Old 03-22-2011, 05:43 PM   #1
JTC/C5
JTC/C5's Avatar
Drives: 2010 2SS L99
GM USES CRAPPY LIFTERS
So my check engine light comes on sat. night and today its still on so i get a diagnostic check from On Star and it comes back with some sort of emissions failure...then without hesistation i take it to my tuner at Tune Time Performance where they had a tech scan my car... it came back with 2 codes...one was for a misfire which it def was doing..So after trying to let the car sit and get cool so he could hear it from a cold start i was there all day.. LOng story short they found metal shards in my oil and with the symptoms the car had with all the misfires especially at cylinder #5 and #7 (not at idle but as soon as u got to 1500 rpm it was constant) the tuner figured it was the lifters GM uses..they ware quickly(springs)
Oh by the way i only have 8000 miles on it lol. Luckily he had a friend at pine belt chevy in eatontown that will do the work covered under warranty..my car has alot of mods and dealers are sometimes sketchy when it comes to covering the work when you have aftermarket work done to your..The shop foreman said as long as i didnt have a supercharger, cam or heads done he said he will do all the work...good to know people...
so what i thought would be a short day and thought it would just be something they could fix on the scan with computer turned out to be a nightmare...
just a heads up to all you guys,,, im sure i wont be the only one ..
what sucks is they will just replace the lifters with the same old lifters and it will prob happen again..i guess there built to fail..????
makes me just wanna do the cam and lifters now hahaha...
To Be Continued
JTC/C5 is offline   Reply With Quote
Old 03-22-2011, 05:57 PM   #2
Kermit1
Kermit1's Avatar
Drives: 2011 Callaway 2SS/RS
2 words....Lowest bidder
Kermit1 is offline   Reply With Quote
Old 03-22-2011, 06:24 PM   #3
JTC/C5
JTC/C5's Avatar
To Be Continued
Old 03-22-2011, 06:27 PM   #4
wullger
Supercharged
wullger's Avatar
Drives: 2010 Camaro 2SS/RS
There's a known TSB (service bulletin) out for this issue. I'll see if I can find it and add it to my reply here. This would've been covered anyway, no worries
EDIT: Is this what you're experiencing? http://www.camaro5.com/forums/showth...82#post2713182
Originally Posted by MS3DALE View Post
Service Information
Document ID: 2547180
#10-06-01-007B: Active Fuel Management (AFM) Engine, Valve Lifter Tick Noise at Start Up When Engine Has Been Off for 2 Hours or More (Evaluate Noise and/or Replace Valve Lifters) - (Nov 17, 2010)
Subject:Active Fuel Management (AFM) Engine, Valve Lifter Tick Noise at Start Up When Engine Has Been Off for 2 Hours or More (Evaluate Noise and/or Replace Valve Lifters)
Models:2007 Buick Rainier
2009 Buick LaCrosse Super, Allure Super (Canada Only)
2007 Cadillac Escalade
Built Prior to April 1, 2006 with 6.2L Engine RPO L92 (These engines were built with AFM Hardware but the AFM system was disabled)
2010-2011 Cadillac Escalade
2007 Chevrolet Monte Carlo
2007-2009 Chevrolet Impala
2007-2011 Chevrolet Avalanche, Silverado, Suburban, Tahoe, TrailBlazer
2010-2011 Chevrolet Camaro SS
2007-2011 GMC Envoy, Sierra, Yukon
2007-2008 Pontiac Grand Prix
2008-2009 Pontiac G8
2007-2009 Saab 9-7X
Equipped with AFM (Active Fuel Management) and V8 Engine RPO L76, L94, L99, LC9, LFA, LH6, LMG, LS4, LY5 or LZ1
Attention: This bulletin only applies to the AFM V8 engines listed above. It DOES NOT apply to Non-AFM Engines. If you are dealing with a Non-AFM engine that is experiencing a similar noise, please refer to Engine Mechanical > Diagnostic Information and Procedures > Symptoms in SI.
This bulletin is being revised to add the 2011 model year. Please discard Corporate Bulletin Number 10-06-01-007A (Section 06 - Engine/Propulsion System).
Condition
Some customers may comment on an engine valve lifter tick noise that occurs after the engine has been shut off for at least two hours. The tick noise may last from two seconds to ten minutes.
Cause
This condition may be caused by any of the following:
• Aerated oil in the valve lifter body, resulting in the valve lifter being unable to purge the air quickly.
• A low engine oil level or incorrect oil viscosity.
• Dirty or contaminated oil.
• A low internal valve lifter oil reservoir level.
• Debris in the valve lifter.
• A high valve lifter leak down rate.
