12-07-2010, 08:47 PM | #1 |
Drives: racecars Join Date: Dec 2010
Alignment issue ???
I hit an icy patch while going around a corner at about 15-20 mph, I had the wheel cranked all the way to the left and then it hit. BANG !! The tire is not flat, but the steering wheel shakes bad at 40 mph, violently above that. Suspension or just alignment ?? The components looked in good shape, bent rim? I just got new rear tires, good thing, if the back end had come around I know for a fact it wouldve been a lot worse...
12-07-2010, 09:13 PM | #2 |
Drives: 2011 Black 2SS/RS L99 on order Join Date: Oct 2010
Could be a bent rim or suspension component. I'd say rim with the way the wheel shakes. Get it checked out
Frank and Kim
2011 SS/RS Black on Black (Born 11/18/2010) 2011 Hemi Ram Crew Cab 1500 4X4 Black on Black 2009 HD Street Glide 2005 HD Fatboy |
12-07-2010, 10:51 PM | #3 |
Banned
Drives: 2003 Cobra Convertible Join Date: Feb 2009
something is bent. an alignment wont be able to fix it, sorry.
12-08-2010, 11:31 AM | #4 |
Drives: 2010 Camaro SS Join Date: Mar 2010
That's what the warranty is for.
12-08-2010, 11:34 AM | #5 |
knows 2 facts about ducks
I don't think warranty would cover a bent rim and/or suspension. They might say you hit something. Which I'm guessing you did by the sounds of it.
12-08-2010, 05:39 PM | #6 |
ya same thing happen to me. took it to the dealership and warranty doesnt cover it because u hit something. turned out my lower control arm was bent.
12-08-2010, 05:50 PM | #7 |
Drives: 2011 2SS Join Date: Jun 2010
If you were not 5 hours from me, I would fix it for free. I have a lift which is a life saver. If you don't have a buddy with one, put it on stands and figure out what you bent. Use spray paint before you take it apart so that you can put it back together pretty close to aligned before you take it in for alignment. The car is almost new, so nothing should be hard to get apart.
Good luck! |
12-08-2010, 07:04 PM | #8 | |
1100, I have a $500 deductible for warranty which will cover it. What is up with Infiniti's Stability Control ??? I had it on the whole time INTENTIONALLY so this would not have happened, like in my old 06 Acura RL where it intervened and saved me in a similar situation. In this video you can see a Chrysler 300 goes around a wet corner in the same way I did(though mine was just a 90 degree left turn), and the stability control intervened and prevented the car from crashing. WHY DIDNT MINE DO THIS ?!?! I also was able to kick the tail out and then it swung around the other way almost spinning out before Stability Control Kicked in earlier that day, if its this bad in the wet how in the HELL can it be any good in the snow ?? I love my Infiniti, dont get me wrong, but this is ridiculous....
12-08-2010, 07:08 PM | #9 |
Need new control arms/tie rods, etc... it's a chrome wheel so may need to replace it, dont think its bent very much because it's like a super high strength alloy ??
12-08-2010, 07:42 PM | #10 | ||
12-08-2010, 07:48 PM | #11 |
Well I had it on so this would not happen, if it wasnt on I would blame myself haha... I was going around the corner slower than I was the previous corner yet somehow still had ALOT less grip, I was getting a feel for the road then that happened. I thought the whole point of stability control was to prevent this, it certainly did in my old 06 Acura RL... But it I was going slightly uphill on the left hand turn, it was banked in the exact opposite of what I needed it to be, the stability didn't cut in though(it had when the rear slipped when I was getting on the on ramp to the highway, whatever)...
12-08-2010, 08:26 PM | #12 | |
12-08-2010, 08:36 PM | #13 |
Similar Threads | ||||
Wheel Alignment Questions | OldSchool | Suspension / Brakes / Chassis | 2 | 09-17-2010 11:07 AM |
Lowering Alignment Issue | obe1 | Suspension / Brakes / Chassis | 38 | 03-05-2010 03:28 PM |
New issue of Camaro Milestones magazine? | slick rick | 5th Gen Camaro SS LS LT General Discussions | 24 | 03-02-2010 11:43 PM |
HVAC issue... Anyone had this problem? | nashstat | 5th Gen Camaro SS LS LT General Discussions | 8 | 01-27-2010 04:19 PM |
TRANSMISSION ISSUE already | Sidewayz_510 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 12 | 08-18-2009 04:11 AM |
