12-12-2014, 05:22 PM | #1 |
Drives: 2013 2LT RS Join Date: Mar 2013
My screen wont turn on
Ok, so I just turned my car on and my screen is all black, but the radio works.
https://vimeo.com/114395744 Sent from my iPhone using Tapatalk |
12-12-2014, 05:39 PM | #2 |
Touchscreen still works!
12-12-2014, 05:42 PM | #3 |
Drives: 2012 45th Anniversary 2SS LS3 Join Date: Feb 2012
What's alt ctrl del for a camaro. Hold gas and clutch then tap brakes twice.
Maybe a battery disconnect? It appears as though the video cable came loose or something. Glad I don't have mylink. Just one more thing to break. Very strange, hope you figure it out. I would just take it in for that and let them fix it. If you start messing around with it you could void your warranty on it.
12-12-2014, 05:54 PM | #4 |
thanks
12-12-2014, 05:57 PM | #5 |
Silver Ice
Unplug negative on your battery in trunk for 10 mins or so. If it doesnt come on, probably a loose connection.
12-12-2014, 07:01 PM | #6 |
12-12-2014, 07:12 PM | #7 |
Silver Ice
No problem man, I'm really glad it helped! Expensive items like that are scary and stressful.
I work with electronics. For the most part, here are the golden rules with any electronic(s): Restart it. Pull battery for 10 minutes Pull battery for an hour if the 10 mins didnt work. Hit it really hard with your fists or against something as hard or harder than your fists. |
12-12-2014, 07:31 PM | #8 |
I work with electronics too lol I just didn't want to pull the battery because it's a pain (too much junk in the trunk) lol
Now windows won't roll up automatically tho Sent from my iPhone using Tapatalk |
12-12-2014, 07:51 PM | #9 |
Silver Ice
Ah I hate that.
You have to re index them right after you start up the car after doing the battery reset, By rolling down driver window all the way down then up. Either do the battery reset again and re index on the first start, or follow these steps to manually reset window memory. 1-A. Open the car door which needs to have the window adjusted. Turn the ignition to the run mode. Do one door at a time !!! 1-B. In the door jam, release the harness from the door (with a medium screwdriver, pull up the release tab, pull off w/ the palm of your hand, and pull the harness off the door for a minimum of 60 seconds (this is very important as the memory will be lost). 1-C. Reconnect the door harness and lock the tab back down. Close your car door. 1-D. The DIC will ask you to lower your door glass. Steps taken from http://www.camaro5.com/forums/showthread.php?t=70683 OP: TAG UR IT |
12-12-2014, 07:52 PM | #10 |
I did it when the dic told me but it didn't work haha it sucks
12-12-2014, 07:54 PM | #11 |
Silver Ice
Damn. The car knows you work with electronics. You are being tested my friend lol. Try the battery pull first its easiest. Then the manual method after. Or maybe the gremlins will be gone tomorrow morning lol.
12-12-2014, 07:56 PM | #12 |
Damn it... All the junk is back in the trunk lol
12-12-2014, 11:43 PM | #13 |
Drives: 2013 2LT RS camaro Join Date: Nov 2014
12-13-2014, 12:20 AM | #14 |
Has this happened more than once to your car? It's the first time for me. Sent from my iPhone using Tapatalk Last edited by PR325xi; 12-13-2014 at 12:41 AM. |