Correction
If the SI diagnostics do not isolate the cause of this valve lifter tick noise and normal oil pressure is noted during the concern, perform the following steps:
  1. Inspect the engine oil condition and level. Refer to Owner Manual > Service and Appearance Care > Checking Things Under the Hood > Description and Operation > Engine Oil in SI.
    ⇒If the engine oil is more than one quart low, an incorrect oil viscosity is being used or if poor quality/contamination is observed, change the oil and filter.
  1. Note: Allow at least a two hour soak time between engine OFF and start up when evaluating the tick noise.
  2. Start the engine and evaluate the valve lifter tick noise.
    ⇒If the valve lifter tick noise is still present, replace all 16 valve lifters. Refer to Valve Lifter Replacement in SI.
Note: A V8 AFM engine requires 8 AFM lifters and 8 non-AFM lifters for a total of 16 lifters.
Part Number
Description
Qty
12576400 - Non AFM Hydraulic Valve Lifter - Qty.8
12632143 - AFM Hydraulic Valve Lifter - Qty.8
Warranty Information (excluding Saab Models)
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
J0627
Valve Lifter Replacement - Both Sides
Use Published Labor Operation Time
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2011 General Motors. All rights reserved.
2SS/RS IBM A6, White Rallies
Ordered: 4/30/09 Delivered: 8/18/09
Appearance Mods:
Heritage Grille, ZL1 Replica Wheels
Performance Mods:
Flowmaster ARH Cat-Back Exhaust, ADM CAI, ADM L99-LS3 Conversion, ADM LSA Supercharger Kit, Lingenfelter GT9 Cam, Stainless Power Headers, Detroit Speed Sway Bars, ZL1 Fuel Pump
581 rwhp/535 lb/ft tq
wullger is offline   Reply With Quote
Old 03-22-2011, 06:31 PM   #5
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
I'm glad I'm having my lifters replaced while my cam is going in.
Sorry to hear about your problems, but I'm glad to hear it's being fixed under warranty.
Old 03-22-2011, 06:36 PM   #6
JTC/C5
JTC/C5's Avatar
Thanks for that post... I guess thats whats wrong then..what a pain in the ass... Yeah im glad its being covered... I guess ill have to wait and see if thats all that is wrong...
Hopefully get in there by this thur or friday
To Be Continued
Old 03-22-2011, 07:38 PM   #7
wullger
Supercharged
wullger's Avatar
I need to take my car in for that same issue at some point--or at least have it inspected. Let us know how it goes.
Appearance Mods:
Performance Mods:
Old 03-22-2011, 07:45 PM   #8
victoryred1ss
victoryred1ss's Avatar
Drives: 2010 SS M6 2016 2SS A8
New lifters they are using with the AFM (l99). We wont see too many issues with with ls3 lifters.
TVS 2300 721RWHP 686RWTQ
Built by Me
Suspension done by JDP
Tune done by JRE
victoryred1ss is offline   Reply With Quote
Old 03-22-2011, 07:58 PM   #9
JTC/C5
JTC/C5's Avatar
So does anyone know if there installing an upgraded lifter? i cant imagine they would use the same old defective lifter????
To Be Continued
Old 03-22-2011, 08:31 PM   #10
OBSSEST
Drives: 2010 Camaro 2SS RS, Black
Another great example of how the "Tuned car = voided warranty" is more GM fueled paranoia than reality.
Glad this worked out for you.
OBSSEST is offline   Reply With Quote
Old 03-22-2011, 08:40 PM   #11
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
CTSV racing lifters are cheap @ $350 for the set. Designed for sustained high rpm use.
Ovenmitt is offline   Reply With Quote
Old 03-22-2011, 08:42 PM   #12
JTC/C5
JTC/C5's Avatar
that sounds good but i doubt they will use them... I guess they have a revised lifter to use since there was TSB issued
To Be Continued
Old 03-22-2011, 08:43 PM   #13
mikeSS
mikeSS's Avatar
Drives: 2015 c7
i only hear bad things about the l99 lifters.
Old 03-23-2011, 04:55 AM   #14
Slowhawk
Drives: 1999 Trans Am
My L99 collapsed a few lifters at 400 miles.They pumped back up and where fine but we pulled them at 600 miles while getting rid of the DOD/AFM and installed LS7 lifters. I've seen alot of the CTS-V lifters fail throughout the years. The LS7 lifters are $120 or so and we use them in all the builds without issue's.
Slowhawk is offline   Reply With Quote
L99 lifters tapping 2010BumbleBee Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 159 04-08-2015 02:05 AM
LS7 Lifters Styffydawg Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 01-25-2011 11:41 AM
amf lifters? woodside783 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 32 12-06-2010 06:21 PM
warranty on noisy lifters with a tune? ambjocky Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 09-07-2010 08:51 PM
New Lifters at 30k? azvren Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 09-01-2010 04:01 PM
