03-21-2021, 01:26 PM | #1 |
Drives: 2010 Camaro 2SS Join Date: Mar 2018
Ac plug
Looked everywhere in the haynes Manuel no where does it say the torque for these bolts
03-21-2021, 02:26 PM | #2 |
I wound up just tightening them down 'good enough', since you are dealing with soft aluminum and a sealing point there. Overtightening you run the risk of stripping or distorting the metal/rubber o-ring.
I know that's not very helpful, but I could also not find the torque values for this, and I have been totally leak free and my air is ice cold. I also made sure to replace every single seal in the AC system and the desiccant bag. You can get a bag of GM seals for like $15 or less online.
03-21-2021, 04:23 PM | #3 |
alot of the AC plugs did not have any gasket that i know of... is that why i had a small leak in the system?
03-22-2021, 07:25 AM | #4 |
Drives: 2014 camaro SS Join Date: Jan 2019
sealed by o ring, just has to be tight enough to crush the o ring. if you are a mechanic you will know when it is tight enough. if not, take to someone who does
