05-21-2015, 06:46 PM | #1 |
Drives: 2018 Camaro 1SS/1LE Join Date: Feb 2015
How often should I change my oil?
It's been around 15 years since I last owned a car that took synthetic oil. I'm bringing my car to the dealer tomorrow to get its first oil change since purchasing the car in January.
I've heard all different numbers all the way up to every 10,000 miles. How often should I be changing it? Also if it's over 3,000 miles, will it void my warranty? |
05-22-2015, 08:02 AM | #2 |
Drives: early 2011 Camaro convertible Join Date: Jul 2014
I use Mobil 1 and change it every 5K or once a year.
Early 2011 LT Convertible, ZL1 bumper, hood, side skirts, belly pan and wheels, Truecarbon ECF hood extractor, K&N CAI, Elite catch can, Big Worm Bow Tie emblems, Jacfab bracket, Vitesse TC, BMR strut brace, BMR tunnel brace, NPP exhaust |
05-22-2015, 08:22 AM | #3 |
Drives: 2011 2SS 6.2L W/RS package Join Date: Jan 2011
I put between 3-4k on my car a year, so I just change it every spring..
KooKs LT Headers, Borla S-Type cat back, RotoFab CAI, Bo White PTB, RMCR tune... |
05-22-2015, 09:47 AM | #4 | |
MY SS is SOLD
Drives: AGM 2012 Camaro 2SS/RS L99 Join Date: Mar 2012
I put about 12K miles per year on mine. I change the oil as soon as I feel like doing it after 4K miles.
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
05-22-2015, 11:24 AM | #5 | |
I'm on the same pace as you. That will probably be my routine as well. I guess time will probably outweigh milage in our scenario. |
05-22-2015, 12:32 PM | #6 |
Well I just got back from the dealer. The sticker on the windshield has a date of 10/22/15 and 5,000 miles from now. Unless something happens to my DD, I wont be hitting 5,000 miles for at least a year and a half so I guess I'll just get it done about a year from now.
05-22-2015, 01:03 PM | #7 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
I use the oil life indicator. I usually wait until it gets to 10-15 percent life and then I change it.
05-22-2015, 01:09 PM | #8 | |
Too much is never enough!
I did that for all of 50k miles, now that I added cam and turbos, I change it every 4k miles on the dot.
05-22-2015, 10:01 PM | #9 |
Drives: 14 1Le --14 chevy ss sedan 07shelby Join Date: Sep 2014
I have a CAMMED 1LE so far I change it every 300-600 I have 1800 miles I'm on 6th oil change
05-23-2015, 03:08 AM | #10 |
if using the dexos semi synthetic the dealer puts in just go with the oil life indicator or once a year.
MRREVINTO7 absolutely no reason to change your oil at 600 miles unless you are tracking the car . you are basically dumping new oil. with a cammed car do 3000 to 5000 on either Amsoil Z rod 10w30 or Driven LS30
05-23-2015, 01:33 PM | #11 |
The dealer put Mobile 1.
05-23-2015, 01:51 PM | #12 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
Change it every 10 years, or every 100,000 miles.
Or...you can change it every time you drive it. Or somewhere in between. Seriously, you have to do what makes sense to you. There are the "3K mile no matter what" types, and then there are the "wait until the oil life monitor tells me" types. And then there's always those in between or longer. Best advice if you're really serious about finding your sweet spot is to do one of those blackstone lab kits and get an oil analysis done and figure out what makes sense to you as far as drain intervals. It will tell you a lot about your oil based on YOUR engine. But if the engine is new, it'll usually show different results at first as it wears in. Otherwise, use a trigger point that makes you feel all gooshy inside. I like to do the OLM monitor myself as it gets around 10-15% then schedule it to be done, and have NEVER had any issue using Mobil 1, even after sending samples to blackstone just to verify.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
05-23-2015, 11:07 PM | #13 |
mobile 1 is full but if you just ask for a oil change you get what ever semi dexos they have that month. Find out what Mobile1 recommends might be 10,000
05-24-2015, 09:02 AM | #14 | |
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1 Join Date: Jan 2014
+1 |
