Old 11-23-2013, 10:34 PM   #1
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Compression Testing
Hey guys,
I pulled my headers off the other day to take them to get ceramic coated. When I pulled the plugs out, I noticed a good amount of oil on the plug for cylinder 1, and a little bit on 4. I was hoping it would be a valve seal. I took the springs off, and the seals looked good. I replaced them anyway. I wanna do a compression test but since I have most of the engine torn down, is it possible to do a compression test without the rockers on? The only thing I can see going wrong, is the lifters turning sideways if the tray were to drop one. Has anyone done this before? The reason the rockers wont be on is because while they are off Im gonna put my trunion upgrades in, finally. My dad can only come over in the morning to help with the compression test so I wanna get that out of the way, then worry about the rockers. Is this a bad idea? Thanks!
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 11-23-2013, 11:09 PM   #2
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
You will need the rocker arms on. A compression test simulates the cylinder pressure generated thoughout the engine cycle. You could do a leak down test though!
Also if you look at the top of the piston if the oil/carbon build up is around the edge of the piston its most likely rings. If its intake valve you should see fairly clean oil on the back side of the valve. How much oil does it use? Any pics??
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 11-23-2013, 11:53 PM   #3
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
I dont have the heads off so I cant see the pistons. Ill prolly end up pulling them to send them off to AI. Just didnt think I was going to do it now. Lol!! Here are some pic of the plug and the hole it came from.....
Old 11-24-2013, 12:03 AM   #4
Nutro
Nutro's Avatar
Drives: 2011 2SS Synergy Green
Damn dude those plugs are oil soaked. You burning any oil?
Nutro is offline   Reply With Quote
Old 11-24-2013, 12:08 AM   #5
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Not sure. Its hard to say when I only drive the car twice a month and I only have 300 miles on this oil change. I was REALLY hoping it was a valve seal but like I said, they looked good. I may pull the heads tomorrow and check what WHITE was talking about above. My 418ci maybe happening sooner than expected.
Old 11-24-2013, 12:23 AM   #6
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
the picture seems to show oil on the outside of the cylinder not inside
firestone_ss is offline   Reply With Quote
Old 11-24-2013, 12:25 AM   #7
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
I couldnt get the camera to focus on it, but the base of the plug has wet oil on it. Not on the electrode, but on the very bottom.
Old 11-24-2013, 11:54 AM   #8
White_SS/RS
Drives: 14 1LE
Do you have the intake off? If you do, look down the port at the back of the intake valve and see if it looks similar in condition to the plugs. How many miles are on the engine?
LMS Engineering
Old 11-24-2013, 02:27 PM   #9
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Did a compression test and results are pretty inconclusive. Here is what it looks like:
#1 215 @ 5 revs
#3 181 @ 4
#5 212 @ 5
#7 175 @ 4
#2 180 @ 4
#4 175 @ 4
#6 168 @ 4
#8 193 @ 4
Cylinders 1 and 5 shot up quite a bit further than the rest. Once I had completed all cylinders, I went back and redid 1 and 5 and got:
#1 168 @ 4
#5 181 @ 5
What Im thinking is there was oil on top of the piston that was sealing the rings, and after several engine cranks, it cleared out. The engine has 44k on it and the car is the most pampered car out there. Its not abused by any means. The manifold is not off but I am going to take it off to check in the intake valves. Anyone have any feedback? Thanks!
Old 11-24-2013, 03:05 PM   #10
Jmar
Drives: 2012 LS3 CRM, V8 Healey, Mini
Try squirting a little oil in the spark plug hole and crank the low reading cylinders again. If the reading jumps up it's ring seal.
Or put air pressure in the low cylinders while the rockers are off and check for leaks. If air is coming out the intake or exhaust you have valve problems. If air is coming out the PCV tube it's rings.
Jmar is offline   Reply With Quote
Old 11-24-2013, 03:23 PM   #11
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
I had oil on the threads at the top of the plug right by the hex when I changed plugs but the plugs were perfectly clean and white. I suspect when I changed the rocker covers the oil seeped down the outside of the head and pooled around the plugs in the head but I'm not sure. I don't use any oil and the catchcan is collecting water vapor only so I'm at a loss also. Don't know where else it can come from. Are there oil channels through the head that can weep past the head gasket and collect oil at the plugs? Perhaps at 9 psi I'm forcing it out somewhere in the area by the plugs?
Keep us updated.
Iam Broke is offline   Reply With Quote
Old 11-24-2013, 07:41 PM   #12
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
I know its not a rocker cover. There was no oil trail going down into the plug. Here are some pics with the manifold off. Im wondering if the head is cracked?
Old 11-24-2013, 08:36 PM   #13
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Could all this be a PCV issue? I was just talking to my dad and looking at the pics, and all the ports are pretty oily. Since the PCV is right behind the throttle body, is it possible cylinder 1 is just getting the grunt of the oil the PCV is ingesting? Im ordering a catch can now. That would be great if thats all this is! But thats just a lot of oil for a PCV system, at 8,000 miles.
Old 11-24-2013, 08:59 PM   #14
iPODFAN11
iPODFAN11's Avatar
Drives: 2019 Shock ZL1
There was plug fouling/cracking on truck engines prior to 2011.
PCV pullover that adds additional oil to the cylinders that can foul out or damage the spark plugs
There was an updated valve cover for the Vortec Gen IV engines. I wonder if this might be what you are experiencing.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
