09-07-2014, 12:44 PM | #1 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
2 catch can questions
1) Anyone know if the plastic fittings on a RX catch can can be replaced? I think I have leaky fittings. If I spray fluid near the fittings my AFR drops.
2) Whats the difference in Elite vs Apex catch cans other then the bracket?
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
09-07-2014, 06:38 PM | #2 | |
the Elite and Apex cans are very similar aside from the bracket. i am going to go with the Apex can personally. |
09-07-2014, 06:38 PM | #3 |
Fitting can be replaced on rx can. which one is leaking?
I don't know anything about 2nd question |
09-08-2014, 07:25 AM | #4 |
both...leaking air. Was wondering if they have to be drilled out to replace them.
09-08-2014, 10:05 AM | #5 |
Do somethin fun every day
If it were me, I would pick up an Elite or Apex can and not bother with the RX can. So much easier to empty too.
09-08-2014, 10:54 AM | #6 |
I am tempted, but its money down the drain yet again...may come to that. I wish i knew whats the internal difference if any between the elite and apex. I like the Apex bracket better cause the elite puts the can in the way of my nitrous solenoids.
09-08-2014, 11:03 AM | #7 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
Do a Google image search on the apex and elite Catch cans. The differences are easy to spot.
As for the fittings on the RX can it looks like the outlet fitting unscrews, and the inlet just pushes on You'll probably have to contact Tracy @ rx for replacements. |
09-08-2014, 11:30 AM | #8 |
I think his can is the only one with a check valve for the exit, wonder if its really needed
09-08-2014, 12:53 PM | #9 |
I know in some instances where the car is in a cold climate area the check valve is sometimes removed because it can freeze the condensation inside it during the winter months and cause the crankcase to become over pressurized.
09-22-2014, 09:37 PM | #10 |
Drives: 2013 Black 2 LT vert Join Date: Jul 2013
well i bought a catch can from Ohio Speed, and couldnt get it hooked up as the lines they supplied are not the right size. so, need to go to Oreilley to get correct lines, as i bought this can new in January, but just now getting to get it installed with my cold air intake, which i did get installed tonite.
09-22-2014, 09:43 PM | #11 | |
Drives: 2012 SIM 2LT/1970 Camaro Join Date: Nov 2012
Enjoy!
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting |
