05-12-2013, 08:01 PM | #1 |
Drives: 2011 Camaro SS Join Date: May 2012
Tell me what you think - Michelin's Pilot Super Sport
What do you guys think about this setup for the stock SS rims?
05-12-2013, 08:09 PM | #2 |
What's in there to be that much more than the OEMs ?
05-12-2013, 08:25 PM | #3 |
Im not sure but they are like the best rated tire. They are suppose to be amazing. I was just curious about the sizing.
05-12-2013, 08:29 PM | #4 |
that's how we do it
Drives: '20 ZL1 / A10 Shadow Gray Join Date: Oct 2010
I've heard a lot of positive things from others who have used that tire.. I plan to try them on my next tire change (different size choice) but same tire.
..."It's All Good" -Todd formerly maddog360
-drives: '20 ZL1/A10 Shadow Gray -rides: Harley-Davidson FLHRSE5 110ci-aka Road King [COLOR=#ff0000][COLOR=black]'02 Camaro SS/SLP 6spd Last edited by RoadMonkey; 05-12-2013 at 08:29 PM. Reason: typo |
05-12-2013, 08:38 PM | #5 |
What do you think about the sizing for the stock rims?
05-12-2013, 09:48 PM | #6 | ||
Original Bumblebee Owner
Drives: 265hp ZX-14, 500hp Silverado, V-ROD Join Date: Apr 2009
285s need a 10" wheel...
05-12-2013, 10:11 PM | #7 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
They dont make the 275/40 for your 20x9 rims in the back. Other then that they are very good street and track tire that wear well dry or rain If I dont do Nitto invos, those are the other choice
05-12-2013, 10:29 PM | #8 |
No 275/40. those are the closest size . Will they work?
05-12-2013, 10:42 PM | #9 |
05-13-2013, 12:03 AM | #10 |
Judging from the difference in size ( 275) vs (285 ) , it's only 10 mm wither , than the OEM , this will give you an extra 5mm , to each side of the tire ( inside/outside , so if you can picture the ( corner ) off the tire ( at wall/thread coming out that much ( just short of 1/4 " ) , and in your eyes it looks clean , do it
05-13-2013, 07:50 AM | #11 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
This issue is the tire diameters. 285/35/20 is only 27.9" in diameter. That's a full 1" smaller than stock (245/45/20 - 28.7").
You should try to find a front tire that's closer to that diameter if you want to run that rear tire size. |
05-13-2013, 10:10 AM | #12 |
What I'm trying to accomplish is running these tires on the stock rims. if someone could give me the correct size to do that I would greatly appreciate it. These tires are limited on the sizing. Check out tirerack. http://www.tirerack.com/tires/tires....ot+Super+Sport
05-13-2013, 12:59 PM | #13 |
Drives: 1-800-428-8355 X4664 Join Date: Sep 2010
Unfortunately there is just no good way to do it on stock rims. The tire will either be too wide for the rear wheel or the front and rear will be too far off in diameter which can cause issues with stabily control.
05-13-2013, 01:10 PM | #14 | |
