05-07-2014, 08:41 PM | #1 |
Drives: 2013 1LE Join Date: May 2013
1LE TIRE & WHEEL ?
What is a full set of tires & wheels worth? I have the set off my 2013 1LE with 1,000 miles on them. Been running around on drag radials and front runners and really don't care to go back to stock. Thanks.
05-07-2014, 08:47 PM | #2 |
1LE.SS
What tire and wheel combo did you go with? Seen on here that a set went for $3600.
05-07-2014, 08:57 PM | #3 |
05-07-2014, 09:04 PM | #4 |
1LE.SS
Very nice! Did you do anything to the center section(track unit or gears)? Heard some stories about failed rearend's from 1le's and the dragstrip.
05-07-2014, 09:06 PM | #5 | |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
-Matt
05-07-2014, 09:14 PM | #6 |
Thanks Matt
05-07-2014, 09:16 PM | #7 |
I was wanting a 2nd set, but at $1095.00 per wheel....i dint think so. I just got these last night.
05-07-2014, 09:18 PM | #8 |
I only been to the track 2 times last season. First outing could not get a good launch [2.0 60 ft.] 2nd time out fried the clutch trying to slip it. Now I installed a Mantic clutch, G- force 1500 hp axles and Alu. drive shaft. Need to do a tru-trac or a 9 inch.
05-07-2014, 09:24 PM | #9 |
Call Me"Doc"
Drives: 2014 2SS/RS 1LE BLACK Join Date: Apr 2009
Why do those rims have Z28 on them?
05-07-2014, 09:25 PM | #10 |
05-07-2014, 09:26 PM | #11 |
1LE.SS
Good luck, if you don't mind I'll try to keep track on your build.
05-07-2014, 09:45 PM | #12 |
Call Me"Doc"
05-08-2014, 01:31 AM | #13 |
Drives: 2015 1SS, 1LE, Recaro, NPP Join Date: Apr 2014
How much did those cost you Cornerspeed92?
