Old 01-17-2023, 07:46 PM   #1
Tomd27858
Drives: 2011 Camaro SS
Hurst Shifter Bushing Upgrade
I am contemplating installing these upgraded bushings to correct some of the slop in the Hurst shifter in my 2011 SS. The shifter was installed by the previous owner and has 50,000 miles on it.
Has anyone done the upgrade? Is it worth it? Also, any tips and tricks to simplify the install? Goal is to be successful and drive it again.
Tomd27858 is offline   Reply With Quote
Old 01-17-2023, 07:54 PM   #2
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
I did the hurst metal bushing upgrade on first install , i thought it was two or three tho not just the one like in the pic. Can't remember tho for sure.
Either way my car shift very good and feels great( nice and tight and positive feeling shifts
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 01-17-2023, 08:02 PM   #3
davidscamaro
Only hard part is getting lower dust boot back on under the car. Hopefully you can change the bushing with out complete removal
Old 01-17-2023, 08:24 PM   #4
Tomd27858
I am glad to hear some good feedback on the bushing kit. I am hoping - planning on installing while the shifter is still in the car. I appreciate the feedback on the fact that the boot is the hard part.
My intent is to put the car on ramps and give it a go one night this week. I just didn't want to get in over my head and end up with a problem that I can't fix.
Old 01-18-2023, 01:17 AM   #5
Aziz2233
Drives: 2010 Camaro 2ss
My hurst shifter, what i ended up doing was removing the shifter and having brass bushing made and pressed in. I didnt like the idea of a nut and bolt holding it together and wanted the original pin and clips.
Aziz2233 is offline   Reply With Quote
Old 01-18-2023, 07:06 AM   #6
Tomd27858
I believe the bolt and nut are solely for installing the metal bushings while the shifter is still in the car. If I read the instructions correctly, the pin and clips are re-used.
Old 01-18-2023, 07:16 AM   #7
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
That is correct. I just did this last weekend. The bushings are way stiffer than the plastic ones. It was a bit of a pain getting the plastic ones out, but I was trying not to damage them just in case. I just dropped down the exhaust and driveshaft, leaving the guibo joint attached to the trans and it was all right there. Put a pry bar between the shaft and the guibo and the shaft will slide back and drop down a bit. The dust boot on mine came off and went back on easily. You only need to remove one of the clips on the pin and it will slide out. Probably took an hour.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
Old 01-18-2023, 07:52 AM   #8
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Just my two cents, but the best mod I ever did to my Hurst Billet Two Plus (installed by previous owner) was remove it and replace it with a factory shifter. No more noise, no more slop, and works great.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 01-22-2023, 06:01 PM   #9
Tomd27858
Some feedback on this. It is impossible on a set of ramps. Car is no where near high enough. There is no way to get two hands up in there at the same time. Not at 200lbs and 6' 1".
Get her up high in the air on jack stands. Then it is only a fiddly pain to get done.
Well worth it though.
Old 01-26-2023, 06:56 PM   #10
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
I did this install last spring on my car. I had installed the Hurst shifter back in 2009 when my car was new, one of my very first mods. I only have about 25000 miles on it since, had some slop but not too bad. I had to take the shifter out to replace the bushings. Just not enough room under there for two hands. I did it on jack stands and it was much harder than I remember when I put it in years ago. The bushings do feel tight and more precise.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 01-27-2023, 06:09 AM   #11
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
IIRC when I installed the one in my 2010 the instructions called for you to lower the trans cross member 3/4" to allow better access to reach in there. I believe it was just backing the bolts out on the driver's side. I did the install on jackstands without much difficulty. As my shifter was one of the first lot of 100 made, the bushings did indeed suck, but I traded the car before I got around to replacing them.
