09-14-2012, 05:26 PM | #1 |
Slow v6
Window error after installing CAI Help!
This is for a friends cai btw!
Okay so he installed the cai and is giving him a "put window down the up" error. Does anybody ever have this problem and have a fix? or is it need to go to the dealership. he has a 2010 rs stock with just a vararam cai. I'm going over there in a hour to go check it out and wanting to know any input before going over Thanks!, Matt
Full bolt on 2lt/Rs. Any questions? always a pm away!
Obx/Mace/Rx/Mrt/Vararam/Bcam/4.11 Gears/SS Brakes USAF. Stationed in TX |
09-14-2012, 05:43 PM | #3 |
Drives: 2010 RJT 2SS/RS Join Date: May 2012
09-14-2012, 05:54 PM | #4 | |
Slow v6
already tried and said it did not fix issue. Oh and yes is disconnected battery
09-14-2012, 06:11 PM | #5 |
Drives: 2012 45 Anniversary Vert Join Date: Apr 2012
should say something like
Open then close the driver side window....this may take a few times to take, hint is to keep pressing the down button a second or two after the window is down, and a second or two after the window is up... then it says, open then close the passenger side window (the first time I did this i did not catch the passenger and thought it was doing it again), follow the above for this as well if he has a vert it goes to the back window then. its a bit buggy, ive had to open and close the first window several times before it took If its not saying to open then close it is a diferent alarm |
09-14-2012, 06:39 PM | #6 |
He's going to close the window all the way down and hold it. Then bring the window up and hold it for like 5 seconds or until the message goes away. I had the same problem but it's fixed now.
|Trifecta Tune|Custom Magnaflow Exhaust|Cold Air Inductions C.A.I.|BBK LTs w/ HFC|Anvil Rear Notch Glossy CF Spoiler|Body Color Heritage Grille|10 spoke polished ZL1 replica wheels|VMAX ported TB|RS Headlights|Night Owl RGB Halos
