Old 06-27-2013, 04:10 PM   #1
MasterZ
MasterZ's Avatar
Drives: 2010 Camaro SS/RS
Street Slayer twin throw out bearing part #
anyone happen to know the part number for the street slayer throw out bearing.. mine seems to be squeeling after alot of spirited driving on the Tail of the Dragon at Deal's Gap during the Hot Rod Power Tour.. I figured it probably got hot and melted the lube out...
need to get it ordered asap and shipped to me before the 4th so I can get it changed out...
thanks
2014 C7 Z51~ M7 custom paint,
Mods soon to come, researching at the moment.
MasterZ is offline   Reply With Quote
Old 06-28-2013, 03:57 PM   #2
JustaCamaro
Figured it out!
It is just the bearing portion of the release assembly for a 2005 Ford Ranger.
I had to purchase the whole slave assembly to get it. Not to bad-$65 at O'Reilly's.
From my thread.
Use only the bearing-exact same part number as the one that came with the clutch
JustaCamaro is offline   Reply With Quote
Old 06-29-2013, 04:15 PM   #3
Rabamaro
Drives: 2010 ABM SS/RS
Originally Posted by JustaCamaro View Post
Figured it out!
From my thread.
I'd been told that the street slayer used a "beefed up" throwout bearing. It's the same one from an '05 Ranger??
Vararam Tune CAI, Vararam Power Wedge, 160 degree stat, VMax ported throttle body, Ceramic coated ARH 1 7/8" LTs with X-pipe, Borla S-Type Axle back, MGW short throw, 3.91s, Ported stock IM, BTR Stage IV cam, Heritage Grille, Backup camera, UMI Performance trailing arms and toe rods, dyno tune
Rabamaro is offline   Reply With Quote
Old 06-29-2013, 04:15 PM   #4
Rabamaro
thanks
Whatcha got going on on the 4th Jason?
Old 06-29-2013, 09:10 PM   #5
MasterZ
MasterZ's Avatar
hopefully I will be swapping out my throw out bearing...
Yes, the Street Slayer does come with a heavy duty throw out bearing. Great product.
I think I over did mine. During the Hot Rod Power Tour we did the tail of the dragon at deals gaps. We did the run 4 times pretty harsh and I stayed in 2nd gear alot. I think I over heated the bearing and melted the grease out causing it to squeak... Thus the reason I am changing it..
Old 06-30-2013, 10:12 AM   #6
H-E
Drives: 2010 zr1 Camaro 2011 vert
We have these HD bearings on our site for any one that has a clutch install coming up...Op yours shipped out ,I sent it 2 day for you
H-E is offline   Reply With Quote
Old 06-30-2013, 10:28 AM   #7
MasterZ
MasterZ's Avatar
thanks a ton! cant wait to get it installed, Great Customer service
