10-01-2013, 05:57 AM | #1 |
Drives: 2014 ZL1 White Convertible Join Date: Aug 2013
Can the ZL1 Suspension be adjusted?
I got my 14 ZL1 on 9/16, I have to say it is super quick. and it has an addiction to octane that is unquencable. I do not know much to anything technical about the magnetic ride system, other then it is super sensitive and you feel everything in the road including a beetle trying to cross it. The sensitivity is a nice but not always needed imo, and infact I really cannot distiguish much of a difference between tour and sport mode. So Can the suspension be tuned more without a hassle?. I would like to make tour alittle more softer like tour should be, and less like race day all the time. I truely enjoy race option, but sometimes I dont want to feel every bump in the road. anyone know?.
10-01-2013, 06:06 AM | #2 |
Drives: 2014 ZL1m6 red hot #569 Join Date: Dec 2009
if you cant feel the difference between mode 5 sport and touring then you need a new butt dyno. the difference is night and day. take a small stretch of road that has a few dips and cruise it in mode 5 sport then do it in regular mode. you will feel the difference then. mode 5 sport is very distinct
10-01-2013, 06:27 AM | #3 | |
2013 ZL1
Drives: 2013 ZL1 m6 Join Date: Oct 2010
I have not heard of this being a possibility(retuning the mag ride), but I don't know. |
10-01-2013, 06:36 AM | #4 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
I can't really tell much difference in modes, either. Then again, not expecting a Town Car ride. I believe you'll have a hard time altering one mode without affecting the other, though. I can tell you that the ride in either mode is night and day better than my SS ever thought about being.
10-01-2013, 06:42 AM | #5 |
Well I gotta say, Great Observation!!. I really should have made the fact that my car is a Convertible, so that PTM would not have been a consideration, however it did not slow you down DVKidd. I apprecate all feed back, and why GM didnt put the PTM in the Convertible is beyond words. The car can kill you with or without it just as easily, drive with a brain and live. Well hopefully someone out there knows something technical about the suspension.
10-01-2013, 11:11 AM | #6 |
Drives: 13 ZL1 SIM, 99 Z28 Black Join Date: Feb 2013
I don't notice much difference between tour and sport. PTM5 is track so there are 3 suspension settings if you have the PTM's.
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
10-01-2013, 02:57 PM | #7 |
Drives: SW 2017 ZL1, M6, Carbon, Nav, MR, Join Date: Dec 2012
Look underneath at the front springs. Your yellow spacers are probably still in there. If so remove them. Tour and Sport mode are (should be) easily discernible.
10-01-2013, 04:24 PM | #8 | |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
The suspension itself is not adjustable, but as Snackbar64 says, look at the front springs, you should be able to look at them from the wheelwell and look for yellow spring spacers that the dealer may have left installed by accident. The spacers are needed when transporting the car to increase the front ground clearance when loading the car onto the car haulers, but are supposed to be removed before delivery. If the spacers are still installed, they will cause the front suspension to be very stiff resulting in the harsh ride you described. The spacers can be removed once to raise the front of the car enough to take the load off the front springs. If you have a floor jack, you can remove them yourself, or take it to the dealer and have them remove the spacers. It's not unusual for dealers to forget to remove them. They are supposed to be removed and handed to the owner or at least put in the glovebox so they are available if you ever need to have your car hauled on a trailer. At the same time, look under the front of your car, in front of each front wheel. The dealer should have also installed little air dams at the same time they prep the car. |
10-01-2013, 10:44 PM | #9 | ||
I Carry!
Drives: 2013 CRT ZL1 Join Date: Jul 2011
Suspension is adjustable.....
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540 From Oklahoma, Join us on Facebook https://www.facebook.com/groups/okcamaros/ |
10-01-2013, 10:57 PM | #10 |
System Test Engineer
Drives: '12 ZL1 #1011 Join Date: May 2012
Well, I think the suspension is about perfect for a car of this type for the intended usage. No softer in tour, and I could go a little stiffer in sport to be honest, but anyway...
The short answer is from what I understand of the suspension if you could reprogram the control module/s for the individual dampers then you could modify the current being supplied to control the default (at rest) damping. I doubt this is possible, i.e. proprietary tech? And, yes, I know GM doesn't manufacture these...and if I'm way off here ignore everything I just said. |
10-01-2013, 11:27 PM | #11 |
Drives: 13 ZL1 vert blac fastlane/LPE 750 Join Date: Jul 2011
there is no ptm in the vert ? what the fuc%%% So what does that mean for the vert as far as driving it,in rain etc..i have track timing etc/so now i guess i need some info
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
10-02-2013, 02:19 AM | #12 |
Can't stop ***ifying
Change springs. I put Eibachs. The are progressive like our stock ones, but the soft side is softer than the soft side of our stock ones. Helped with absorbing small bumps. Made the ride more compliant on normal roads. Supposed to be a performance increase, but I doubt it, and since i don't race, I don't mind.
Rotofab, grinding rear diff sound forever, dealer replaced supercharger - now i have a rattle when starting from a stop, ordered 2.35 lingenfelter pulley, hp tuner, belt, 100mm idler pulley, tr7IX spark plugs, wideband kit, long tubes with no cats...hoping for 650hp. dyno with rotofab = 518hp |
10-02-2013, 04:00 AM | #13 |
Camaro fan since birth
Am I the only one who notices a difference between Tour and Sport modes on normal roads?
Sent from my SAMSUNG-SGH-I337 using Tapatalk 4
10-02-2013, 04:33 AM | #14 |
[QUOTE=SamHouseIII;7055372]Suspension is adjustable.....
/QUOTE] You are entirely correct. What I should have said is the compliance of the shock absorbers (stiffness) is not user adjustable. |
