Old 04-27-2013, 07:44 AM   #1
Aubrey64
Aubrey64's Avatar
Drives: 2010 Camaro LLT/RS
Clanking sound after 1.2" drop?
I installed 1.2" BMR drop springs last week and I love them. The only thing is, is that I've noticed a clanking/rattling sound coming from my car. Sometimes it seems as though it's coming from the front, but sometimes from the rear. I checked for loose nuts/bolts and everything was fine. Is this normal since my springs are new, or is this something to be concerned about?
Aubrey64 is offline   Reply With Quote
Old 04-27-2013, 08:09 AM   #2
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
I had the Pfadt clunk after I installed their springs a while back, but haven't heard about BMR. I put Eibachs in and they have been quiet since day one. If everything was installed properly there should be NO noise. Double check your install to rule that out, then it can be narrowed down to the actual springs themselves. It sucks but Iv'e been there and done that
'19 Z06-7Speed and lowered on stock bolts
'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew
TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0
SOLD! '18 ZL1 Mosiac Blk
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 04-27-2013, 08:36 AM   #3
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
I've got the 1.4 BMR springs and over moderate to hard bumps the rear clicks noticeably loud. Had it checked twice and the install is 100% correct. I'm thinking its just the spring compressing fast and hitting itself?
I love my springs, but I want to go lower and being in NY I need something adjustable. Not to mention we have some of the worst roads in the country. Lots of bumps I hit cause the rear to shift a lot and roll. Someone else with BMRs had complained about it and I'm sure all springs will do that on these cars. Just a result of the IRS.
DarkneSS is offline   Reply With Quote
Old 04-27-2013, 09:49 AM   #4
dstroyr11
dstroyr11's Avatar
Drives: 2011 2SS (sold) 2017 ZL1/A10
Hey DarkneSS, do you have any rubbing issues on your fenders with 1.4 drop? What size tire and wheels do you run? I was thinking about 1.4 drop with 22's but didn't know if they would hit fenders or not.
dstroyr11 is offline   Reply With Quote
Old 04-29-2013, 07:30 AM   #5
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
I also had BMR 1.4 and they clanked on hard bump so I took them off a week later and got coil overs, no more problems since then
jeremywes is offline   Reply With Quote
Old 04-29-2013, 12:10 PM   #6
Aubrey64
Aubrey64's Avatar
I'm REALLY hoping that its just a problem with alignment or with the springs still settling in. I really don't want to have to buy any more parts or have to replace the springs
Old 04-29-2013, 12:56 PM   #7
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
What you are hearing is most likely the springs clanking together. Many spring manufacturers are starting to provide Spring insulators/isolators. (whatever you want to call them)
Note the Brown rubber on the close coils.
I have seen others in the past use tubing from Home depot / Lowes, cut a slit and put it on the noisy coils. May not be the answer you are looking for but it does work.
Best regards,
Tyler
888-308-6007
Old 04-29-2013, 01:31 PM   #8
jeremywes
jeremywes's Avatar
wheres that guy with the toilet bowl mod? Maybe he can figure something out ;-)
Old 04-29-2013, 02:17 PM   #9
Aubrey64
Aubrey64's Avatar
Best regards,
Tyler
888-308-6007
That's exactly what it sounds like! So that is most likely the problem. Well, is this something that needs to be fixed, or something that could damage anything? honestly, it doesn't bother me that much because I can only hear it when the radio is off, and I rarely drive without the radio on. So is it ok to just leave it as is?
Old 04-29-2013, 02:34 PM   #10
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2021 Shadow Grey Camaro 2SS 1LE
My Hotchkis clunk over patched ashphalt and such also.No big deal and installed correctly
VR Baron is offline   Reply With Quote
Old 04-29-2013, 04:09 PM   #11
JDP Sales
JDP Sales's Avatar
It's fine, and is not going to hurt anything besides the powder coat on the spring itself. The sound is just a bit annoying.. The hose/tubing is a good "fix" I have even seen some people give them a shot of plastidip on the noisy springs. May be worth a shot.
Best regards,
Tyler
888-308-6007
Old 04-29-2013, 04:20 PM   #12
Aubrey64
Aubrey64's Avatar
Best regards,
Tyler
888-308-6007
Thanks for the tip! I may give plasti dip a try, I jus don't want to have to uninstall it to put the tubing on, so plasti dip sounds like the route I'll go. Thanks again for the help!
Old 04-29-2013, 04:43 PM   #13
JDP Sales
JDP Sales's Avatar
If you try the tubing, just cut a slit in it and slide it over the springs. No need to uninstall them. The car being lifted with the suspension sagging should give you enough space between the coils to slide them on. Good luck and let us know how either of these work for you.
Best regards,
Tyler
888-308-6007
Old 04-29-2013, 08:31 PM   #14
MPG1959
Drives: 2012 45th SS
My BMR 1" drop springs do the same thing. I've contacted BMR and they told me they were trying to source out the spring tubing sleeves but have not heard any more about it. I'm going to the depot and see if I can find some tubing to make my own sleeves cause that clunk bugs the crap out of me!
MPG1959 is offline   Reply With Quote
