04-26-2011, 07:47 PM | #1 |
Drives: 1969 Camaro Z28 Join Date: Apr 2011
454 Engine Build. Help needed!!
Just purchased a 1969 Camaro Z28 with a 454 crate engine for my first Chevy bb project. The engine Cast# is 10237297. Was looking to put 500hp to the rear wheel naturally aspirated while still streetable. Does anyone have any suggestions for what I can put on the engine minus taking the block out? I was looking at some of the edelbrock top end kits and a quick fuel carb. I figured someone might have a better idea for a cam/lifter/head combination or better manifold to put on it. It has a 4" cowl hood and plenty of room for a bigger manifold.
This is what the car has on the engine: Holley 650 carb K&N Filter w/XTREME top Poweraid throttle body spacer MSD HEI distributor & 8mm plug wires Edelbrock Performer RPM manifold Hooker Competition headers Everything else on the block is bone stock. It currently pushes 280/350 to the rear wheel through a th400 backed up by 12 bolt 3.73 gears with positraction. The gap on the plugs is .045 through acdelco copper plugs and I'm running 93 octane on it through an electric fuel pump. Tom |
04-29-2011, 09:42 PM | #2 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Hyd roller cam
single plane intake I would look at Brodix or AFR heads As for a carb, better off getting a carb from Pro Systems. They custom build it. You fill out a questionaire of whats in the motor and he will build the appropriate size. What are you hoping to run in the 1/8 or 1/4?
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
04-29-2011, 09:50 PM | #3 | |
SST...
Drives: SST Camaro 2010 Join Date: Oct 2008
Good choices above. Roller cam, AFR/Brodix/Dart heads. AFR is personal preference. much larger carb. 650 is too small for a built 454. Air Gap intake. Get heads with combustion chamber size for around 10:1 CR range. |
05-01-2011, 07:03 PM | #4 |
05-02-2011, 03:54 PM | #5 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Tell us more about the long block.... 2 or 4 bolt, cast or forged crank, what rods, what rod bolts, pistons, compression....
05-02-2011, 05:18 PM | #6 |
4 bolt. stock pistons crank and rods. I can change these out but was trying to find what I could do without pulling the block out.
05-03-2011, 08:18 AM | #7 |
It sounds like that is a Vortec 7400 truck engine. Those have about 9-1 compression.
With low compression and stock rods/pistons, I don't see it hitting 500 RWHP, which would be about 600 hp at the crank. I wouldn't want to be doubling the hp of an engine on stock rods/rod bolts. For that power level, my opinion would be to build it from the ground up. It's going to need more compression, better rods.... all forged, studs.... In the car, you could put a little more cam in it and a bigger carb (750/800 Holley Double Pumper). I wouldn't put high dollar heads on a stock short block. Find out your exact compression ratio, and talk to some of the cam makers for a cam suggestion. It's going to need to be a pretty mild cam with that compression. A cam and carb should really wake it up. But I'd save those real big power levels until a full ground up rebuild. |
05-03-2011, 09:17 AM | #8 |
You listed your hp intent, but do u want it to run? As an example based off my 454. Its basic, that its a ~9:1, hyd cam, dual plane intake, stock oval port heads, pro system carb, msd ignition, th400 and on drag radials, 4.56gears ran 7.5 and 7.4 in the 1/8th no juice. In the quarter with a progressive shot 20 off the line ramping up to 100hp over 1.5 secs out it ran 11.2, but should run 10's with a gear change. I have too much gear in it as i was hitting the rev limiter 1000ft out. It ran 9.2 at a 1000ft. 1.4 at 60ft. After i change out the rear, i will add a little more juice off the line. My car is tubbed, but has a full interior except no rear seat. I actually have added weight back into the car since owning it and for it to run those times with not much in it I think is pretty good.
If you dont plan to change out the pistons i would look at the oval port race rite heads from Brodix and a good hyd roller. Not sure u will see 500rwhp though unless u go more radical in compression, cam, and head choice.
05-04-2011, 11:25 AM | #9 |
A few pictures to let you guys know that I have a real car.
05-04-2011, 11:25 AM | #10 |
05-04-2011, 11:26 AM | #11 |
Tags |
454 engine heads cam |
Similar Threads | ||||
LS3 Forged Stroker Engine Build By Jannetty Racing | Slim2SS | Forced Induction - V8 | 39 | 08-30-2010 01:28 PM |
GM Reveals 2011 Chevrolet Silverado HD | FenwickHockey65 | General Automotive + Other Cars Discussion | 55 | 03-04-2010 01:56 PM |
The BEST Break for a new car. "very long" | Darin Morgan | General Automotive + Other Cars Discussion | 346 | 02-04-2010 06:49 PM |
Camaro ls3 news...true or false? | Dark Knight | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 74 | 06-05-2008 05:29 PM |
Axial Vector Engine | Mr. Wyndham | General Automotive + Other Cars Discussion | 6 | 06-20-2007 04:00 PM |
