Old 07-17-2014, 05:59 AM   #1
Intimidator333
Intimidator333's Avatar
Drives: 2010 Camaro 2SS/RS Inferno Orange.
1LE Goodyear F1 on 9in SS/RS Rears?
A guy locally has a stupidly good deal on some 1LE Goodyear F1's 285/35/20 and am wondering if they would work on 9in SS/RS wheels all 4 corners?
Thanks.
2010 Camaro 2SS/RS Inferno Orange Metallic LS3. K&N Cold Air Intake. Borla Atak Axle Back. BMR 1" Drop.
Intimidator333 is offline   Reply With Quote
Old 07-17-2014, 06:03 AM   #2
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
NO, very dangerous. 10" wheel at least.
Scott@Bjorn3D is offline   Reply With Quote
Old 07-20-2014, 03:33 AM   #3
fly2hip8
Drives: 2013 Camaro 2SS
Actually, if you look at the recommended tire size sticky, It says 9-10 for 285.
Recommended 20" tires for 2010 Camaro
245/45-20 = 28.7" tall, 8.0-8.5 wheel
255/45-20 = 29.0" tall, 8.0-8.5 wheel
265/40-20 = 28.4" tall, 8.5-9.0 wheel
275/40-20 = 28.7" tall, 9.0-9.5 wheel
285/40-20 = 28.9" tall, 9.0-10.0 wheel
295/35-20 = 28.1" tall, 9.5-10.5 wheel
305/35-20 = 28.4" tall, 10.0-10.5 wheel
315/35-20 = 28.7" tall, 10.5-11.0 wheel
fly2hip8 is offline   Reply With Quote
Old 07-22-2014, 07:30 AM   #4
Denis
Denis's Avatar
Drives: 2010 SS
the issue is more that the tire is only a 27.85" diameter tire and your OE front pirellis are a 28.68" diameter tire. so your rear tire is going to be .83" shorter than your fronts.
thats if you're running the OE 245/24-20's up front.
Old 07-22-2014, 09:35 AM   #5
ytown87
ytown87's Avatar
Drives: C6 Corvette
you would want 285/40/20 if running stock 245/45/20 up front. will throw off traction control and anything else associated with due to diff in diameter. 295/35/20 is about as narrow as you can go with 35 side wall and keeping stock fronts
2008 C6 m6. Carbon creations front/rear carbon fiber wodebody fenders. Carbon fiber hood carbon fiber roof hoop carbon fiber zr1 extreme spoiler. NW 102mm tb. Ported intake manifold. Cometic .040 head gaskets. LG motorsports G6x3 cam. DSX flex fuel sensor. AEM methanol kit. Z06 brakes. Ebiach sway bars. ZR1 rep wheels and Nitto Invo tires. Monster stage 3 twin disc clutch. MGW short shifter. Corbeau race seats. Gforce race harnesses. SLP loudmouth 2 mufflers. Carbon fiber exhaust tips. RPM stage 4 transmission and Stage 3 rear diff. 3.73 gears. Vararam cai. Kooks 1 7/8 headers and x-pipe.
ytown87 is offline   Reply With Quote
Old 07-22-2014, 09:39 AM   #6
Matze
German Representative
Matze's Avatar
Drives: 2010 Camaro 2SS/RS IOM
He wants to run the 285s in all four corners. But the rear 20x9 from the SS can't go in the front, they stick up too much.
Mathias
Apex intake scoop, CAI intake, Vmax ported throttle body, Kooks LT headers, stock exhaust with NPP mufflers, BMR trailing arms, toe rods, cradle bushing inserts, Hex Vents, Factory Reproduction 41 20x9 and 20x10
Matze is offline   Reply With Quote
Old 07-22-2014, 09:44 AM   #7
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
I ran Michelin Pilot Super Sports on my 9" wide RS/SS wheels without issue.
It's pretty much a waste of tread, though, as it's kinda smashing 10 pounds of shit in a 9 pound box. The only reason I did it is because I was waiting for my new wheels to get in! Then I put those tires on the new, wider wheels.
shibbs is offline   Reply With Quote
Old 07-22-2014, 10:10 AM   #8
Denis
Denis's Avatar
Drives: 2010 SS
oh well thats a different story. just pick up a used set of rear wheels and go to town lol.
Old 07-22-2014, 11:28 AM   #9
ytown87
ytown87's Avatar
Drives: C6 Corvette
That is almost 100% incorrect. Tons of people are running a square 20x9 setup on these cars and they dont poke out at all. You just keep the 275/40/20 on them.
Old 07-22-2014, 12:05 PM   #10
Matze
Matze's Avatar
I stand corrected, I thought the offset would cause issues.
Mathias
Old 07-29-2014, 03:31 AM   #11
Intimidator333
Thanks for your replies guys. So a 285 on a 9in rim in front is a no go?
Old 07-29-2014, 03:51 AM   #12
edneyens
edneyens's Avatar
Drives: 1SS/RS/M6-White/Beige
If you have a stock suspension it is going to be tight, it will at the minimum limit how much negative camber you can have, and possibly even cause the tire to rub on the strut on the top side. If you have replaced the stock struts with coil-overs you may have gained additional clearances due to products design providing a wider stance, on my car with pedders coilovers I gained 10mm clearance on each side.
I would suggest moving your back stock wheel/tire to the front and measure how much clearance you have, realizing that the 285 tire will need an additional 5mm clearance...
edneyens is offline   Reply With Quote
Old 07-29-2014, 03:14 PM   #13
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Wow, so much misinformation in this thread.
OP you will be fine.
SUX2BU is offline   Reply With Quote
Old 07-29-2014, 04:21 PM   #14
edneyens
edneyens's Avatar
Wink
SUX so says someone with narrow tires on the front... :-)
I had problems with the stock suspension using the factory rear wheel/tire combination up front with aggressive track camber settings - the tire rubbed on the strut at the top (was forced to use factory camber settings). Now I know there will be some tolerance differences from car to car, however with him attempting to use a 10 mm wider tire there definitively is some risk of the tire rubbing at this point. OP please proceed with caution.
