09-10-2014, 11:17 AM | #1 |
Drives: 18 ZL1 1LE Join Date: Apr 2013
Tire swap article from Z28 to 1LE
It would have been more interesting if they had run it around a road course for comparison also.
http://www.motortrend.com/roadtests/..._make_the_car/ |
09-10-2014, 12:28 PM | #2 | |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
Nice find...They really need some time on a road course with both cars... Here is my swap from 1LE to Z/28 wheels...I had Bridgestone at first but moved to a Hankook RS3...Not sure how I feel about the RS3 yet, but will be at Gingerman Raceway again Friday to try them out http://www.camaro5.com/forums/showthread.php?t=369676 Matt
09-10-2014, 08:37 PM | #3 |
Drives: 2019 Chevy Equinox Premier AWD Join Date: Mar 2011
Wow, the 1LE stops quicker than the Z/28 with it's tires!? I would not have guessed this from a car with those massive brakes. And only 35 pounds less eh? Hmm...
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43) |
09-10-2014, 08:50 PM | #4 | |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
I'm guessing the reason for this is the amount of heat in the brakes. I'm sure the Carbon Ceramics, when cold, will not stop as well as they do when they are warmed up. I'm sure for this brake test they did not get the brakes good and hot on both cars before testing them. And since the steel rotors with 1LE pads are designed as a compromise street/track pad they likely have more bite cold than the carbon ceramics do. With the extra grip of the Trofeo tires on the 1LE then the brakes can stop the car faster.
09-10-2014, 09:17 PM | #5 |
Too Many Great Choices
Drives: Grand Sport/Z07 Join Date: Jun 2009
The 1LE is great bang for the buck.
09-10-2014, 09:45 PM | #6 |
Drives: 2013 Camaro 2SS/1LE Victory Red Join Date: May 2014
Very informative article.
09-10-2014, 10:00 PM | #7 | |
Drives: '16 C7 Z51 Join Date: May 2012
On the surface they used, 1LE's softer suspension or less engine weight might have fared better. Who knows? One would need to analyze all the data.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
09-10-2014, 10:41 PM | #8 |
Drives: 14 1LE Join Date: Mar 2013
Wasn't it claimed that the z28 can pull -1.5g in decel? I sure as hell know the the 1le can't. Even With CTSV brakes I'm only hitting -1g and getting into the ABS a little. Although, my stops are from 100>40. 60>0 quite possibly is different.
LMS Engineering
09-10-2014, 10:45 PM | #9 |
What tires do you use, though? Sticky tires, in my experience, can increase the threshold for ABS by a huge margin.
09-10-2014, 10:47 PM | #10 | |
09-10-2014, 10:54 PM | #11 |
Drives: 2014 Camaro 2SS 1LE NPP Join Date: Nov 2013
Gentlemen, you must remember that single-distance braking tests are not a test of brakes, but a test of tires and suspension (suspension as far as using all 4 tires as effectively as possible).
There isn't a vehicle manufactured today that cannot activate its anti-lock braking system if you stand on the pedal. In other words, EVERY SINGLE VEHICLE ON THE ROAD already has more braking power than it can use. Larger rotors do not provide shorter stopping distances, they provide greater surface area with which to dissipate heat. The big difference between great brakes and okay brakes is all about repeated performance. An Escalade's brakes are more than powerful enough to lock up all four corners, but put it on a track and it will overheat those brakes in no time. So, it should be ENTIRELY expected that the 1LE will stop shorter with the Z28s wheels and tires because those wheels and tires offer more grip. End of story. Now, put Z28 wheels and tires on BOTH vehicles, and run those vehicles at full speed on the track, and the 1LE will cook its brakes and the Z28 won't. That is the difference. That is what you pay the money for. Suspension also plays a meaningful role in braking, as too much dive at the front and/or lift at the back will put too much of the overall braking responsibility on only 2 tires (the fronts). Porsche 911s always do phenomenally in 60-0 and 70-0 braking tests despite having relatively skinny front tires (I think a 911S only runs a 245 width front tire) because the rear-engine setup helps keep more weight over the rear wheels while braking. This allows the rear tires to help stop the car moreso than the rear tires on almost any other car on the road today. It always kills me when a car magazine or journalist is impressed with a car's stopping prowess and praises the brakes. Brakes are what stop you repeatedly, tires are what stop you once. |
09-10-2014, 11:24 PM | #12 | |
I still think lighter engine (and engine equipment up front) might have something to do with it..
09-11-2014, 02:07 AM | #13 |
Drives: 2014 SW 1LE Join Date: Jan 2014
Anyone with a Z/28 want to drive my 1LE around a road course with their Z/28 wheels & tires?
09-11-2014, 05:00 AM | #14 |
American Gold Whisperer
Drives: 2014 White 1LE 2SS/RS/NPP/Rec/Nav Join Date: May 2014
No doubt. And at roughly half the price too.
