06-13-2012, 06:15 PM | #1 |
Drives: 1987 Corvette TPI Join Date: Mar 2012
You get this problem in your IRS too?
I got a 1987 Corvette with IRS. When I slowly reverse or slowly accelerate below like 10mph I hear a clunk only once from the right side it seems. Can somebody help, I'd rather not just go redoing everything in the rear end.
06-13-2012, 07:01 PM | #2 |
Drives: 2010 Camaro Join Date: Feb 2010
What axles are you running? I've heard of quite a few cars with a very similar issue.
06-14-2012, 05:21 PM | #3 |
As far as I know I'm running stock axles etc.
06-14-2012, 05:53 PM | #4 |
Drives: own more cars than i can list Join Date: Nov 2010
you know the C4 uses a U-joint axle and i have seen from time to time the strap that holds the u-joint cap stretch out and make a noise like this. take a look at the ends of the u-joint caps that are held down with the straps. if the strap s stretched the outer edge will look like its been freshly polished, if its not moving it will look like the rest of the cup end.
Thread Tools | |
