03-10-2016, 06:42 PM | #1 |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
Tires... Tires and Tires! Tire Question
So I have the MRR FS01's and I currently have tires on loan (Pirelli P-Zero's)
I was originally not going to swap the tires and buy these, but the size in general has me wanting a slimmer side wall. These 35's just feel to tall. Currently: 285/35/20 305/35/20 So my question.... What sizes should I get front and back if I go with 30 sidewall height in the back? (305/30/20) I ask, as the 305/35/20 rub on the interior in the wheel liner. If I go 30 in the rear is 35 up front still good? do I go 30 upfront like the 1LE is equipped with? What is the proper size to make these tires not look like odd sizes tires on the car front and back?
03-10-2016, 07:08 PM | #2 |
SABIO
Drives: 2016 CAMARO 1SS Join Date: Jul 2015
305/30/20 = 27.2" rear
265/35/20 = 27.3" front Or 285/30/20 = 26.8" front
03-10-2016, 07:11 PM | #3 |
Lethal Camaro
Looking like 285/30 & 305/30 will look okay. Downside... I can only find the rears in stock. Tirer Rack seems to only have PSS Cup 2's which is was pricey. I am looking to snag P Super Sports
03-10-2016, 07:17 PM | #4 |
SABIO
Rear tire will always look bigger, you have an 11" rim.
If you went with a 10" rim on the back..... then you could get matching tires. $$$$$$$$$
03-10-2016, 07:30 PM | #5 | |
Lethal Camaro
will help with that staggered raked look as well that I like.
03-10-2016, 07:47 PM | #6 |
Drives: 2022 Lt1 A10 Join Date: Nov 2015
Why do you think they feel too tall? The gen5 had 28.4 inch diameter and the 305/35/20 are about the same. Don't you want to fill up the wheel well? The ride is already firm, if you go down to a 30 series tire its gonna be stiffer yet. I think the 30 series will be shorter then stock is, downside is they'll hate pot holes
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
03-10-2016, 07:48 PM | #7 |
SABIO
It can't get any closer than that. Unless you put a smaller tire on the back.
Drop the rear to a 295, you will eliminate any rubbing concerns and hit a 27" diameter. Always tough choices when a good chunk of coin is involved. I think the 285/30 & 305/30 combo is good. It will give it that classic muscle car look where the back is slightly beefier. Also a fan of Pirelli, tracked some Zeros awhile back. Heat up real nice and stick. Not a fan of the price... :(
03-10-2016, 07:55 PM | #8 | |
Lethal Camaro
I would agree if I was going stock size with the 30's, but a 285 and 305 with 30's are still fairly good sidewall height compared to a 30 on a 245 tire.
03-10-2016, 07:56 PM | #9 |
Lethal Camaro
Here is a 245/30 vs a 285/30. the 245 looks very skinny and the 285 looks somewhat normal (to me)
03-10-2016, 10:06 PM | #10 |
Drives: 2016/SS Has had 4 Gen 5's Join Date: Dec 2015
I just want a good looking wheel I can buy and use my Stock tires ?????? And not spend an arm and a LEG on wheels??????? VENDORS Somebody Please help ME please Help ME
SnoWhite |
03-10-2016, 11:55 PM | #11 |
Drives: toyota mr2 Join Date: Dec 2008
That tire size comparison/visualizer is cool... Where can I find it/use it?? Thanks. I've seen calculators... but nice to have visual there too.
03-11-2016, 06:52 AM | #12 |
Drives: Varies Join Date: Dec 2009
I am getting 20x9.5 and 20x11 3 pc wheels eventually, I was going to run 265/35/20 front and 305/30/20 rears, was going to go with NITTO NT555G2s. It's a street setup, I don't see a need to get ultra wide tires on the front personally.
03-11-2016, 02:19 PM | #13 | |
Lethal Camaro
https://tiresize.com/calculator/
03-12-2016, 09:41 PM | #14 |
Lethal Camaro
I gave up waiting on Michelin's. Snagged P Zero 285/30ZR/20 & 305/30ZR/20. Both 99Y rated.
