10-14-2016, 07:53 AM | #1 |
Exhaust buzzing sound
Quick question. After I went with my current exhaust setup (tsp 2" primary LT headers, cat deletes and full 3" dual with x pipe through 2 flowmaster mufflers (quad tips) it sounds absolutely sick however at a certain rpm/load there is a horrible buzzing sound from the right rear of the car. I've triple checked the exhaust and nothing is close to rubbing and I can't duplicate it by banging underneath the car. Almost like a heat shield rattle from hell. Any ideas or anyone else ever get a similar sound from the right rear ?
10-14-2016, 08:27 AM | #2 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Have somebody back there and rule out the muffler itself...hopefully not a internal weld prob...good luck...
10-14-2016, 12:15 PM | #3 |
10-15-2016, 09:16 AM | #4 |
old school chevy rodder
Sounds like your most likely lugging the engine in a zone we have as all cars have where theres more vibration down low and your hearing it shake.... I get mild buzz on a stock NPP exhaust if I am luggin it down low in a small window where crap is more likely to shake in the console also.... which does not help, but its very minor and only noted if dogging it around town prolonging my being a rolling turd coasting from light to light practically after getting up to warp in .0000000000002 seconds. So even with other mufflers yes you would be a more prone to vibration zone when luggin or in a certain rpm, but yours may have a weak baffle that's more prone to sing with that harmonic....
10-15-2016, 03:32 PM | #5 | |
10-19-2016, 12:56 AM | #6 |
1st Civ. Div.
Drives: Camaroless for now...RIP "Big SexZ" Join Date: Dec 2007
The sound that you're experiencing maybe drone and not a rattling or buzzing exhaust. A full 3" exhaust with LT headers, off-road pipes and free flow mufflers will drone in a certain rpm range.
Swift....Silent....Deadly
10-19-2016, 01:46 AM | #7 | |
Drives: 2018 1SS M6 Join Date: Nov 2014
It could very well be a heat shield, not rubbing against the exhaust itself, but vibrating against the tunnel wall. Something along those lines. |
10-19-2016, 07:47 AM | #8 |
High-tech Redneck
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8 Join Date: Nov 2010
Maybe not your scenario at all, but "under load" could be what I had to consider with my 3" exhaust.
After headers and TSP off-road pipes were installed, I would get a rattle. Not a buzz per say, but marbles in a can. This would only happen under load and after warm. I put the car on the rack and loosened the driver side motor mount as much as I could without removing the nut and then jacked up that mount stud thus rocking the engine to the right to simulate the torque. I found that my pipe right at the bend headed to the x-pipe would hit the "frame" and contact the heatshield way before the cat-like off-road pipe would contact. I loosened clamps...pushed, pulled, pryed, and prayed and got more clearance (maybe a 1/4" more than previously at rest). No more buzzing/rattling. I may need some stiffer motor mounts.
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning. |
10-20-2016, 09:39 AM | #9 |
Drives: 2023 2SS 1LE Join Date: May 2014
Would agree with MrChrisLS3...I have the stock NPP and noticed that resonance/metallic vibration sound at 1000 to 1200 rpms (under a load)...Right now do not want the dealer to mess around and try to find the solution....For now
11-05-2016, 02:35 PM | #10 |
