04-21-2012, 05:47 PM | #1 |
Chiquita
Drives: 2013 1LE/1SS YELLO1LE 1 of Only 28 Join Date: Nov 2011
HELP FRONT BOWTIE DELETE
I can't get it OFF??? Whats the trick???
04-21-2012, 05:48 PM | #2 |
Let's go Rangers!
When you find it let me know.
Sent from my 2LT/RS using Tapatalk |
04-21-2012, 05:59 PM | #3 |
There is four tabs on it. Sqeeze them together pull straight out on the bowtie.
04-21-2012, 06:02 PM | #4 |
04-21-2012, 07:03 PM | #5 |
Drives: 2010 Camaro 2LT RS Join Date: Nov 2011
Put a towel around it to protect your hands and pull out hard. It takes a lot so dont be afraid to break it.
04-21-2012, 09:20 PM | #6 |
04-21-2012, 11:15 PM | #7 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
There are 4 tabs two horizontal underneath, and two vertical in the center.
The horizontal ones are bigger, and if you get them loose, thats about all you need, get a good grip behind both sides and pull slowly with constant force (not jerking) and it will come eventually. The middle ones are small and you dont need to squeeze them, they will just come once you pull on the outside. Takes a little effort, and its harder than it seems, but itll come |
04-29-2012, 10:36 PM | #8 |
Drives: 2012 1SS/RS Join Date: Feb 2012
take off the radiator cover under the hood, gives easier access to the 4 tabs,
Inferno Orange Metallic, Hurst short throw, Boston Acoustic, straight pipes, 5% tint, replaced bowties with color match, lloyd mats in inferno orange.
04-30-2012, 12:39 AM | #9 |
Drives: 2016 Camaro 2ss Join Date: Aug 2010
Nothing is require for it to be taken off! It's really simple
1. Brace yourself 2. Grab bowtie firmly 3. Open a can of man and pull on the left side of the bowtie 4. Repeat step 3 to right side of bowtie. And don't take it serious I'm just being sarcastic lol. It's really simple to remove |
06-10-2012, 05:36 PM | #10 |
DAVE T
Drives: 2011 1LT Summit White M6 Join Date: May 2011
Me and the wife got mine off in less than 15 seconds. The best way I found was one pinches the right side tab thru the grille while pulling and the other does the same on the other side at the same time and it comes right out. If one side is pulled more than the other, the opposite side will lock back in, so you both have to be "in sync".
06-10-2012, 08:06 PM | #11 |
Drives: '12 2SS/RS, '13 Vette, '13 Wrangler Join Date: May 2012
I just grabbed it and slowly but firmly pulled until it came off. You can also search google videos for videos of it if you wanna see it before you do it.
2012 Camaro Ashen Grey Metallic 2SS/RS "Timberwolf". Custom exhaust, RX oil catch can and oil breather, CAI inc intake, SLP 160* thermostat, TSP 2" LT headers w/ off road pipes, custom cam, tuned. 467rwhp 450rwtq.
2013 Corvette Torch Red LS3. 378rwhp/375rwtq SAE corrected, tuned. ROCK CHALK JAYHAWK GO KU! |
