02-23-2014, 07:25 PM | #1 |
HT5:Keeping it Exclusive
Drives: Black Mamba 2010 2LT RS Join Date: Feb 2011
Cant open door Help ASAP
Hello C5. I'm in a bit of pickle. I took off my (exterior )door handle ( passenger side ) to wrap it with vinyl. I made the dumb mistake of closing the door with handle off. Now when I go to open it from the inside it won't budge ( it's unlocked ). Any tips on how to open the door ? Thank you
02-23-2014, 08:32 PM | #2 |
Living Life in MPH.
I'm afraid you will have to remove the inside door panel http://www.camaro5.com/forums/showth...+panel+removal or bring to the dealer if you don't feel safe
02-23-2014, 08:41 PM | #3 | |
I can't get to the panel since the door is closed. I'm hoping the dealer is my last resort.
02-23-2014, 11:08 PM | #4 |
Drives: 2013 LS Join Date: May 2013
Pop the trunk and go thru the back.
02-23-2014, 11:25 PM | #5 |
I can open the driver side , but the passenger door is shut the lock is up but it won't open from the inside .,the outside door handle is off.
02-23-2014, 11:38 PM | #6 |
Drives: 2013 CRT/2LT/RS Join Date: Nov 2013
02-23-2014, 11:44 PM | #7 |
Exactly, I can't open the passenger door even tho it's unlocked and I can't pop off the door panel since the door is shut
02-24-2014, 10:22 AM | #8 |
Bump
02-24-2014, 12:24 PM | #9 | |
Let's go Rangers!
02-24-2014, 08:32 PM | #10 |
pretty simple. there should be a door handle rod hanging in there. im sure you can reach in with a finger and depress it thru the exterior hole where the handle went.
02-24-2014, 08:36 PM | #11 |
Living Life in MPH.
but really now, go to the dealer if you haven't gotten it yet..Try bending a wire hanger to fish the wire if you can't fish it with your fingers. GL!
02-24-2014, 10:25 PM | #12 | |
What wire are you referring to ?
02-24-2014, 11:13 PM | #13 | |
RIP Betsy ( Vitara )
The exterior functions without the interior being on so why not vice versa?
First retrofitted 2014 mylink. |
02-24-2014, 11:41 PM | #14 | |
Yeah I thought the same thing. For some reason now the latch is stuck even with the door unlocked it won't open from the inside.
