Old 10-02-2012, 02:42 PM   #1
Lee0123567
Nope! v6.
Lee0123567's Avatar
Drives: 2001 SOM v6
Question Stereo problems..
Okay so here's the run down. My stereo/radio goes off and on just out of the blue. It does it when I'm listening to a CD and the radio. Sometimes it turns back on real quick but most of the time it takes awhile if it even if does come back on.
Anybody have any idea what it could be?
3" Magnaflow cat-back, MSD 8.5mm Super Conductor Wires, NGK Iridium plugs, KN Air Filter, Halo Headlights, Shaved Air Lid, Chrome ZR1 Rims, SS Hood Scoop/Spoiler
Lee0123567 is offline   Reply With Quote
Old 10-02-2012, 03:03 PM   #2
02SS#214
02SS#214's Avatar
Drives: 2002 Camaro NBM Hartop SS
Is it the monsoon system? If so, the head unit or amp
02SS#214 is offline   Reply With Quote
Old 10-02-2012, 03:55 PM   #3
Lee0123567
Nope! v6.
Lee0123567's Avatar
Drives: 2001 SOM v6
Yeah it's the monsoon system
Old 10-02-2012, 04:19 PM   #4
02SS#214
02SS#214's Avatar
Then it's more than likely either your head unit or amp
Old 10-03-2012, 12:43 PM   #5
Bulldogwinters
SS #2431
Bulldogwinters's Avatar
Drives: 2001 Pewter Camaro SS
I have an amp lying in my bedroom back home if you end up needing it
2001 SS Lid, LT's, 3" Y to 4" Borla XR-1 dumped, LCA, LCA Brackets, Dbl. Adj. Panhard, Subframe Connectors, Shock Tower Brace, Eibach Prokit, Eddlebrock Shocks, C6 ZR1 Wheels 18x9.5
Bulldogwinters is offline   Reply With Quote
Old 10-03-2012, 01:53 PM   #6
02SS#214
02SS#214's Avatar
I do as well, sorry no head unit though. I got rid of that this last Dec
Old 11-06-2012, 08:29 PM   #7
Lee0123567
Nope! v6.
Lee0123567's Avatar
Drives: 2001 SOM v6
Well it has been a couple of weeks and my radio is still acting funny. I've figured out that when it goes dead to smack the dash above the head unit and it'll turn back on.
Old 11-06-2012, 08:56 PM   #8
insidethreat07
insidethreat07's Avatar
Drives: 2001 Camaro 3.8
If you need a head unit I have one. Hell ill even let you put it in and see if it solves your problems. If so you can just pay me whatever
2001 Camaro V6
2016 Camaro 2SS
insidethreat07 is offline   Reply With Quote
Old 11-18-2012, 10:22 PM   #9
Chevyguybc
Drives: Camaro SLP zl575
I need a head unit, my monsoon is not giving proper signal to some of the speakers...
Mine is a 2002 camaro monsoon
Where is the rear amp located?
Chevyguybc is offline   Reply With Quote
Old 11-19-2012, 10:06 AM   #10
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
Bad solder from the factory.. Mid 90s Delco are POS. The work GMC is losing the radio in a similar manner, FM band only.
Amp is located inside the trunk behind the spare tire. All of that is inside the right side interior panel that has the screw pegs holding it on.
If you need a new head unit and want to see something cool: http://www.doubledmods.com/
Sells refit kits with harness plug and play adapters for touch screen units. No cutting, just plug in. Kit with head unit on average runs you 600 usd. Yes you can use radio controls too. Even has a few that run Bluetooth like MyLink or Sync. Plan on upgrading mine when the solder fails.
Zabo is offline   Reply With Quote
Old 11-19-2012, 09:19 PM   #11
insidethreat07
Spare tire area I believe, pass side
2001 Camaro V6
2016 Camaro 2SS
