Old 11-08-2012, 09:22 AM   #1
bklyn_tap
bklyn_tap's Avatar
Drives: 2011 camaro LS
Long tube header question
I want to buy the obx long tube headers and was wondering if I would have any issues connecting it to my current set up. I have a bbk xpipe connected to my mrt v2 exhaust. Will I have any problems making this work? Anything else I need? I don't have much knowledge on the 02 sensor issue throwing a cel either so what can I do to prevent the cel?
bklyn_tap is offline   Reply With Quote
Old 11-08-2012, 10:16 AM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Your sensors should throw a code because of the increase in air in the cats but a tune will take care of that...also a couple of o2 extensions are a good idea to have
After installing my headers I didn't get a code...not even after giving several hundred miles to give it time to get a cel but idk . Maybe you'll get lucky op
Lil' Nasty is offline   Reply With Quote
Old 11-08-2012, 10:21 AM   #3
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Maybe my install thread of OBX headers will help?
http://www.camaro5.com/forums/showthread.php?t=195877
Old 11-08-2012, 10:27 AM   #4
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Since the x-pipe you have right now bolts up to your stock cats I don't see why it won't bolt up to the OBX cats and headers. I would recommend a resonated X-pipe instead of a true X-pipe though. You will get less rasp.
For the CEL most need a tune and that's the end of it.
Old 11-08-2012, 11:11 AM   #5
bklyn_tap
bklyn_tap's Avatar
That would be nice if I didn't get a cel at all!
Old 11-08-2012, 11:13 AM   #6
bklyn_tap
bklyn_tap's Avatar
I will definitely take a look at your build thread. Sweet car btw. I'm about to install my front splitter. Love the rims
Old 11-08-2012, 11:18 AM   #7
bklyn_tap
bklyn_tap's Avatar
I plan on having off road headers which is what I believe is the only option for obx so it won't have any cats. Tune it is then
Old 11-08-2012, 11:40 AM   #8
rtcat600man
Thank - you, If you should have any questions, feel free to send me a PM.
