Old 09-09-2010, 07:59 PM   #1
Styffydawg
SSinister
Styffydawg's Avatar
Drives: Ram SS/T + Murdered Out 2SS/RS
LS7 Lifters
What's up guys
I dropped a big Thunder Racing cam in my car about three months ago and under the advisement of TR did not upgrade the stock lifters.
Pretty sure one has gone bad on the right side. It's making a lot of noise and feels like timing has been pulled from the motor. I might be able to get a set of LS7 lifters from a dealership in town if they have them in stock and was wondering if anyone has used these in an ls3. I know all the LSx motors share common traits but want to make sure before we dive in.
SSinister
Styffydawg is offline   Reply With Quote
Old 09-09-2010, 08:15 PM   #2
usmc8411
Drives: 2010 camaro
They are the same lifters.
usmc8411 is offline   Reply With Quote
Old 09-09-2010, 09:28 PM   #3
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
The reason why Thunder did not recommend new lifters is because your stock ones are the same LS7 lifters and could not have had many miles on them.
Old 09-09-2010, 11:25 PM   #4
Styffydawg
SSinister
Styffydawg's Avatar
Sweet. We didn't think that 5k miles would be enough to develop a wear pattern but apparently it was or that one little guy was just a bum lifter from the factory.
Thanks for the help just wanted to double check.
SSinister
Old 09-09-2010, 11:33 PM   #5
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
ok i have to ask the question just to make sure. Auto or manual?
trudawg660 is offline   Reply With Quote
Old 09-10-2010, 10:45 AM   #6
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
ya that will be the real ??
woodside783 is offline   Reply With Quote
Old 09-10-2010, 12:37 PM   #7
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
if you already had a lifter go bad, you might have bigger issues.....
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 09-10-2010, 12:49 PM   #8
Steve@Vectormotorsports
Drives: Firehawk
Originally Posted by Styffydawg View Post
What's up guys
Look into the CTS-V lifters they have a ceramic check ball and are a sweet upgrade over LS7 lifters
Steve@Vectormotorsports is offline   Reply With Quote
Old 09-10-2010, 09:17 PM   #9
Slowhawk
Drives: 1999 Trans Am
Depending on how big the cam is the LS7 lifters work well. I've run them up to .660lift Cams reving to 7400rpm. The CTS-V lifters are suppose to be stronger but I blew 3 of them apart and went back to LS7 lifters.Could of been a bad batch though.
Slowhawk is offline   Reply With Quote
Old 09-11-2010, 02:27 AM   #10
Ivan @ Southwest Speed
Ding Ding Ding....
Yella Terras while you're at it too.
Ivan
Old 01-25-2011, 02:27 AM   #11
The 2010 Sin
Dont H8 Me Cuz U Aint Me
The 2010 Sin's Avatar
Drives: 2016 SS Sedan, 2017 Explorer Sport
I broke a lifter on my toy.. down at XP-Racing.com getting all patched up.. DAMN!
The 2010 Sin is offline   Reply With Quote
Old 01-25-2011, 04:08 AM   #12
CC Performance
Drives: 99 Camaro SS, 79 z28, 70 GTX
The only lifter I would upgrade to is the Morel link-bar its a true Hi performance lifter none of the others are, in fact the caddy is tiny compared to the rest of them and has casue more heart ache than good. The valvetrain needs to be properly matched.
It comes down to the cam profile and springs you chose.
We see LS7 lifters develop a tick and some of them fail all the time with the use of aftermarket cams and springs.
This is an LS7 lifter which is bigger than a caddy lifdtr compared to a Morel.. the Morel uses better materials and has a bigger pin and wheel.
The one of the left is the Morel Hi rpm micronited $700 lifter. The middle is the Morel 5206 most common used lifter and the right is the LS7 lifter. We only like to use the link bars, its a better systen than the lifter trays gm uses. Not pictured is the caddy, its smaller than the LS7 by a good amount though and to be honest is never used by us.
What happens to the LS7 is the pin starts to come out and then the wheel fails and then its time for some new parts and maybe even a whole new bottom end.
CC Performance is offline   Reply With Quote
Old 01-25-2011, 07:54 AM   #13
Jayson9
Drives: 2SS
I was told the same thing about a Crane Cam install once on a new crate engine, never do that again. IMHO - always install new lifters when replacing the cam - less room for failure.
Jayson9 is offline   Reply With Quote
Old 01-25-2011, 08:15 AM   #14
andredmg
Big Nasty
andredmg's Avatar
Drives: Chevys lots of em
Morel PERIOD!!!
andredmg is offline   Reply With Quote
LS7 Camaro on eBay starting at around 60k! x7productions 5th Gen Camaro SS LS LT General Discussions 11 03-19-2010 03:54 PM
Lingenfelter 750hp LS7 Camaro debuts at SEMA Tran Camaro Photos | Spyshots | Video | Media Gallery 14 11-07-2009 10:40 PM
SEMA CAMARO: LS7 Camaro Tran Camaro Photos | Spyshots | Video | Media Gallery 157 10-16-2009 09:26 AM
LS7 Camaro....some assembly required Txturbo 5th Gen Camaro SS LS LT General Discussions 11 11-03-2008 12:17 PM
