07-08-2012, 07:11 PM | #1 |
Butter Bar!
Drives: 2011 SS, 1998 Trans Am Join Date: Dec 2010
Heads and Cam swap
Instead of completely derailing Bulldog's thread I decided to make a separate thread about my heads and cam swap. I've been slowly taking the car apart for the last few days and got the heads off today. I'll tackle the cam tomorrow. Here is how she sits for now.
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension 2004 GSXR 1k, Matt Mladin Edition |
07-08-2012, 10:26 PM | #2 |
SS #2431
Drives: 2001 Pewter Camaro SS Join Date: Jul 2009
Lookin good so far man! keep us updated!
2001 SS Lid, LT's, 3" Y to 4" Borla XR-1 dumped, LCA, LCA Brackets, Dbl. Adj. Panhard, Subframe Connectors, Shock Tower Brace, Eibach Prokit, Eddlebrock Shocks, C6 ZR1 Wheels 18x9.5 |
07-09-2012, 12:01 PM | #3 |
not afraid of the wall
Drives: Camaros Join Date: Apr 2010
Awesome!
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z |
07-09-2012, 12:14 PM | #4 |
What heads r u puting on?
top 10 reason why real men drive stick. 10. A manual transmission is the ultimate in control 9. You can use automotive jargon and not sound like a total tool 8. You can't spell "manual" without "man" 7. Manual transmissions prove you can do more than one thing at a time 6. You can't drift in an auto 5. You can't pull fancy moves in an automatic 4. You get better fuel economy with a stick 3. You’ll never look like a chump if you can drive stick 2. Manual transmission cars are faster 1. Women like a guy who is good with his hands. |
07-09-2012, 08:43 PM | #5 |
Butter Bar!
Ported 243's. So today was one of those days where if somebody came by it'd look like you didn't get any work done. Got about 2 hours in after work and it was all devoted to getting the balancer off. The first puller I rented broke, so I got a bigger one. It worked until the last 1/4 inch. There was no more thread left on the crank bolt so I had to resort to 3 lb sledge hammer and a crowbar. Luckily the puller had these nice hooks to beat on and I worked it off slowly. Some newer pics. I hope tomorrow goes better so I can get the cam, oil pump, timing chain on.
07-10-2012, 06:33 AM | #6 |
07-13-2012, 12:12 AM | #7 |
Butter Bar!
I'm slowly whittling away at it. I did a few hours yesterday and got the cam out and the new one slid in. Before I did that I pulled the lifters and trays out and I cleaned all the passenger side head bolt holes. They had a lot of crap in them so it took awhile.
Today I dropped the oil pan a bit, pulled the old oil pump and finished the cam install by putting the LS2 timing chain on. I was making good time and should've gotten the timing cover back on before dark but I dropped the oil pick up tube bolt into the oil pan when I was installing the new pump. So after running to the store to get a flexible pen magnet, I was able to fish it out rather quickly. Tomorrow I am hoping to put a big dent in it since I've got the day off of work and have all day until about 1730 to work on it. Yesterday: How she sits now:
07-17-2012, 12:12 PM | #8 | ||
Butter Bar!
It's done! First start up was actually last night but somehow one set of coil packs was plugged in the wrong way. I let a friend help me and it ended up plugged in 7-5-3-1 instead of 1-3-5-7 and #7 had a pin bent so it wasn't actually plugged in.The car back firing so bad I had a headache afterwards; it sounded like gun fire coming out of the garage.
Anyway I decided to go down and trouble shoot this morning and found the wires like that. 5 min later I tried it again and she fired right up! Here's an idling video once the car was more warmed up.
07-17-2012, 01:34 PM | #9 |
Sounding good. When/where is the tune?
07-17-2012, 06:00 PM | #10 |
Butter Bar!
I just dropped it off with John at Broadview Auto Service. He does good street tunes for the cars. He's done all the tuning on the car up until now, and has done a lot of tunes for other LSx cars in the area.
07-17-2012, 09:24 PM | #11 |
Nope! v6.
Drives: 2001 SOM v6 Join Date: Mar 2012
Damn, i wish my sixxer could sound like that!
3" Magnaflow cat-back, MSD 8.5mm Super Conductor Wires, NGK Iridium plugs, KN Air Filter, Halo Headlights, Shaved Air Lid, Chrome ZR1 Rims, SS Hood Scoop/Spoiler |
07-17-2012, 09:27 PM | #12 | |||
2001 Camaro V6
2016 Camaro 2SS |
07-17-2012, 10:20 PM | #13 | |
Gunning for Sixth
Drives: '03 ZR2 Blazer Join Date: Sep 2008
..I need more money. :(
Someday, Fenix.. someday. *pats dash* Also, "That sounds awesome.." Instantly my brain went this: Last edited by Zabo; 07-17-2012 at 10:34 PM. |
07-18-2012, 01:08 PM | #14 |
SS #2431
Man that sounds amazing! I like the 113 LSA, still has that definite chop in the idle but not as noticable. Are you planning on dynoing to see what power the package added?
