04-17-2014, 08:12 PM | #1 |
Autocross z28 setup on 1le
OK my thought is to get more rubber on the road to help with autocross lap times in my F Street class.
I have been looking at copying what was done on the z28, but i have some questions. Z28 runs Front - 22873225 - (19x11 11mm os) (GM says the shipping weight is 25.88 pounds) - $795.00 Rear - 22873227 - (19x11.5 26mm os) (GM says the shipping weight is 26.32 pounds) - $795.00 All Tires 4 305/30/19 pzero trafao All that = 1.3g turning..... THAT IS WHAT I WANT the 1le rims are 20X10 23mm offset Front and 20X11 43mm offset in the Rear. What Im wanting to run is a 19 X 10.5 inch rim, mainly because I cant find it the other sizes. and a Handkook Ventus R-S3 305/30/19 Tire. Also, the rims Im finding are 27mm offset. and bolt pattern 5x120 Now for the questions... 1) Will what I have listed work? (10.5X19 with the handkook) 2) What are acceptable ranges for the offset front and rear on a 19 inch rim? if I'm using the 305/30/19 3) Without modification to the suspension can I fit the tires and wheels on my car? 4) Does anyone have a lead on where to buy 19 X 11 rims that will work... Better 5) what the hell is the offset, and why is it important? please explain it to me in layman terms Thanks for the help in advance, I'm not a very mechanical car guy I just do research till I understand and I'm trying to fix my problems I had on the track
Drives,
2016 Camaro 2 SS, (OLD CAR)2014 Camaro 1LE, 2SS, NPP Dual Mode Exhaust, K&N Air Filter. E3 Catch Can. z28 Grill, and 1LE Badging |
04-17-2014, 08:38 PM | #2 |
Drives: 2022 SS 1LE Join Date: Jul 2013
A great source of knowledge and lightweight forged wheels is CCW. I run 315/30-18s on 18 x 11s front and 18 x 12s rear, I'm not positive what my offset is. My 18s don't quite tuck under the fenders, so they're fine at the track but not a good choice for street. I plan on adding Z/28 like fender flares to remedy this. You need to modify the front suspension arm for clearance to run 18s. The clearance is so tight that if the wheel weights are all the way towards the inside, the suspension arms will knock them off, LOL. The 18s are a reaaaallllllyyyy tight fit, 19s would be easier. So bottom line, I think you're headed in the right direction.
CCW can set you up with the correct offsets. There are other choices as well as the Trofeos, I love Nitto NT-01s. Not sure what comes in a 305/30-19 though.
Sold but not forgotten! Pedders Supercar Coilovers, 32mm rear sway bar,bushings; APR wing and splitter
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb 1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697 Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086 |
04-17-2014, 09:14 PM | #3 |
Drives: 2012 SS LS3 Join Date: Nov 2011
For what its worth, F street rules don't allow you to put wider wheels on. You can probably get away with it locally, but at bigger events a protest might happen. Otherwise, to be legal you will get bumped to a higher class.
Buttonwillow 2:23.736
Sacramento Raceway 12.89 at 112 mph Thunderhill 2:22.242 |
04-17-2014, 09:30 PM | #4 |
I thought in F Street you could put on wheels that came on standard models of the car like the z28, or zl1 like i said im new to this so I could be wrong.
Drives,
04-17-2014, 11:44 PM | #5 |
I don't believe you can swamp parts from one model to another unless you swap every part over to create the alternate model. The change in model must be complete, not just cherry picking parts. Also the model must have been produced the year of your car. For instance, I would love to convert my SS to a 1LE, which wouldn't be to hard, but 1LE's were not produced in 2012, so I can't legally do it in FS.
They're others with more experience that may prove me incorrect, but I have been studying the rules pretty closely and reviewing several SCCA forums to educate myself.
Sacramento Raceway 12.89 at 112 mph Thunderhill 2:22.242 Last edited by Cuda7050; 04-18-2014 at 12:03 AM. |
04-18-2014, 05:12 AM | #6 | |
Drives: 2014 1LE Join Date: Sep 2013
Offset is very important, the higher the number the more the wheel is "pushed" towards the inside of the car, the lower then number the more it is pushed to the outside of the car. When trying to fit bigger tires or wheels you can and will rub on the inside suspension or outside fenders if the offset is wrong.
2014 Red Hot 1LE |
04-18-2014, 07:25 AM | #7 |
Well I do have the 2014 so I'm good on the year, same as the z28. THE RULES ARE VERY CONFUSING... I think my factory rim width is allowed to be modified by 1 inch, but it is not necessary because factory my car came with 11" rims on the rear, I would just be adding them to the front which came with 10" if I square the setup to 11" all the way around I think I'm good. I wish we had an scca official to answer. I believe the 305 will easily fit on the rear 11" without issues. Zl1 has the same rims and factory 305 on the rear.The real question is the front 305 and what size rim and offset I need to get it on the car.
I should probably take a rear zl1 wheel and try it, but I want to drop to 19s,. Also is anyone using the handkooks and how are they on the track? Sent from my SM-N900T using Tapatalk
Drives,
04-18-2014, 07:39 AM | #8 | |
As for the rear zl1 wheel, you already have that on your 1le. If you are talking about taking the actual wheel and running it in the front, it most likely will not work because the offset going to make it rub on the susension, not the mention it will also break the rules when it comes to offset and width. As far as the rs-3, I plan on autoxing this weekend with a different club, a very well known driver will be there with his 1le running rs-3 on factory wheels. Im sure he will share his findings.
2014 Red Hot 1LE |
04-18-2014, 07:44 AM | #9 |
I thought there was a section that said I could change parts between models of the same year. If not can I get a 305 on a 10" rim?
Drives,
04-18-2014, 07:50 AM | #10 |
Have you thought of keeping your rims to be safe and move to a 295. I know folks have said the Michelin Pilot Sports in that size run close to 300 vs others 295's.
04-18-2014, 07:55 AM | #11 |
Yes I have, but I wanted a separate set with autocross tires so I can swap them out. I figured if I did that I might as well get the additional handling benefits of lowering the car with the 19" rims.
Drives,
04-18-2014, 08:12 AM | #12 | |
Can you fit 305's on a 10 inch rim, sure. How will that affect turn in with a slight buldge...don't know till I try it.
2014 Red Hot 1LE |
04-18-2014, 10:44 AM | #13 |
This may help:
http://www.camaro5.com/forums/showthread.php?t=201546 Sux to be you has been through many combinations.
"Democracy Dies in Darkness" |
04-18-2014, 11:01 AM | #14 |
Drives: 2013 1LE 1SS Victory Red 1 of 76 Join Date: Sep 2008
Keep in mind also when you change wheels for street class the offset has to be plus or minus 7mm vs stock
2013 1SS 1LE Victory Red. 187 CAM-C
