
Trust No One!
el-guapin's Avatar
Drives: 2010 SIM 2LT/RS
I got the switch but never installed it. Pull on the inside handle twice to unlock the door.
el-guapin is offline   Reply With Quote
