06-01-2011, 01:26 PM | #1 |
Exhaust Tip alignment with GFX
This past weekend Rounki and I put a stainless works s-tube catback system into my car, and holy hell it sounds great. Thanks for all the help again man!
I also installed it with the MBRP square tips for the factory GFX, and it looks great. We spent a bunch of time adjusting the whole setup to make sure the tips were where they needed to be and after much effort, they we in the right spot. They've been on for a few days, maybe 50 miles. But now it looks like they're adjusting themselves back out. I know with the rubber couplings in the back end that there's going to be some movement, but I'm worried that they'll eventually adjust themselves into the gfx and start making a hell of a lot of obnoxious noise. Is there anything I can do to readjust them and make sure they stay put?
2010 IBM 2SS/RS - T BRUTAL Matte Black Bumblebee Stripes - Unpainted Heritage Grille - Blacked Out Bowties - Stainless Works S-Tube Catback - CAI, Inc. Cold Air Intake Whiteline Rear Cradle, Rear Differential, Front Radius Rod Bushings - BC Racing BR Coilovers - Installed by Whiteside Customs |
06-01-2011, 01:33 PM | #2 |
I used the MBRP exhaust on my Dakota R/T some years ago with the rectangular tips through the rollpan used for this particular set-up. I never could get the tips to stay aligned within the openings. Hope you have better luck than I did.
(sold) 2011 SS/RS LS3 SW w/Orange Stripe, factory GFX, heritage grille with Sparks emblem, pinnacle ceramic tint
06-01-2011, 01:56 PM | #3 |
Once i had them in place I used a simple tack weld just to hold it in place, about 6 months and no issues. and the tack can simply be ground out if need be
06-01-2011, 02:30 PM | #4 |
I don't think it's the tips themselves moving, more that the entire exhaust setup is adjusting on those rubber hangers. I can definitely give them a solid tug and see if I'm mistaken though.
06-01-2011, 02:36 PM | #5 |
Drives: 2010 CGM SS/RS IO Int. Join Date: Aug 2009
Maybe let the exhaust settle out at it's final position and readjust again?
But whenever you want to readjust let me know =)
Ron K.
XS Power 1 7/8 LT Headers XS Power 3" Cat Back Vmax TB ADM Street Intake H&R Springs Forgestar F14s Tuned by HPT |
06-01-2011, 04:10 PM | #6 |
700RWHP-650TQ
Drives: 2011 Forged LS3 Supercharged/Cammed Join Date: Aug 2010
I have the Retro system and mine moves around all the time, i need to do some tack welding to get everything to stay put...i also have the ground effects and its a pain.
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL |
06-01-2011, 11:17 PM | #7 |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
We do a boatload of the MBRP Square tips and hear that they move sometimes too.
Normal for settling and since they are only, really supported by two rubber mounts, they will move here and there. Like mentioned above, about the only way to really keep them from moving at all would be to tack them in. I can personally say that it's an easy solution..... Best of luck and thank you for rockin them Ivan |
06-02-2011, 06:25 AM | #8 |
700RWHP-650TQ
This is what mine look like....At first they were sticking out like 4" now i got them down to about an inch...but i still think they need to go in. but everytime i drive it seems like they move around....annoying
You guys think this looks ok or do i have to bring them in more??....Because this is as far as i can get them to go in without cutting major components?
06-02-2011, 06:31 AM | #9 |
honestly, the dual tips @ each end look rather small and stick out too much.
ZL-1 tips looks just PERFECT! |
06-02-2011, 10:41 AM | #10 | ||
That being said, I would bring them in more if you could... Attached are what mine looked like directly after install, now they're sticking out about a half inch farther. It's really not bad and I'm completely fine with leaving them where they are as long as they stay even, which for now they are slightly off. I might try and redo it after a while to see if they keep moving, but once they totally settle I'm not going to worry about it too much if they still look good.
06-02-2011, 11:22 AM | #11 | |
700RWHP-650TQ
And those tips came with the kit, and they are the largests that fit in the GM Body kit without major modification.
06-02-2011, 11:23 AM | #12 | |
700RWHP-650TQ
yea i see what you mean....now that i look at mine more i almost like the no tip at all look but i ran without one for 2 weeks and got some discoloration going on, i buffed it out but dont want to be doing that every week.
06-02-2011, 11:33 AM | #13 |
700RWHP-650TQ
Ok well......I got out put the thing on the ramps loosened all the clamps...took a 2x4 with a blacket wrapped around it and smashed away on the tips hoping to move it in, after smashing my middle finger once and throwing the mallet out the gargage and into the street they did move in a bit more.
However, i dont know if anyone else is noticing this but when the car heats up the damn tips emerge from the bezel and then when it cools its contracts in, about a inch movement....now i just give up Here are updated ones
06-02-2011, 11:42 AM | #14 | |
Drives: 2010 2SS/RS M6 Black on Black Join Date: Jan 2010
I would think you could make a steel strap that would have a press fit over the hanger arm on the car and on the muffler to reduce the up and down movement from the rubber, and that may also reduce front-to-back movement as well, but may introduce some noise/vibration into the car.
Meh
Similar Threads | ||||
V8 Camaro Aftermarket Exhaust Video Clips Compilation | tjbusa | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 591 | 07-06-2022 08:38 AM |
chicken or egg? exhaust vs gfx??? | Drago77 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 14 | 02-28-2011 06:27 PM |
MAGNAFLOW Cat-Back / Axle-Back Exhaust Systems | FREE Shipping | Apex Paul | V8 Bolt-Ons & Tunes | 134 | 01-24-2011 12:56 AM |
2LT exhaust options | Guardian1816 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 3 | 01-12-2010 09:28 PM |
SS Exhaust Tip Diameter? | sen10l | Cosmetics and Lighting Modification Discussions | 12 | 11-20-2009 06:08 PM |
