01-03-2013, 12:21 PM | #1 |
Make your peace with God!
Drives: 2011 Camaro SS/RS M6 Convertible Join Date: Dec 2011
Back down to ECS!!
Last April I brought my 4 month old convertible to ECS to have them supercharge it. Two months later I threw on headers and had Doug re-tune the car. A 47 rwhp gain. Since then, I've watched cars come out with waaayyy more power and it has made me jealous. So, since Black Friday, I've been stockpiling new parts to get installed. To include, a new cam, Squash fuel system, ID 850 injectors, MGW shifter, LGW differential cover, Eaton TrueTrac differential, JRE billet caps, DSS axles the Borla full 3" exhaust which I have already installed. I'm excited to bring my car back down and I can't wait to see what kind of numbers they can pull out for me. My goal is for a minimum of 800. So my countdown begins with one more month to go. Any thoughts or inputs from anyone else?
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ UNDER MAJOR OVERHAUL!! Last edited by Chris82xx; 02-04-2013 at 09:18 AM. |
01-03-2013, 12:33 PM | #2 |
Hating prius's since 1997
Drives: 2010 Camaro 2SS/RS (JENNA) Join Date: Apr 2011
Better get a hitch installed before the trip. All those goodies ya might be needin a trailer. Sounds like a real nice setup ya have.
PIPE
01-03-2013, 12:37 PM | #3 |
Drives: Florida Speed & Power Join Date: Jan 2011
cant wait to see the end product
01-03-2013, 12:51 PM | #4 | |
No trailer needed. I have full intentions of driving this car everywhere I go.
811RWHP/719RWTQ UNDER MAJOR OVERHAUL!! |
01-03-2013, 01:06 PM | #5 |
is this the cover you got? http://www.lpwracing.com/Ultra_GM/Ultra_GM.html ?? Or can you pm me it?
01-03-2013, 01:23 PM | #6 |
This is the cover : http://www.lpwracing.com/Ultra_IRS/Ultra_IRS.html
01-03-2013, 01:36 PM | #7 |
Drives: 2011 Camaro SS Join Date: Dec 2012
Nice Chris.. The ECS boys will get you all fixed up...
01-03-2013, 01:42 PM | #8 |
Sounds like a good setup, But you're looking to make 800 on the stock short block? How much boost you running now to get 684?
01-03-2013, 02:05 PM | #9 |
I'm not too certain, maybe Matt or one of the guys from ECS can chime in, but I believe I'm making 10lbs. There are three other guys, including Matt that made over 800 on the stock block.
01-03-2013, 03:36 PM | #10 |
Just seems like it would take a lot of boost to get to 800. I'm running 10psi boost and right at 600hp. would take a lot more boost to hit 800. L99 Car.
01-03-2013, 03:40 PM | #11 |
Hasbin of Stock Bottom HP
01-03-2013, 03:40 PM | #12 |
I've also got meth running right now. I know that the latest car on here left there with 15.3lbs and he's also running meth and is an LS3.
01-03-2013, 03:41 PM | #13 |
01-03-2013, 03:45 PM | #14 |
Drives: 11 Seconds or Faster Join Date: May 2012
She's gonna blow!!!
Thread Tools | |
